Drives: Silver Ignit10n
Radium Dual Catch Cans on NA setup
Hello,
Are there any negative effects of installing the dual catch cans on a NA setup? Or should I just go with the 1 catch can on the PCV side till I am boosted? Thank You |
#2 |
Drives: Raven FR-S
There's no negative, but no real point either.
#3 |
@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
While I whole heartedly agree theres no negative, I disagree to say there's no point. I run one on the PCV side, and you wouldn't believe the crap that gets built up in there. Certainly not as much as there could be if I was FI.. but even N/A theres a lot of crap that gets trapped in that can - I'm happy I have one. Sent from my iPhone using Tapatalk
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
| The Following 3 Users Say Thank You to brzzy For This Useful Post: |
#4 | |
Drives: Raven FR-S
He asked about dual. Yes a single is good. I run one as well. No point in the second one. Hell there are even guys on here that run a second while boosted and don't get anything with it. |
#5 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
So the only negative would be cost and something else to keep your eye on and maintain. I would certainly recommend one (or 2) though, when going FI. |
#6 |
Drives: 2017 manual BRZ
I'm NA and the PCV can catches loads of crap that I'd rather not be in the intake manifold and heads. Also the more blowby gets into the combustion chamber the less room there is for air and fuel.. rather have a can than not.
Sent from my Pixel XL using Tapatalk |
#7 |
Drives: 2014 Toyota GT86
Mine NA with dual can setup , the PVC can catch a lot , 2 track day can mix out the can , the other side catch nothing .
#8 |
Ohne Titel
Drives: 2017 BRZ PP ISM
NA with Radium on the PCV side. I catch a small amount of blow by - definitely enough to where I'm glad I got this thing.
| Radium Catch Cans | zypher | Engine, Exhaust, Bolt-Ons | 7 | 12-28-2016 07:34 PM |
| Radium Engineering Catch Cans | FRS2000 | Engine, Exhaust, Transmission | 111 | 03-02-2016 12:49 AM |
| FS: Jackson Racing SC kit, brand new blower + Radium Dual Catch Cans | autograph | NY / NJ / CT / PA | 6 | 10-29-2015 09:06 PM |
| Radium Dual Catch Cans with AVO kit & RHD | Skorov | Forced Induction | 6 | 04-08-2015 11:22 PM |
| Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? | OICU812 | Forced Induction | 7 | 10-14-2014 12:36 AM |
