#99 |
Drives: BRZ, STI, GT350R, Supra, 987.2
First product photo:
![]() They are selling the kit *only* with the crash beam, there will not be an option to order it without the beam. I personally think this is really reasonable for a bolt on oil cooler kit. I'll keep the thread updated as it is fully released and ready for purchase. Should be very soon. Thanks, Eric Last edited by VerusEric; 07-28-2017 at 10:16 AM. |
#100 |
Sent from my XT1575 using Tapatalk |
#101 |
Last Starfighter
Drives: 2016 FR-S Series 2.0
We test fit on my car. So i dont think the production kit has been fully mounted yet. If i get my hands on it, ill post pictures mounted up.
Sent from my SM-G955U using Tapatalk |
#102 | |
#103 | |
The Mocal adapter fits and does not need banjo bolts, which is a huge plus IMO. We found that the Grimmspeed, IIRC, oil cap did not fit with the Mocal adapter and turbo... *So if you have an aftermarket oil cap, you *may* need to revert back to stock.* ![]() ![]() Thanks, Eric Last edited by VerusEric; 08-06-2017 at 08:26 PM. |
#104 |
Thanks, that's what I was looking for. Look forward to seeing it with the bumper cover installed. Any idea why the oil call wouldn't fit?
#105 |
Last Starfighter
If you mean the cap? Look at the clearance between it and the sandwich plate. It has to do with the tight fitment next to the turbo
#106 | |
#107 |
Drives: t
is there space to put in a larger core? where will the air exit?
#108 |
Last Starfighter
The core they chose is definitely larger than the mock up one in the last photo. A 19 row setrab fits fine. The air can escape up if you use hood vents. If not, some holes in the fender liner vehind would work nicely.
#109 |
Drives: Toyota 86 GTS
What exhausts are everyone running with this kit (from mid pipe back). Looking at getting the Tomei 60s and a 2.5" mid pipe with a cat as I want to reduce the weight of the exhaust system as much as possible, but will the smaller diameter hinder performance a lot? I am not aiming to be pushing anything over 280-300hp initially, and once I go e85, nothing over 350. Also, may sound stupid, but would a 2.5 inch front pipe connect to the full race 3" over pipe without any issues?
#110 | |
Drives: t
| The Following User Says Thank You to choi0706 For This Useful Post: | arthur93 (05-30-2017) |
#111 |
Drives: t
#112 | |
Last I was told, there are 3 in stock. Thanks, Eric |
| The Following User Says Thank You to VerusEric For This Useful Post: | arthur93 (05-30-2017) |
| Full Blown Turbo Kit Owners Topic | King Tut | Forced Induction | 2639 | 04-05-2026 10:31 PM |
| Full-Race Motorsports | White_Lightning | Forced Induction | 259 | 04-11-2017 01:04 AM |
| best turbo kit - currently Full Race? | TEAM SCION | Forced Induction | 41 | 10-14-2016 08:41 PM |
| Full Blown Motorsports turbo kit exhaust question. | Jtbirchfield | Forced Induction | 2 | 09-09-2015 04:19 PM |
| Full blown turbo kit owners | Joeycokeboy | Engine, Exhaust, Transmission | 2 | 09-02-2015 09:49 PM |
