Old 05-05-2017, 12:02 PM   #127
Yoda
Drives: Crystal Black BRZ(Sophia)
Originally Posted by Kris86 View Post
The tuner also stated that if I do not find any vacuum leaks, then my motor isn't holding compression.
what I find weird is that the car has a wont idle once is cold, I have to keep my foot on the throttle to prevent it from stalling, but once it warms up, it idles perfectly, if I shut off the engine and start back when its hot I don't need to apply any throttle
my mechanic is saying that the piston rings need some more time to be seated and then my compression will go up.
whats you guy thoughts on this?
This brings me back some fond memories of my last turbo project. A sage laid some knowledge on me in its simplest form to help me troubleshoot issues like this. Three things you need to have combustion; spark, fuel, air. If you are sure spark and fuel are good then you can dive into air. Check for vac leaks, check the compression of the engine, check maf and all the way down the tree for air. You will find the problem. I had the opposite of your problem and it turned out to be the fuel pump. Also could be a simply grounding issue. Good luck you are almost there!
Yoda is offline   Reply With Quote
The Following User Says Thank You to Yoda For This Useful Post:
Kris86 (05-05-2017)
Old 05-05-2017, 01:32 PM   #128
Kris86
Kris86's Avatar
Drives: RHD Gt86
we are going to be doing the compression check again tomorrow. putting on the oil pan tonight to let the silicone set properly and then in the morning start it back up and start looking again and spray carb cleaner around and see if I find anything as Justin suggested
could my EBCS be hooked up in a way to cause a vacuum leak? if I remember correctly, the EVAP solenoid is now disconnected and my EBCS is plugged into the plug that the EVAP was once plugged into, also the hose coming from the intake manifold is then plugged into the EBCS. its a three port so one is vented to atmosphere I think.
how do I check my MAF?
Thank you for your support !
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 05-05-2017, 01:42 PM   #129
-Phil
Drives: Rb25 neo brz
Did you preform a leak-down test on the motor before it was installed? If so what was the %?
-Phil is offline   Reply With Quote
The Following User Says Thank You to -Phil For This Useful Post:
Kris86 (05-05-2017)
Old 05-05-2017, 02:03 PM   #130
Kris86
Kris86's Avatar
Drives: RHD Gt86
Yes we did a leak down test, not before but after the motor was installed in the vehicle.
two were 9%
one was 6%
one was 7%gl
Old 05-05-2017, 02:40 PM   #131
-Phil
two were 9%
one was 6%
one was 7%gl
That's fairly normal before the valves and rings seat, i would run the car for a bit and give it a chance to seal up. Let the motor cool and get the number. if those are your numbers after already doing that then its a different story. generally motors we build are 1-2% leak-down while on the engine stand and that drops to 1 or less once the motor is ran.
Kris86 (05-05-2017)
Old 05-05-2017, 02:49 PM   #132
Kris86
Kris86's Avatar
Drives: RHD Gt86
thank you so much for your help, I will relay this message to my mechanic and we will take it from there, I look forward to your continued support
Old 05-05-2017, 04:20 PM   #133
Kris86
Kris86's Avatar
Drives: RHD Gt86
one thing to note tho, I cannot run my car any more than just idling, this is as far as we have gotten with the tuning
Old 05-06-2017, 03:13 PM   #134
Kris86
Kris86's Avatar
Drives: RHD Gt86
Sooo, this is what I've found so far
Not sure if this will cause my vacuum leak issue tho
Old 05-07-2017, 02:51 PM   #135
Kris86
Kris86's Avatar
Drives: RHD Gt86
Looks like we are gonna be pulling the motor :-( @FRS Justin @GsxrMe @Yoda @Moto-Phil
My mechanic thinks maybe the rings could have been cut to wide possibly, so he said he will get the rings and replace them. We have no vacuum leak, we have back check everything possible. We did the compression test and came up with this
Piston 1 - 95
Piston 2 - 90
Piston 3 - 98
Piston 4 - 93
Even though I'm running 9:0:1 compression I shouldn't be seeing such low results
The Following User Says Thank You to Kris86 For This Useful Post:
Yoda (05-08-2017)
Old 05-09-2017, 11:39 PM   #136
Dipstik-sportech
Dipstik-sportech's Avatar
Did you do the compression test on a warm engine with the throttle held wide open? 90psi is barely enough compression too fire off. If your rings were leaking down you would've seen that in the leak down test. Is there a lot of crank case pressure? Is it pushing coolant at all?
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Kris86 (05-10-2017)
Old 05-10-2017, 08:28 AM   #137
Kris86
Kris86's Avatar
Drives: RHD Gt86
no we did the compression test when the engine was cold. just swinging the engine.
not sure about the crank case pressure tho :-S, would you mind explaining to me how to go about checking this?? I have in the Radium DUAL catch can set up, which are vented to atmosphere.
it has not pushed any coolant out what so ever.
ive been suggested that it would either be bent valves ( when engine wasn't timed correctly first) or maybe rings ground to much. :-(
I appreciate your help
Old 05-10-2017, 09:18 PM   #138
Dipstik-sportech
What do you mean by just swinging the engine over?
Izzyboost1 (05-11-2017)
Old 05-11-2017, 08:57 AM   #139
Kris86
Kris86's Avatar
Drives: RHD Gt86
Put my foot flat on the throttle and swung the engine a few revolutions with starter
We did not run the engine and warm it up before doing so
Old 05-11-2017, 01:01 PM   #140
Dipstik-sportech
Take the intake pipe off and hold the throttle open and try again. Make sure you take all the spark plugs out to save your battery.
Kris86 (05-11-2017)
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 07:44 PM
I drive fast because the car feel "slow" fang_gt86 Scion FR-S / Toyota 86 GT86 General Forum 65 05-04-2015 01:06 PM
Most effective ways to make a "fast" NA car Kronos Engine, Exhaust, Transmission 68 02-16-2014 01:59 PM
XSXV: Nissan R34 Skyline from "Fast and Furious" goat_cheese Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 10-25-2012 04:15 PM
come and hoon they say.... it will be "like Fast and the Furious", they say... davey90 AUSTRALIA 5 10-23-2012 12:11 AM
