Old 05-13-2017, 08:06 PM   #1
xstatic
Drives: Silver Ignit10n
Radium Dual Catch Cans on NA setup
Hello,
Are there any negative effects of installing the dual catch cans on a NA setup? Or should I just go with the 1 catch can on the PCV side till I am boosted?
Thank You
xstatic is offline   Reply With Quote
Old 05-13-2017, 08:22 PM   #2
Rougenite
Drives: Raven FR-S
There's no negative, but no real point either.
Rougenite is offline   Reply With Quote
Old 05-13-2017, 08:38 PM   #3
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
While I whole heartedly agree theres no negative, I disagree to say there's no point.
I run one on the PCV side, and you wouldn't believe the crap that gets built up in there. Certainly not as much as there could be if I was FI.. but even N/A theres a lot of crap that gets trapped in that can - I'm happy I have one.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
The Following 3 Users Say Thank You to brzzy For This Useful Post:
Drakiv (05-14-2017), Somerandom18 (05-13-2017), xstatic (05-13-2017)
Old 05-14-2017, 02:52 AM   #4
Rougenite
Drives: Raven FR-S
He asked about dual. Yes a single is good. I run one as well. No point in the second one. Hell there are even guys on here that run a second while boosted and don't get anything with it.
Old 05-14-2017, 08:06 AM   #5
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by xstatic View Post
Hello,
Thank You
I installed the PCV side only, almost a year before going FI....didn't catch squat. After 8 months of running the Edelbrock kit, emptied maybe 1/2" of liquid from the can. Just for reference, I put about 10k miles per year on my car and I use the whole RPM range! YMMV. Each engine and setup is different, some will have more blow by than others.
So the only negative would be cost and something else to keep your eye on and maintain. I would certainly recommend one (or 2) though, when going FI.
BirdTRD is offline   Reply With Quote
Old 05-14-2017, 09:48 AM   #6
Somerandom18
Drives: 2017 manual BRZ
I'm NA and the PCV can catches loads of crap that I'd rather not be in the intake manifold and heads. Also the more blowby gets into the combustion chamber the less room there is for air and fuel.. rather have a can than not.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 05-14-2017, 12:53 PM   #7
kingkenny
Drives: 2014 Toyota GT86
Mine NA with dual can setup , the PVC can catch a lot , 2 track day can mix out the can , the other side catch nothing .
kingkenny is offline   Reply With Quote
Old 05-14-2017, 01:31 PM   #8
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
NA with Radium on the PCV side. I catch a small amount of blow by - definitely enough to where I'm glad I got this thing.
TofuJoe is offline   Reply With Quote
Radium Catch Cans zypher Engine, Exhaust, Bolt-Ons 7 12-28-2016 08:34 PM
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 01:49 AM
FS: Jackson Racing SC kit, brand new blower + Radium Dual Catch Cans autograph NY / NJ / CT / PA 6 10-29-2015 10:06 PM
Radium Dual Catch Cans with AVO kit & RHD Skorov Forced Induction 6 04-09-2015 12:22 AM
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? OICU812 Forced Induction 7 10-14-2014 01:36 AM
