Old 05-10-2017, 08:47 AM   #1
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Question Drambeenie Risers MEGATHREAD.
FT86SpeedFactory are now selling the Drambeenie Risers!! Check it out!
http://www.ft86speedfactory.com/dram...17-86-brz.html
_______
ORIGINAL POST
I removed my spoiler but the green pop clips didn't come along with it. I tried pushing in the sides but it's difficult because the other flap is inside of the trunk. This spoiler is different than the prior years.
Thoughts? First image is inside of the trunk opened, second is ontop of the trunk. Black oval is a decal I put to cover the hole.
Drambeenie is offline   Reply With Quote
The Following User Says Thank You to Drambeenie For This Useful Post:
ROFL it's Waffle (02-21-2020)
Old 05-10-2017, 09:35 AM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
You selling the 2017 spoilerr?
Old 05-10-2017, 11:44 AM   #3
Gunman
Drives: 2019 Mazda Miata RF
Looks like you pinch the clip on the inside, and push it out of the car.
Old 05-10-2017, 11:47 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Yeah try using a flathead to push in the tabs and remove the clip.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-10-2017, 12:33 PM   #5
Drambeenie
Drambeenie's Avatar
Originally Posted by Summerwolf View Post
You sellibg the 2017 spoilerr?
No, I'm disassembling the spoiler - Going to 3D print larger pylons so that the wing sits higher.
Ok I just tried that. Half of the clip seems like it's coming out but there's another tab on the underside of the green piece that I can't reach due to the trunk hole size and clip placement. Suggestions?
Old 05-10-2017, 12:34 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Originally Posted by Drambeenie View Post
Ok I just tried that. Half of the clip seems like it's coming out but there's another tab on the underside of the green piece that I can't reach due to the hole opening size and clip placement. Suggestions?
Can you twist the cap so the other tab faces you?
Current DD: M235i
Old 05-10-2017, 01:05 PM   #7
Drambeenie
Drambeenie's Avatar
Unfortunately I can't. The clips are rectangular and require both flaps (or pins) to be pushed in to be removed.
I'll try using my pic tool and see if it'll get to the underside and fit.
Old 05-10-2017, 01:17 PM   #8
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Pic tool was going to be my suggestion.
Also, subscribed for pics of finished product. If it looks good, there could be a market for it
trippinbillies40 is offline   Reply With Quote
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
Drambeenie (05-10-2017), Menashe123 (09-20-2017)
Old 05-10-2017, 01:25 PM   #9
Drambeenie
Drambeenie's Avatar
Will do! I'm also excited to make it and see what the finished higher spoiler looks like.
Old 05-10-2017, 03:08 PM   #10
Summerwolf
Panda Trueno
Summerwolf's Avatar
Oh. That sounds.....interesting.
The Following User Says Thank You to Summerwolf For This Useful Post:
Old 05-10-2017, 03:33 PM   #11
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
!!!!!!! ive been thinking about how someone should do this since i got the car, i cant wait to see how it looks
tacos is offline   Reply With Quote
The Following 2 Users Say Thank You to tacos For This Useful Post:
Old 05-10-2017, 05:25 PM   #12
spike021
spike021's Avatar
Will whatever you print be durable enough to be back there?
spike021 is offline   Reply With Quote
Old 05-10-2017, 06:22 PM   #13
Drambeenie
Drambeenie's Avatar
Yes. We're going to be using industrial 3D printers. This isn't a HomeKit 3D printer. There are many 3D printing processes and machines and materials. We'll test the parts thoroughly and build it for structural considerations. Given the amount of wind resistance that can be generated at high speeds, we'll be very thorough.
My cousin is a robotics engineer so we're going to make sure it's structurally sound, sturdy, durable and most importantly safe!
spike021 (05-10-2017)
Old 05-10-2017, 06:27 PM   #14
Gunman
Needle nose pliers won't fit up in there?
removal, spoiler, trunk, wing
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-09-2017 11:31 PM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) — General Topics 9 07-18-2016 10:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 10:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) — General Topics 15 08-21-2013 10:58 PM
