Old 04-21-2017, 04:13 PM   #7911
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Njjawn View Post
I checked the wiring/plug already and all seemed fine. I ordered a new air fuel sensor hopefully that does the trick. Could that be throwing the car into this "limp" mode?
Yes, as it can't trust the output of the O2 sensor.
.: Stealth 86 :.
Kodename 47 DJ:
Njjawn (04-21-2017)
Old 04-21-2017, 07:27 PM   #7912
Njjawn
Drives: None
Beautiful. Thanks guys!
Njjawn is offline   Reply With Quote
Old 04-27-2017, 03:30 AM   #7913
LetterVi
Drives: Toyota Prius
What do you guys recommend me to buy for injectors and fuel pump for the 210?
LetterVi is offline   Reply With Quote
Old 04-27-2017, 12:42 PM   #7914
Njjawn
Drives: None
UPDATE -
Replaced the AFR, drove around for about 75 miles and the CEL remained off.
Still throwing an ABS/Trac light and loosing power.
Old 04-27-2017, 01:14 PM   #7915
Yoda
Drives: Crystal Black BRZ(Sophia)
UPDATE -
Sounds like you are getting closer hang in there guy.
Yoda is offline   Reply With Quote
Old 04-27-2017, 04:27 PM   #7916
Kodename47
Kodename47's Avatar
Drives: UK GT86
That shouldn't be happening. Any codes despite the lack of CEL?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-27-2017, 04:43 PM   #7917
Njjawn
Drives: None
None....
I thought it MAY have something to do with 2 different sized wheels on it, so I threw the stocks on.
Still doing it.
Old 04-27-2017, 05:18 PM   #7918
xjohnx
Grip>Slip
xjohnx's Avatar
stock will be fine.
Old 04-28-2017, 03:40 PM   #7919
-Willis-86touge
Drives: Stock
Has anyone thought about taking the bypass valve out I know gas mileage would suffer but would this add more power down low? And get rid of the hesitation the sprintex unit has? Just curious don't even know if it would work properly and prob need a retune if it did
-Willis-86touge is offline   Reply With Quote
Old 04-28-2017, 03:46 PM   #7920
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Without a built motor I'm not sure if you want more power/torque down low.
I suppose I must be immune to the hesitation. As least on E85, I think the car is perfectly smooth at all RPM, and when clutching in/out.
ajcarson11 is offline   Reply With Quote
Old 04-28-2017, 03:51 PM   #7921
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Same here on 92.
If you want more power down low, use more throttle.
If you use enough, your rods will bend.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 04-28-2017, 05:50 PM   #7922
Kodename47
Kodename47's Avatar
Drives: UK GT86
It would put extra strain on the compressors. It's there for a reason.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-28-2017, 07:22 PM   #7923
stockysnail
Just the tip
stockysnail's Avatar
In my opinion any forced induction system won't be 100% as responsive as a non-forced induction unit all the time. Even non-forced there's a very slight hesitation and that's only as good as your tune.
If you want instant, responsive, gut pulling torque, you sir are looking at an electric car. Nearly all of them will beat all but the most expensive cars off the line. I had an i3 for a while which smoked anything 0-30mph. I sold it because I got smart and decided 2 car payments wasn't financially sound. I think I may wait until the Tesla Model Y if it's a 2 door sports car or maybe the new Supra as I really want an electric sports car. I may just get another i3 as they and all but Tesla's used cars are stupid cheap for what you get. I test drove a couple Tesla's one being the Ludicrous mode equipped and it was like riding a bullet fired from a gun.
Old 05-01-2017, 02:22 PM   #7924
Njjawn
Drives: None
Well, this is embarrassing.
Was finally able to pull a code from the car (not sure why, but it wasn't showing on start up, I had to grab it after running the car).
The code was for a SAS - Steering angle sensor.
Backstory - The car was hit by a fire truck on the drivers side front corner and then went straight into "build" mode, so there was no driving time since it was repaired.
The steering wheel was about 15* off since it came out of the body shop, but it was driving straight enough for me to get some seat time to run through a mechanical testing phase... and I didnt see a point in getting an alignment since I was going to have the car corner balanced on May 11th.
Well, I went and got an alignment and all is good.
UNRELATED -
Has anyone had issues with a JB performance catch can mod on their supercharger? The bottom of my hood has some residual oil shit on it above the catch can. It was installed by JB when the supercharger was undergoing a rebuild.
The Following User Says Thank You to Njjawn For This Useful Post:
CarzCarzCarz (05-01-2017)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
