#113 |
Drives: Late 2014 Subaru BRZ
My car idles from 19-20 vacuum at idle. Hows the 2 barbs under the plastic cover on your intake? Do you got those pigs clamped?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#114 | |
Drives: RHD Gt86
yes we have all hoses secured with hose clamps
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#115 |
Drives: RHD Gt86
i was told to make sure i have the one under the intake manifold and behind the aircon compressor secured properly.
thing is that hose runs to one of my radium catch cans and is vented to atmosphere
#116 | |
Drives: 2014 BRZ
http://www.ft86club.com/forums/showthread.php?t=109444 |
#117 |
Drives: 2013 Asphalt FRS
Hey Kris didn't you lower the compression?
for the EXACT same combination of parts...a higher compression motor draws harder on the intake, and thus has more vacuum. the bigger the difference in compression...the bigger the difference in vacuum... 1-2 inches of vacuum per point seems realistic... I would check fuel trims for signs of a vacuum leak not the gauge
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#118 | |
Drives: RHD Gt86
Hey Justin, thanks for the info ! This is what my tuner sent me letting me know I have a vacuum leak "I can see that manifold absolute pressure is at .52 BAR and 18% short term fuel trims. Trims should be close to 0%, and manifold absolute pressure at unassisted idle should be .27-.35 or so with no vacuum leaks."
#119 | |
I know your looking at fuel trims but hows the MAF? Is it solid readings when at idle or is it all over the place?
2014 Subaru BRZ
#120 | |
The only thing I can think of left would be the orings on the bottom of the intake flange, that bolts to the heads.
#121 | |
Drives: RHD Gt86
when I turn the ignition and engine speed at "0" rpms. my MAF reads 0.76 volts. once started and idling on its own it jumps between 1.3 V - 1.4 V the g/s for the MAF jumps between 2.9 g/s - 4.3g/s ( don't know what the hell all that is supposed to mean but hoping you guys will see something unusual @GsxrMe
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 05-10-2017 at 03:09 PM. |
#122 | |
Drives: RHD Gt86
the issues with living on a island in the Caribbean, u cant even get a proper weld done. so tomorrow when the oil pan is back on im gonna be doing what u suggested with the carb cleaner and spraying the said areas
#123 |
At hooters atm, once im home ill pull some logs to compare.
2014 Subaru BRZ
#124 | |
#125 |
Drives: RHD Gt86
So we did the vacuum test with the fancy smoke machine last night, found out my turbo has a very small leaking through the front cover on one particular section, possibly the o-ring that seals the cover. This tho, I don't think will cause my issue at idle. No other leaks anywhere what so ever. USED THE VACUUM FROM THE BRAKE BOOSTER TO DO VACUUM TEST
My tuner sent me this "your manifold absolute pressure at a stable idle should be between .28 and .36 at most. Yours was around .5 or higher, with correspondingly high fuel trims. This indicates a leak. "
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 05-05-2017 at 10:04 AM. |
#126 |
Drives: RHD Gt86
The tuner also stated that if I do not find any vacuum leaks, then my motor isn't holding compression.
what I find weird is that the car has a wont idle once is cold, I have to keep my foot on the throttle to prevent it from stalling, but once it warms up, it idles perfectly, if I shut off the engine and start back when its hot I don't need to apply any throttle my mechanic is saying that the piston rings need some more time to be seated and then my compression will go up. whats you guy thoughts on this?
| Who's tired of the "Pedal Dance" and wants to be in real control of their car? | FT-86 SpeedFactory | Tracking / Autocross / HPDE / Drifting | 61 | 10-01-2015 07:44 PM |
| I drive fast because the car feel "slow" | fang_gt86 | Scion FR-S / Toyota 86 GT86 General Forum | 65 | 05-04-2015 01:06 PM |
| Most effective ways to make a "fast" NA car | Kronos | Engine, Exhaust, Transmission | 68 | 02-16-2014 01:59 PM |
| XSXV: Nissan R34 Skyline from "Fast and Furious" | goat_cheese | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 10-25-2012 04:15 PM |
| come and hoon they say.... it will be "like Fast and the Furious", they say... | davey90 | AUSTRALIA | 5 | 10-23-2012 12:11 AM |
