#29 |
RCE, do you think because we have macpherson struts in the front that we have inherent problems with camber loss? I only ask because I'm not sure if this is something that has more to do with older cars.
#30 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
This is exactly the set up I was looking for! Great to hear it's a good fit. I already have the whiteline camber bolts for the front and at some point might do the SPC or Velox control arms for the rear. I felt the $1100 for the tarmacs and the B6's would be just right for me. Especially since I don't need adjustable height and the dampening of the B6's sounds like it's good enough.
#31 |
Drives: 2019 WRX
Thanks good to know!
#32 | |
Drives: 2019 WRX
| The Following User Says Thank You to JMon85 For This Useful Post: | Stang70Fastback (05-15-2017) |
#33 |
Drives: 2013 Subaru BRZ
And now Subaru makes a 15 mm rear bar for the 2017 cars.
That makes a choice of 14 mm stock, 15 mm factory, 16 mm adjustable from Whiteline, though they do not publish the equivalency of each of the three link locations in each end of their bar. In theory that adjustment gives a choice of six effective rear bar rates. Camber delivers grip without affecting roll rates, all other things being equal. Camber delivers grip by camber thrust, the tire physically resists being compressed into the road rather than resists being scrubbed across the road, more like a motorcycle tire and less like a car tire. This creates serious overheating problems quite quickly on the road or track. Camber ideally is specified to provide even tire wear considering how the car will be driven normally on the street. Racing tires are sensitive to incorrect camber because of temperature effects caused by excessive camber on one side of the contact patch as compared to the other side. So camber is also carefully considered for track work. There is likely not much difference between ideal camber for the road or for the track when using street tires. A tire temperature gauge is very useful for testing for this if the seat of your pants isn't working for you. Auto X typically does not overheat tires to the point that one side of the contact patch works less optimally than it could. You can therefore get away with a lot more camber than might otherwise be ideal. A slalom and a skid pad can similarly mislead you into dialling in too much camber. Last edited by Gforce; 05-15-2017 at 07:31 PM. |
#34 |
Which would be only slightly stiffer than the 20 mm solid bar. Maybe just enough to hit the sweet spot with that 16 mm rear bar.
#35 | |
But a little camber goes a long way. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | norcalpb (05-16-2017) |
#36 |
Wes
rookie question, but you need to buy camber plates to be able to adjust camber, right? That type of adjustability doesn't come with aftermarket coilovers?
#37 | |
Camber plates are useful if you need/want a lot of camber or want a solid plate instead of a rubber top mount. - Andrew |
#38 |
Wes
Okay thanks! And these camber bolts go into which part? I'm only looking to go -1.5 at the front and -1.0 at the back, and I'm guessing the bolts provide a fixed camber angle?
#39 | |
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=25001 iirc some struts like Racecomps are slotted to allow for additional camber adjustment. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Racecomp Engineering (05-16-2017), StraightOuttaCanadaEh (05-16-2017) |
#40 | |
Yeah our coilovers have the lower mount slotted so you can get some adjustment there too. But factory struts and Bilsteins are not. - Andrew |
#41 |
Drives: 2014 GT86
StraightOuttaCanadaEh: take note, that camberbolts - for front. There is way to adjust camber in rear with excentric bushings, but it is PITA and lot of work (they charge for) for shop. So in addition to camberbolts for front, for rear get LCAs. Eg. cheapest/stock alike - SPC.
#42 | |
Wes
| RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 589 | 11-21-2021 04:13 PM |
| ***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 208 | 09-30-2016 03:43 PM |
| rce tarmac 0 or 2 ? | FISHBURGLAR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 01-06-2015 11:58 AM |
| Tarmac r40 | ikeryder13 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-19-2014 06:13 PM |
