Old 05-12-2017, 06:25 PM   #29
johan
Drives: '14 981CS, '99 NB1
I saw this today, and it got me thinking:
Article: http://www.autoguide.com/auto-news/2...ng-around.html
Even taller, with adjustable angle? I think being able to change the AOA would be excellent.
johan is offline   Reply With Quote
Old 05-12-2017, 06:36 PM   #30
johan
The other thing I have had on my mind for this spoiler, a gurney flap. Connect it via the posts and the outer screws, if it was a rigid enough material, it should stay in place really nicely.
Old 05-12-2017, 10:51 PM   #31
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
So funny, I saw that too and then realized the straight spoiler width wasn't going to be an issue (I thought it might be too chunky at first)
The issue with being taller, is that the side panels that sit perpendicular to the wings are really kinda small. So the taller you go with the spoiler, the more awkard they look. As a phase 2 I could also produce larger side panels to go with the larger height, similar to the Subaru BRZ Sti Concept.
I also want to make sure it still has the OEM look to it, as if it came from factory.
Adjustable angle would be a cool idea - same with the gurney flap. I think I'm gonna just start with the simple extension, get a feel for the process of producing the part and then go from there. These are really good ideas for future variations.
Drambeenie is offline   Reply With Quote
Old 05-13-2017, 11:42 AM   #32
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Originally Posted by Drambeenie View Post
Here is what the 2.5x looks like from the back (roughly)
I was all for this until i saw the render, IMO the wing itself is so thin and skimpy it looks a little funny at the height of some of the other monster wings on the market. Its more suited to be tucked in tight to the body.
I see what your doing, its an easy (cheepish) little thing to customize the wing you were already given. who knows maybe ill change my mind once i see the final products. hope you carry this out! subd
VIP BRZ is offline   Reply With Quote
Old 05-13-2017, 12:24 PM   #33
Drambeenie
Drambeenie's Avatar
Here's what 2x height (roughly) looks like. Thoughts?
Old 05-13-2017, 01:02 PM   #34
VIP BRZ
VIP BRZ's Avatar
Not as bad at x2 height
here's what i would do if i was designing this project.
Id have some metal bracket type mounts CNC cut, rather then the 3d printed towers. these could be made to be structurally sound for sure, and match the thickness of the wing better. something like this.
The Following User Says Thank You to VIP BRZ For This Useful Post:
Drambeenie (05-13-2017)
Old 05-13-2017, 03:52 PM   #35
Drambeenie
Drambeenie's Avatar
I see what you mean. That would be a much more aftermarket look.
The challenge with even doing something simple CNC'd out of metal, is that the pylons don't sit flat. So the bottom, where they're attached to the trunk tilt on an angle and the length of them has an S-curve. The mounting points at the top is at another angle. The wing, though it looks like it's completely flat, actually curves. When you sit it on the floor, the sides very slightly curve downwards. Not saying what you want to do isn't possible, just that a flat piece of metal would need to be bent in a precise way to line up with the factory hardware and not have any gaps.
Another possibility to increase the height of the wing while keeping it proportional, would be to create larger side winglets that attach to the ends of the wing.
Old 05-13-2017, 06:29 PM   #36
Drambeenie
Drambeenie's Avatar
Further disassembled the Pylons.
Old 05-13-2017, 09:31 PM   #37
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Looking forward to see what you come up with. Sub'd
derekbrz24 is offline   Reply With Quote
The Following User Says Thank You to derekbrz24 For This Useful Post:
Old 05-13-2017, 09:39 PM   #38
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm liking the x2 height.
Everytime I see the word pylon in here though...
The Following 5 Users Say Thank You to Andrew025 For This Useful Post:
Drambeenie (05-13-2017), Elliotw (09-28-2017), spike021 (05-14-2017), tony-brz (05-13-2017), weederr33 (05-14-2017)
Old 05-14-2017, 04:14 AM   #39
spike021
spike021's Avatar
For this black one I think the pylons end up looking way too thick compared to the spoiler itself. Kind of screws up the balance piece to piece, appearance-wise.
spike021 is offline   Reply With Quote
Old 05-14-2017, 09:14 AM   #40
Drambeenie
Drambeenie's Avatar
This is great feedback. This mockup uses the straight sketch design. Perhaps the curved or vertical design would suit better given their thinner profile.
Old 05-14-2017, 11:22 AM   #41
Gunman
Drives: 2019 Mazda Miata RF
Project is pretty cool. Is the goal form, or function?
Old 05-14-2017, 12:32 PM   #42
Drambeenie
Drambeenie's Avatar
Mostly just for looks, but want to make sure it's structural and won't fly off and decapitate someone. We're going to try and use as much factory hardware as possible.
removal, spoiler, trunk, wing
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-09-2017 11:31 PM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) — General Topics 9 07-18-2016 10:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 10:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) — General Topics 15 08-21-2013 10:58 PM
