Old 05-07-2017, 01:59 PM   #1
shakil229
Drives: Scion FRS 2016
Jackson Racing Supecharger
Hi all,
I am looking at buying a jackson racing supercharger for my scion FRS. I want to also do the pulley upgrade, but it says i need a new fuel pump and injectors. Could someone link me some upgrades or help me out with this? I currently fuel my car with 94 Octane.
shakil229 is offline   Reply With Quote
Old 05-07-2017, 02:00 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Did you check the owners thread?
Freeman is offline   Reply With Quote
The Following 2 Users Say Thank You to Freeman For This Useful Post:
rns294 (05-10-2017), VABeachBRZ (05-07-2017)
Old 05-07-2017, 02:29 PM   #3
VABeachBRZ
Originally Posted by shakil229 View Post
Hi all,
If you want to upgrade then get:
JRSC C38
HBP
DW 700cc Fuel Injectors
DW 300 Fuel Pump
Flex Fuel kit
Clutch (to hold the power)
Clutch fork (while you replace your clutch, you may as well)
Edit: make sure you use a reputable tuner.
VABeachBRZ is offline   Reply With Quote
Old 05-07-2017, 02:42 PM   #4
shakil229
@VABeachBRZ I drive an automatic so I wouldn't replace the clutch
Old 05-07-2017, 10:05 PM   #5
zypher
Drives: WR Blue BRZ
JRSC C38
HBP
DW 300 Fuel Pump
Flex Fuel kit
DO NOT use the HBP with the C38 unit. Unless you have a built engine with forged internals.
The C30 supercharger with a HBP is fine for stock engine, but you are pushing it.
Running a HBP on 94 is ok.... its not ideal, E85 is recommended with the HBP
zypher is offline   Reply With Quote
Old 05-07-2017, 10:25 PM   #6
shakil229
@zypher So should i just get the C38 unit with no HBP or a C30 unit with HBP?
Old 05-07-2017, 11:37 PM   #7
VABeachBRZ
You can most certainly run the c38 with a HBP. Many people I know personally do and have had ZERO issues. Someone 50k Miles in.
Don't get me wrong, it can be risky. But many many many people do it. And yes having s built motor is always better.
If you look at other applications people are pushing 350-400 on stock motor and running strong. It's all about the upkeep and the driving styles, imo.
The Following User Says Thank You to VABeachBRZ For This Useful Post:
Jackson Racing (05-11-2017)
Old 05-08-2017, 06:37 AM   #8
zypher
Drives: WR Blue BRZ
It depends on your power goals and what you plan to do with your car.
A C38 with a custom tune will be in the 260ish WHP range.
A C30 with the HBP will be in the 300ish WHP, 370 if you run a header and E85.
I strongly recommend reading the owners thread.
Also if you plan to track your car I would get an oil cooler.
I have a C30 running around 250, and tracking the car definitely makes the oil cooler worth it.
Old 05-08-2017, 06:49 AM   #9
Bfranklyn86
Drives: GT86 Harrop S/C
Do these people run e85 though? I think this could be the key difference. OP stated he runs 94, which would be risky taking above 300whp IMO.
Bfranklyn86 is offline   Reply With Quote
Old 05-08-2017, 08:16 AM   #10
VABeachBRZ
Yes we are all on e85. In winter we have some 93 in it tho.
Old 05-10-2017, 02:25 PM   #11
shakil229
@VABeachBRZ So I don't need a flex fuel kit because I don't run E85 correct? Also i'm driving an AT FRS, so I don't need a new clutch or flywheel, but would a High Output Torque Converter be beneficial at all?
Old 05-10-2017, 03:44 PM   #12
gtengr
Drives: 2017 BRZ
My understanding is the C38 is mainly for built engine/E85 users?
gtengr is offline   Reply With Quote
Old 05-10-2017, 05:11 PM   #13
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Not true. In Factory Tuned trim they make the same power as they utilize the same pulley size. The C38 allows you to run all of the Jackson racing configurations (High boost pulley, RS Bracket & Pulley). The C30 can only run up to the High Boost Pulley.
JDMChris is offline   Reply With Quote
Old 05-10-2017, 06:44 PM   #14
gtengr
Drives: 2017 BRZ
http://www.ft86club.com/forums/showp...postcount=1192
forcedinduction
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
FS (NY): Jackson Racing SC (c30) dp1 Engine, Exhaust, Bolt-Ons 12 04-21-2016 06:37 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Cusco Supecharger kit with water cooling Thongpocket Forced Induction 1 09-23-2013 12:54 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
