Old 05-09-2017, 09:28 PM   #1
HachiRolle
Drives: 2017 Toyota 86
2017 aftermarket steering wheel horn question
hey everyone,
i recently installed a works bell short hub in my 2017 86. the only connector that fit within the clock spring was the one with the black wiring, however when i connected the horn it did not work. from looking over other diy's, it seems like the red harness was used.
does anyone else have experience in installing an aftermarket wheel in the 2017s? or have a pinout for the clock spring for which pins are for the horn? i'm a bit stumped at this point
HachiRolle is offline   Reply With Quote
Old 05-10-2017, 06:06 AM   #2
HachiRolle
nevermind, figured it out.
this is the harness from the oem 2017 steering wheel:
the wires in the blue loom are for the audio controls. the bottom (blue wire) is for the horn, and the remaining loom is for the cruise control.
the black connector included in the works bell kit is the correct plug for the 2017 clock spring (for the 86, at least). however, it is pinned incorrectly. the top left pin in this photo needs to move down to the bottom left pin slot:
once repinned, the horn worked just fine. as many of the other diy's mention, some horn buttons ground themselves such as the vertex seven star i installed. hook up the single repinned spade connector and everything should work.
picture after finishing my install with the black downstar bolts:
hope this helps someone out in the future!
p.s. aside from the connector, the install is almost identical for removing the airbag off the 2017 steering wheel. however, instead of visible holes to release the pins/clips for the airbag, there are two side covers on the steering wheel itself that can be removed with a flathead to gain access to the pins/clips.
The Following 2 Users Say Thank You to HachiRolle For This Useful Post:
Joveen (01-17-2019), SuperTom (07-07-2018)
Old 05-13-2020, 02:53 PM   #3
DonnyDang
Drives: 2018 GT86
I know this is an old thread, but how do I make the horn work without losing my switch controls, I have the 2018 GT86 so I need to maintain my oil temps thru the switch controls on the wheel, but the wiring that came with the worksbell hub/quick release deletes the switches
DonnyDang is offline   Reply With Quote
Old 02-03-2022, 05:50 PM   #4
Kimchi86
You're either gonna need this
https://www.geraldjustprojects.com/p...r-kit-4-screw/
Or
https://www.blackhawkjapan.com/produ...s-bell-542ssts @DonnyDang
Kimchi86 is offline   Reply With Quote
Old 03-26-2022, 03:42 AM   #5
suhal
Drives: BMW
The 2018 Toyota 86 ranks near the bottom of the sports car class. Despite its deft handling and good predicted reliability rating, it lacks the modern amenities found in most rivals..
suhal is offline   Reply With Quote
Old 03-26-2022, 10:22 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
spam reported
Tcoat (03-28-2022)
Old 03-26-2022, 10:06 PM   #7
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
what is this horseshit?
SuperTom is offline   Reply With Quote
Old 03-26-2022, 10:58 PM   #8
soundman98
soundman98's Avatar
hover your mouse over the last period. it's a spam link
SuperTom (03-27-2022)
Old 03-26-2022, 11:04 PM   #9
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Good catch there, Soundman!
LimitedSlip is offline   Reply With Quote
Old 06-20-2022, 07:30 AM   #10
sthen
Drives: GR 86
Helped me a lot. Thanks
Regards, Steven_lax
sthen is offline   Reply With Quote
2017 Steering Wheel Irace86 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-16-2017 01:21 PM
Horn wiring for aftermarket wheel? acpstunts Electronics | Audio | NAV | Infotainment 0 12-06-2016 12:52 PM
FS: Scion FR-S steering wheel with horn turbos86 Canada Classifieds 0 11-27-2013 12:16 AM
