Old 05-08-2017, 03:26 PM   #2745
renfield90
The Stig's German cousin
Originally Posted by M0nk3y View Post
No FRS related, but on my 128 when I just replaced the transmission bushings with 80A polyurethane, it sounded like a straight cut gear Porsche whine, and on decel the whole car would shake. It really ruined the DD aspect of the car.
But I didn't have 2nd gear denial from 3rd on a loaded turn so there is that...
Thanks. Shaking car would suck for sure. I am tempted to be the guinea pig who tries the solid mounts though. Best part is they won't need maintenance...
Old 05-08-2017, 03:34 PM   #2746
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
BTDT
While the part itself may not need "maintenance", the rest of the shaking car will have bolts loosen or cracks developing, etc...
Definitely lowers the driving experience down to annoying lol...
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
The Following User Says Thank You to oinojo For This Useful Post:
strat61caster (05-08-2017)
Old 05-08-2017, 06:19 PM   #2747
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
On at least one occasion, I started slamming the shifter into random spots and did find second, but it was way to the right of where it should've been. So something is moving around. I agree, the mount probably did not go bad overnight, they screwed something up (maybe rear shifter bushing? I didn't look there so I'll check tonight). But stiffening the mount should prevent movement regardless of what they screwed up.
Do you have a short shifter? The TRD one came loose real easily and had similar symptoms to what you describe. Could be shift bushing or spring got screwed up or even left off.
ineedyourdiddly
Old 05-08-2017, 10:05 PM   #2748
cjd
cjd's Avatar
Drives: 2017 BRZ
Thanks for the detailed response. One question, when you said "both" diff bushings, are you talking both of the cradle mount inserts or did you also add something like these? http://www.ft86speedfactory.com/whit...l#.WRCd_8tlDqA
These are full replacement, so we'd have to be careful with metal content. From the under car videos I've seen it seems like most of the movement is in the cradle bushings anyway.
The ones at the back of the diff, and the outriggers. I only used inserts, not replacements. I said both because people like @DocWalt have only used some of them due to noise, but I guess that was probably confusing.
If the engine mounts weren't such a pain, I'd be tempted to try the Perrin version, but not sure I want to try that install again any time soon. Good 'nuff.
I'll also second the thought that nothing you can do with bushings will help. Any other options for places to take the car? I'd hesitate to put bushings on the chance the shop DID screw it up, and the bushings end up being blamed (even though they weren't there at the time...) Probably had a kid that didn't know how to drive stick moving the car and bent a fork. The ONE time I stopped for the free (touchless) car wash the poor kid came in and the service manager took it through, but he was so pissed... and I realized it wasn't worth the free cleanup. I was also getting stuff to do an oil change, so wasn't a wasted trip, but... oy.
C
Old 05-10-2017, 03:53 PM   #2749
ryan t
Drives: frs
is anyone running oft/ofh? building my car this year and wondered if i would be to far off on power with the combo compared to a custom tune. closest tuner is 3 hours away.
ryan t is offline   Reply With Quote
Old 05-10-2017, 04:14 PM   #2750
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
You mean OFT with an OTS map? It should be pretty close, but not as good as a custom tune of course.
I ran OFT on my FRS, even with the OTS map for a while. But we eventually dyno tuned it. Same power as my 2017 with ECUtek.
justinco is offline   Reply With Quote
Old 05-10-2017, 04:23 PM   #2751
ryan t
Drives: frs
Yes the ots tune for the ofh.
Old 05-10-2017, 04:54 PM   #2752
ein86
I hit cones.
Drives: 2015 FRS
I'm running an ots oft map with a JDL header, good enough to win Dixie this year. Planning to get a custom tune this summer and ditch the oft though...
ein86 is offline   Reply With Quote
The Following 4 Users Say Thank You to ein86 For This Useful Post:
cjd (05-10-2017), justinco (05-10-2017), ryan t (05-10-2017), strat61caster (05-10-2017)
Old 05-11-2017, 11:27 PM   #2753
renfield90
Update on my drama: took it back to the dealership and I'm glad I did. There is a plate that sits on top of the transmission/under the console that helps line up the shifter. On Toyotas, this plate locks into place and there's basically only one correct position for it. On Subarus, this plate can slide around and must be positioned correctly or there can be shifting problems.
Thanks to everyone who had advice. Car shifts great now.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
cjd (05-11-2017), strat61caster (05-12-2017)
Old 05-11-2017, 11:32 PM   #2754
renfield90
With JDL UEL, muffler delete, and OFT OTS tune my car ran 14.49@95MPH at 1200' elevation. YMMV.
I do plan to get a dyno tune this year if budget allows, but it's probably last on the list.
Old 05-13-2017, 01:27 PM   #2755
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I know it has been talked about in the past on here but did we come to an official interpretation about Launch Control as available on OFT? Have my first ProSolo next weekend and don't wanna be that guy.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 05-13-2017, 01:32 PM   #2756
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
You don't really need launch control, if that makes the decision easier
What interpretation are you talking about? If you have launch control you can use it in ST, unless I am missing something.
Old 05-13-2017, 02:10 PM   #2757
strat61caster
Now that I know how oft launch control works I think it's fine since it's just a rev limiter that gets released at a certain speed. I think you could be all nitpicky and call it a modification of traction control (explicitly not allowed) since it's pulling wheel speed data, but it's not doing anything advanced like calculating speed differentials between wheels or anything.
I bet if there's someone old school running the event there could be a hubbub, but meh.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
justinco (05-13-2017), Silver Ignition (05-13-2017)
Old 05-13-2017, 02:12 PM   #2758
Silver Ignition
APEXHNTR
I remember someone wondering if it'd be ST* illegal due to the phrase "Traction Control Parameters may not be altered" in 14.10.F
I just want to make sure I'm adhering to all the rules.
(not that anyone protests DFL anyways...)
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
strat61caster (05-13-2017)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
