Old 05-05-2017, 02:20 AM   #15
JAK_SPYRO
JAK_SPYRO's Avatar
Drives: 2017 Subaru BRZ Yellow Series
Originally Posted by arthur93 View Post
Are you worried about blowing axles and gearboxes?
Axles maybe, under pressure and track days they can break. The axles I found are 600 HP ones so that kinda tells me that you don't really have to worry about them. If you look at the Crawford FR-S they built, it has 450 HP and 500 torque and all they did to the car is:
1. New mufflers
2. Built engine
3. Turbo kit
4. Clutch
That's it. I feel like after the 450 mark you'd have to worry about more things.
As for the gearbox, I haven't heard of anyone having trouble with that. Everyone just seem to get stage 2 or 3 clutch kits and call it a day but then they all have 270-350 HP cars. If you get any info on that please let me know 😅
JAK_SPYRO is offline   Reply With Quote
Old 05-05-2017, 02:39 AM   #16
arthur93
Drives: Toyota 86 GTS
Well I know Eric for Velox motorsports runs the full race turbo kit, and he was putting down a tad under 400whp and 320w ft lb. He sheered 4th gear. Here is the link to the page; http://www.ft86club.com/forums/showt...t=gear&page=10
I have read you can get the gearbox cryo treated. Might be worthwhile for you. Guess it more of luck as others are running a lot more power and torque with no issues. Bear in mind Eric's vehicle has had quite a few dyno pulls, so more abuse than the average Joe.
arthur93 is offline   Reply With Quote
The Following User Says Thank You to arthur93 For This Useful Post:
olsonpg (05-05-2017)
Old 05-05-2017, 03:00 AM   #17
JAK_SPYRO
JAK_SPYRO's Avatar
Keep in mind I own the 2017 Limited edition BRZ with the performance package! Subaru upgraded a bunch of things in this car including an aluminum manifold, 4.3 final drive, new valves and camshaft, new exhaust manifold, suspension, aero and chassis upgraded, etc. basically they improved the -2017 models and made it more sturdy for FI. It has 205 HP with 156 torque.
I have yet to see anyone FI a 2017 BRZ/FRS, but I'm assuming everything is a lot stronger and my car is basically brand new still. Since they changed the final drive, each gear gets more torque making them shorter so I'm afraid the extra torque in every gear is gonna cause issues. I'm gonna have to talk to my mechanic where I'm getting all this stuff installed and see what he thinks I should do with the gearbox /:
Old 05-05-2017, 03:03 AM   #18
JAK_SPYRO
JAK_SPYRO's Avatar
To be honest though I have never heard of cryo treatment so I had to look it up, and this actually sounds smart. I like the idea!
http://www.gearsolutions.com/article...ment--of-gears
Old 05-05-2017, 06:04 AM   #19
arthur93
Yeah in theory it sounds very interesting. I have done a bit of research into it and it makes a lot of sense. I have looked at pricing and it has varied significantly from the very cheap to very expensive. I am also considering cryo treatment if I am looking to eventually go about 400whp
Old 05-05-2017, 11:09 AM   #20
PranayP
Drives: LR BRZ| OFT STG2 UEL E85
I would get the Crawford oil catch can, it sends the oil back to the oil pan and you don't have to get 2 oil catch cans cause it protects both sides. Other than that, how much HP are you planning on? I feel like the 600 HP block is a bit of a waste of money cause the stock block is pretty strong. The only reason petiole break the block is because they break pistons and rods which then launch into the block and make a hole. If you upgrade everything in the block then don't even waste $2-3k on a block. Everything else you chose is pretty good quality and yes buying parts individually saves a lot of money
Yea, I'm definetley not going to do a block package. The reason I'm not going for the Crawford AOS is because I've heard some poor reviews on it on how oil leaks into the intake and how it's a bad design. Just search Crawford AOS review and it should be the first to pop up on this site. I've heard nothing but good about the Radium ones though. I'm definetley going to look into engine mounts after reading this thread, but I'm also wondering at what point do we need to upgrade the axles? As far as I've read, doing hard launched all the time breaks your joints, but daily driving seems fine for the stock axle and driveshaft.
PranayP is offline   Reply With Quote
Old 05-05-2017, 11:47 AM   #21
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
I'm running the JRSC on my 17 with PP. Been about 1100 miles since going FI and I'm loving every second of it.
Barefootdan is offline   Reply With Quote
The Following User Says Thank You to Barefootdan For This Useful Post:
JAK_SPYRO (05-05-2017)
Old 05-05-2017, 02:49 PM   #22
JAK_SPYRO
JAK_SPYRO's Avatar
I wouldn't even find anyone around me who would do it 😂 I live in the most boring state
Old 05-05-2017, 02:55 PM   #23
JAK_SPYRO
JAK_SPYRO's Avatar
Yeah the Radium ones are amazing, I haven't seen anyone complain either. I just hate the fact that you have to empty them a lot, but I think I'm going with 2 Mishimoto cans if the Crawford one is causing trouble.
I was watching a video last night and the mechanic said you'd only have to upgrade them if you go drifting or track and just beating on your car launching it 24/7. If you're a normal driver like me and just race people in the streets 😂 You'll be just fine. Although there's a 600 HP axle package on the FT86 site for almost $1k if you want to be safe
Old 05-05-2017, 03:00 PM   #24
JAK_SPYRO
JAK_SPYRO's Avatar
Which year and model of the SC did you choose from their site? Right now the newest they have is 2016 and I emailed them about it and they said that the 2017 version is being calibrated and will be available in the near future! I have been deciding on SC and TC but finally laid my foot down on the FBM Stage 1 Premium TC
Old 05-07-2017, 06:15 AM   #25
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Subbed for info. I'm in the same boat as you, so need to get a list of parts down for a good/reliable build. Getting a closed deck build, so far decided on 10.5CR JE pistons, HKS 1.0mm headgasket, crank is getting oil phased. Anyone got any suggestions for headwork and what specs? thx
stevo_12v is offline   Reply With Quote
Old 05-07-2017, 06:21 AM   #26
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Hey, welcome back. Give us an update of your car when you have time.
internals, pistons, rods, short block, upgrade
Internals Upgrade Question Strife26 Engine, Exhaust, Transmission 12 06-22-2015 09:20 PM
DI pump Internals SkullWorks Issues | Warranty | Recalls / TSB 60 10-30-2014 02:23 PM
Forged internals mikepaul21 Engine, Exhaust, Transmission 7 10-30-2013 10:26 PM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
How about them internals nytfury Engine, Exhaust, Transmission 5 08-27-2012 07:23 AM
