Old 05-03-2017, 10:13 AM   #15527
piotrr
piotrr's Avatar
Drives: wrb brz
Installed Valenti Euro Winker relay. Install was a freaking pain in the ass, couldn't get that original relay out. Was seconds from going mad and brute-forcing the old one.
[ame="https://www.youtube.com/watch?v=OKu1rc4Tr1Y"]ヴゑレンティ ユーγƒ*ウむンカーγƒͺレー - YouTube[/ame]
piotrr is offline   Reply With Quote
Old 05-03-2017, 06:32 PM   #15528
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Originally Posted by Dan37BRZ View Post
Finished up installing my EB-S/C. Amazing kit, two
What are your wheel specs and suspension setup? Car looks great
derekbrz24 is offline   Reply With Quote
Old 05-03-2017, 06:41 PM   #15529
kch
Senior Misanthrope
kch's Avatar
Originally Posted by bentleyboii View Post
Let me know how they feel, If their that much better than stock etc. Been looking at these for my replacement next go around
They feel like brakes. Any real change in feel is down to pad choice and tires. I got this kit due to its higher heat capacity and thicker brake pads. In theory, it will pay for itself after a lot of track use.
Old 05-03-2017, 07:46 PM   #15530
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Wheels are Enkei NT03+M in limited edition SBC finish. 18x9.5 +40, wrapped in Michelin Pilot Super Sports 245/35/18 all around, finished off with some Project Kics NeoChrome R26 lugs. Sitting on ST-X coil-overs by KW.
Unfortunately they might be for sale soon, they won't clear my Brembo GT BBKs.
Dan37BRZ is offline   Reply With Quote
Old 05-04-2017, 08:56 AM   #15531
bentleyboii
bentleyboii's Avatar
Drives: 2022 GR86
Thanks, I dont know one thing about breaks. lol
bentleyboii is offline   Reply With Quote
Old 05-04-2017, 01:35 PM   #15532
kch
Senior Misanthrope
kch's Avatar
It's okay; they're frequently misunderstood. Lots of people think BBK = more stopping power, but that's not really the case in most situations. If your stock brakes can hit ABS, then they have enough stoppingpower--the limiting factor is the tire, not the brakes. Stickier tire = shorter stopping distance.
The natural first upgrade for performance use is some better brake pads and fluid. "Better" in this case means they have a higher operating temperature and can take more abuse before they fade/boil. With street tires, on most tracks, the OEM brake calipers with good track pads will be sufficient.
The primary reasons to upgrade to a BBK are heat capacity, pad availability, longevity, weight, and decreased caliper flex. For instance, the AP sprint kit caliper is much stronger and more rigid than the OEM calipers. It also accepts larger and thicker pads, meaning they'll last longer. The rotors are vented more for better cooling. And because the rotors are two-piece, the hat can be made of aluminum instead of iron, saving lots of weight.
edit: there are street-appropriate pads that have a higher initial bite than the OEM pads. Something like that might provide the sort of feel you're looking for. Not sure what pads would do the trick, though.
The Following 3 Users Say Thank You to kch For This Useful Post:
bentleyboii (05-04-2017), justinco (05-04-2017), yberther (05-10-2017)
Old 05-04-2017, 02:37 PM   #15533
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Just to add to what kch said, which is all good info. Especially about the tire being the most important part.
I did notice the AP brakes seem to have better clamping power over the stock calipers (not necessarily the same as stopping power). Or, it could be a combination of the caliper and SS brake lines providing improved feel and feedback. But, there is definitely an improved feel in the pedal under hard braking, like the calipers are squeezing a lot harder than the stock calipers (I am using the same type of brake pad and same tires as when they were stock).
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
Old 05-05-2017, 10:21 PM   #15534
Surj_brz
Drives: 2015 BRZ Ltd
I went from stock brakes --> SS lines --> pads --> rotors --> to a BBK
The biggest change is the ability to deal with heat which equates to braking power (ability). My current set up (RR-racing stage II) is not up there like the AP Racing kit but its cost effective and is a massive improvement over stock for the trackday pounding it gets.
Not sure I would have gone down the same route for street use.
2015 BRZ Ltd trackday speciale (eventually) | 2017 BMW M3 Competition Pkg
Gone: 2011 G37S | 2009 WRX Wagon | 1998 C2S garage queen | 2006 Mini Cooper S | 1997 C2S trackday speciale | 1999 ///M Coupe | 1990 E30 ///M3 | 1997 Corvette | 1993 205 1.9 GTI | 1997 328is
Surj_brz is offline   Reply With Quote
The Following User Says Thank You to Surj_brz For This Useful Post:
bentleyboii (05-07-2017)
Old 05-07-2017, 06:44 PM   #15535
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
After waiting for over a month, the car was finally picked up and is on its way to FullBlown Motorsports. I had to call another transport company and cancel with the other one because they weren't doing anything. Luckily I got a full refund. Car will return in about a month.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following User Says Thank You to Drakiv For This Useful Post:
D_Thissen (05-07-2017)
Old 05-08-2017, 08:37 PM   #15536
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Black housing tail lights...thought about doing the DIY but I wussed out and just got the Depos
BRZyJ is offline   Reply With Quote
The Following 7 Users Say Thank You to BRZyJ For This Useful Post:
B-R-Z (05-09-2017), BirdTRD (05-09-2017), Brayden_23 (05-11-2017), Drakiv (05-08-2017), Husker BRZ (05-08-2017), KR-S (05-09-2017), norcalpb (05-08-2017)
Old 05-09-2017, 12:38 AM   #15537
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
I have always loved the look of the stock zenki tail lights; just don't like the chrome. No other aftermarket tail light has ever appealed to me.
I'm seriously hoping that they make a red version as well!
Old 05-09-2017, 01:59 AM   #15538
BRZyJ
BRZyJ's Avatar
Me too, exactly.
I looked at the DIY threads over and over and was thinking I'd buy some used OEM lights and do it...but then I figured I'd most likely destroy a few before getting it right and would have spent around the same amount, lol.
The Following User Says Thank You to BRZyJ For This Useful Post:
KR-S (05-10-2017)
Old 05-09-2017, 01:47 PM   #15539
BxrFnd17
Drives: 2017 BRZ Limited
Installed these last night. OZ Ultraleggera 17x7.5 et35 with 225/45-17 Michelin Pilot Sports.
IMG_20170508_1846083-01 by jakechildress, on Flickr
IMG_20170508_1844503-01 by jakechildress, on Flickr
IMG_20170508_1847456-01 by jakechildress, on Flickr
BxrFnd17 is offline   Reply With Quote
The Following 4 Users Say Thank You to BxrFnd17 For This Useful Post:
BirdTRD (05-09-2017), derekbrz24 (05-09-2017), sprintertrueno86 (05-10-2017), VMRamos (05-12-2017)
Old 05-09-2017, 05:23 PM   #15540
derekbrz24
derekbrz24's Avatar
Are you on stock suspension and what side skirts are those? The wheels look great
