Old 05-10-2017, 08:50 PM   #15
VABeachBRZ
Originally Posted by gtengr View Post
Speak to Jackson Racing and CSG directly. I've been on a c38 with ZERO issues.
VABeachBRZ is offline   Reply With Quote
The Following User Says Thank You to VABeachBRZ For This Useful Post:
CSG Mike (05-14-2017)
Old 05-10-2017, 08:55 PM   #16
VABeachBRZ
Didn't read it all the way, I apologize. If you are running stock fueling and reg gas, then yes the c38 isn't the best option.
Old 05-10-2017, 09:06 PM   #17
bfrank1972
Drives: 2013 FR-S Argento
I wonder if the C38 will produce less heat than a C30 all other factors remaining the same...
Old 05-11-2017, 07:40 PM   #18
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Yea, All of that is completely false.
JDMChris is offline   Reply With Quote
Old 05-11-2017, 07:44 PM   #19
JDMChris
Drives: 2016
This is also false. The C38 works great on stock fueling. The Benefit of the C38 is the overhead. It has more overhead so you can add more boost. On the standard pulley the perform just the same.
Old 05-12-2017, 09:12 AM   #20
Storm_Trooper
Good morning guys
I've been researching FI for a while now and believe I'm leaning towards this SC kit. My vehicle is pretty much stock save for a 93 octane OTS tune on the OFT. I figured this kit is a more reliable FI option and I'm not looking for anything crazy as I'm not going to track the car.
I wasn't planning on upgrading the exhaust anytime soon either. My question is, would the C30 or C38 kit be better for my application? Also, is there an OFT OTS tune available for this SC or should I sell it and go with the factory ecutek option?
Thanks!
Storm_Trooper is offline   Reply With Quote
Old 05-12-2017, 10:49 AM   #21
shakil229
Drives: Scion FRS 2016
So I spoke to Jackson Racing and they said that it would be better to do the C38 with the HBP, because on the C30 the HBP is running the C30 to its maximum which can be dangerous but with the C38 it's not running it to it's max. Just as long as i fill it with 93+ octane, get new fuel injectors and a new fuel pump it should be fine.
shakil229 is offline   Reply With Quote
Old 05-12-2017, 10:51 AM   #22
shakil229
@Storm_Trooper The C38 and C30 produce the same power, the C38 is just better to get if you plan on replacing your engine in the future, and it's not much more. When I spoke to jackson racing, they said it's better to go with the C38.
Old 05-12-2017, 11:08 AM   #23
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
"dangerous" in what sense?
Sleepless is offline   Reply With Quote
Old 05-12-2017, 12:31 PM   #24
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Originally Posted by Storm_Trooper View Post
Good morning guys
Thanks!
It is not dangerous to run the High Boost Pulley on the C30, you may have slightly misunderstood. The reason we recommend the C38 with the smaller pulley, is the C38 isn't working as hard to make the boost, therefor there is less stress on the C38 unit.
With that being said, we have many customers with the C30 and High Boost Pulley that are running reliably.
Jackson Racing Staff
-Chris
Jackson Racing is offline   Reply With Quote
The Following User Says Thank You to Jackson Racing For This Useful Post:
Sleepless (05-12-2017)
Old 05-12-2017, 12:32 PM   #25
bfrank1972
I imagine it means generating much more heat than a C38, outside of the compressor's optimal efficiency envelope
Old 05-12-2017, 07:01 PM   #26
gtengr
Drives: 2017 BRZ
I'm on board with you now. Just remembered reading that from D-Tuning and figured I didn't need to research any further. After reading further, it's a bit odd that they even offer the C30 anymore. $100 is a pittance with FI and should be easily made back in better resale on a C38 kit.
gtengr is offline   Reply With Quote
Old 05-12-2017, 09:32 PM   #27
JDMChris
Drives: 2016
No.
Old 05-12-2017, 09:41 PM   #28
bfrank1972
No.
lol thanks for your expert opinion
Sent from my SM-N920V using Tapatalk
forcedinduction
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
FS (NY): Jackson Racing SC (c30) dp1 Engine, Exhaust, Bolt-Ons 12 04-21-2016 06:37 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Cusco Supecharger kit with water cooling Thongpocket Forced Induction 1 09-23-2013 12:54 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
