Old 05-16-2017, 08:35 PM   #2185
rt
@rayhere
rt's Avatar
Originally Posted by icybrzzz View Post
More pics please!
rt is offline   Reply With Quote
Old 05-17-2017, 11:29 AM   #2186
jubella2
jubella2's Avatar
Drives: DGM BRZ
@rt you make me wish I would have gone for 255 instead of 245 on those wheels. The 245 has a bit of stretch but yours is so pretty and square.
jubella2 is offline   Reply With Quote
Old 05-20-2017, 03:20 PM   #2187
rt
@rayhere
rt's Avatar
Saw your post in the 57CR thread. The gun blue isn't as blue as I thought so it's making me wish I got those instead.
Btw just noticed my rear is rubbing slightly after some spirited driving so I'll have to roll the quarters. Not that bad though since I didn't even feel it, just happened to look at the tires after and it was barely there in the pic I posted earlier.
Old 05-20-2017, 07:12 PM   #2188
jubella2
jubella2's Avatar
Drives: DGM BRZ
That sucks about the rubbing. That was something I was worried about going with a 9 inch wheel. I haven't really pushed the car yet but so far none for me. The wheels are mostly gray but in direct sunlight you can tell they are blue. Hard to capture in a picture though.
Old 05-21-2017, 02:35 AM   #2189
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If you have the right offset it should be no worry at all, looks like @rt could be prevented if it was a +40 instead of +38. Shame that's the expensive direction to change offset.
With 17x9+45 and 245 tires the dampers run out of travel before the wheel/tire hits anything, and plenty of clearance to stuff a 255 under there, maybe even a 265. I run a 5mm spacer to prevent rubbing at full lock.
But then again I guess a lot of this thread is about looks and "flushness" so that solution probably isn't too welcome.
ineedyourdiddly
Old 05-30-2017, 07:49 PM   #2190
sid94
Drives: 2013 frs
I can finally make it on this thread just bearly tho lol
Disregard my crappy phone pictures
Work XD9 18x10 +38
Achilles ATR sportz 255/35 18
sid94 is offline   Reply With Quote
Old 06-01-2017, 09:31 PM   #2191
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
you sure you're not rubbing on the bumper tab in the rear? how sure are you your'e rubbing on the bumper. usually if you rub it gashes the sidewall, doesn't look like thats whats happening here.
Jive Turkey is offline   Reply With Quote
Old 06-01-2017, 11:05 PM   #2192
rt
@rayhere
rt's Avatar
You're right actually. I took a closer look a few days after and it's just rubbing the bumper tab so no need to roll! Forgot to follow up here.
Old 06-02-2017, 07:36 PM   #2193
ericwudi0830
ericwudi0830's Avatar
Drives: Scion FR-S
How elegant
I don't drive fast, I fly low
ericwudi0830 is offline   Reply With Quote
Old 06-06-2017, 01:55 PM   #2194
keb86
Drives: Toyota 86
would you be able to show how will you take care that bumper tab?
keb86 is offline   Reply With Quote
Old 06-06-2017, 02:11 PM   #2195
dattran86
Driver
Drives: 2013 Whiteout FRS
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
Old 06-07-2017, 08:08 PM   #2196
PeterFRS
PeterFRS's Avatar
Drives: FRS
doesn't show the meaty ness - shot from recent autox
255/40R17 all around
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 06-13-2017, 09:31 PM   #2197
rt
@rayhere
rt's Avatar
You can just shave the tabs so they're shorter.
Old 06-13-2017, 09:34 PM   #2198
jordonallison
jordonallison's Avatar
265/35's..
IG @jordonallison
jordonallison is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
