#295 | |
Drives: 2016 FR-S 6MT Oceanic
I get most tires at cost, so I'm afforded that luxury. But wheels were a different story. I bought the Konig Hypergrams because of cost/weight ratio, and was going to wrap them in Firestone INDY500 to save initial $$. Until... |
#296 | |
Although having drivin a couple FR-S with them installed I must say it is well sorted. I'd just feel comfortable if I had the ability to adjust stiffness. I guess it helps I can get all TRD stuff dirt cheap... but I still have reservations. |
#297 |
Drives: 2013 Subaru BRZ
If I may suggest you select the front bar with the rate you like and fit an adjustable rear bar. The changes you are likely to want to make are probably best made to rear roll rate.
Additional front grip is easily achieved by fitting camber adjustment. Either crash bolts or camber plates depending on how much negative front camber suits you. In my experience this chassis is limited by rear grip. Most aftermarket setups add front roll stiffness either by higher rate springs or roll bar. I did the opposite by fitting softer 2017 rear springs to achieve more relative front grip. The 20 mm front bar also pushed roll stiffness forwards. . My car has a Supercharger and benefits from less roll stiffness at the rear. Increasing roll stiffness also reduces grip delivered by the inside tire in favour of increasing grip of the outside tire. The Torsen differential is not quite the same as a clutch type LSD and only works well if both drive wheels have solid road grip. |
#299 |
Drives: 2019 WRX
Interesting .. This right here explains one issue I ran into after I put on new tires.. hopefully the bushing kits I ordered can somewhat sort this issue umong others.
| The Following 2 Users Say Thank You to JMon85 For This Useful Post: | Racecomp Engineering (05-10-2017), Somerandom18 (05-10-2017) |
#300 |
Stickier tires increase the maximum possible loading on the chassis bushings. The sloppy feeling also comes from the rear dampers being too soft for the stock rear springs. Bilstein B6 help a lot there. The front struts are ok from the factory so fitting Bilstein B6 to the front isn't really essential. I did this in two steps just to see what the effect of rear Bilsteins only would be. If budget is tight just do the rears first. The BRZ handles well with this set up.
A 20 mm front bar helps tighten up the front end as you turn in although since Whiteline also supplied me with poly bushes and beefy drop links to go with that bar it may be that most of the effect comes from those better components. Finally, MCA traction brackets are amazing. The reduction in anti squat jacking forces which otherwise move the rear suspension around as you corner is impressive. Also, wheel hop is eliminated by fitting these brackets. They give the geometry this car should have from the factory. Bonus, they drop the trailing arm connection point level with the rear subframe bushings so ground clearance is not affected. Good in winter. About a 2 inch drop in the front mounting point for the trailing arms is a lot to achieve and it works extremely well. |
#301 | |
Drives: 2013 BRZ 6MT
front non-adjustable swaybar -- BSF45 (20mm) [stock is 18mm] rear adjustable swaybar -- BSR53Z (16mm) [stock is 14mm] rear swaybar mount support brackets -- KBR38 rear subframe inserts -- KDT921 and KDT922 positive shift kit, transmission insert -- KDT926 steering rack bushings -- KSR210 trailing arm front bushings -- W63414 rear differential inserts -- KDT925 toe control arm inner bushings -- SPF3099K rear lower control arm inner bushings -- SPF3106K camber bolts -- SPC81305 Also, the alignment helped as well - stock settings had slightly positive camber up front. The NVH increase is there but not terrible and not a big deal for me. The car has less body roll and feels more precise, with much less understeer. At the track it is fairly neutral, with just the slightest understeer tendency at the limit. I also now notice during track time that the changes highlight the stock springs and especially dampers -- it could use a bit more of each. But that's only really a concern at the track; for street and backroad driving it's fine. |
| The Following User Says Thank You to PWBRZ For This Useful Post: | SkyeHack (07-06-2018) |
#302 |
Do you still notice an odd side to side sway from the rear axle under hard cornering in a fairly tight bend?
I did until I fit the MCA traction brackets. That cured that completely. I recommend a set of Bilstein or Sachs struts and dampers. The stock dampers are too soft, especially at the rear. . |
#303 | |
Custom User Title
Drives: Asphalt FR-S MT
| The Following User Says Thank You to boredom.is.me For This Useful Post: | JMon85 (05-11-2017) |
#304 |
Drives: 2019 WRX
#305 | |
The MCA brackets drop the trailing arm pickup point by 53 mm (2 in). This reduces the static angle of the trailing arm from 3 in slope to 1 in, equivalent to a two inch spring drop with no camber changes. Dropping the trailing arm pickup point pushes the bottom pivot point of the rear hub backwards which should increase static toe in a toe in direction. Factory rear toe setting is around zero. Suspension compression initially toes the rear out. Dropping the angle of the trailing arm at static ride height will likely eliminate or substantially reduce this initial toe out movement. If so then these brackets will eliminate that odd swaying feel to the rear axle as the cornering load increases. That's been my experience I'll try this again tomorrow on one of our very entertaining off ramps. |
#306 |
Bump.
One other thing I'm not sure is emphasized here is that there are a couple things you can do to these cars that seriously change the handling/driving feel WITHOUT lowering the car, if that's your thing. - Andrew |
#307 | |
Drives: Silver FR-S
Sent from my iDroid |
#308 | |
Drives:
Coilovers that don't lower your car! A little front camber, a lot of front camber, other alignment related... Driving practice, driving courses. This is by far the most effective. Sent from my SM-G930W8 using Tapatalk |
| The Following User Says Thank You to N234 For This Useful Post: | Jajanken86 (11-06-2018) |
| BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 06:18 PM |
| step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 10:44 AM |
| [StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:38 AM |
| [StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
