Old 04-28-2017, 03:23 PM   #1
imnotsureaboutbrz
Drives: between cars...
Silly?: Any use of First gear beyond the launch
While I'm not new to autocross but my first autocross in the BRZ is this weekend. And I was wondering.. for those who have been at it for a while, has/is there ever been a corner or chicago box tight enough where you felt the need to downshift to first, or just 'power' through 2nd? From the videos I've been watching it seems that after the launch everyone just stays in 2nd, unless the course allows 3rd. The courses up here are usually pretty tight.
imnotsureaboutbrz is offline   Reply With Quote
Old 04-28-2017, 03:57 PM   #2
CatDaddysBBQ
Drives: '13 FR-S
In 4 years I have only had one or maybe two courses that actually benefit from getting back down to 1st. You're better off just leaving it in 2nd. Even with a good heel-toe, the car doesn't LOVE going into first unless you're CRAWLING, so you're better off holding a few mph more speed and keeping it in 2nd.
I found that it was harder before, when the car was stock - With a tune, the torque dip is not such an issue getting low in 2nd as it was before. Also, with some really sticky tires, you can make those hairpins at a higher speed so you don't drop so low in rpm in 2nd either, making 1st really unnecessary.
CatDaddysBBQ is offline   Reply With Quote
Old 04-28-2017, 04:06 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
When I used to autox my Miata I would do that quite often (depending on the course).
Since the car loved revs I always had it in a high rpm.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
nikitopo (04-28-2017)
Old 04-28-2017, 04:10 PM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I've seen a rally driver switching to 1st gear. However, please keep in mind that the specific car had a slightly longer 1st and 2nd gear ratio.
Old 04-28-2017, 04:23 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+1 for keeping it in second, modern autox courses only briefly drop below 30 mph in my experience, 99% of the time you'll be slower trying to shift to first than just riding out the lack of power down low, not to mention the risk of not nailing it which would instantly put you behind someone not shifting.
ineedyourdiddly
Old 04-28-2017, 04:27 PM   #6
imnotsureaboutbrz
That's going to be a fun and interesting part of learning this car. Trusting that there's more grip than I think and try to carry more speed. I'm pumped. I'm on Michelin PSS' btw.
Old 04-28-2017, 04:53 PM   #7
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've been tempted to use 1st sometimes to avoid coming out of hairpin turns right in the middle of the torque dip, but downshifting to 1st in a competitive environment is not easy to do, and it usually winds up costing me more time than it saves because it draws too much of my focus. I've only recently gotten decent at coming back down into 2nd from 3rd gear [relatively] smoothly and quickly without screwing up my line, lol.
I'd love to be able to heel-toe down into 1st flawlessly like a pro, but I really don't wanna burn out my synchros practicing it too much, lol.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
CatDaddysBBQ (04-28-2017)
Old 04-28-2017, 05:36 PM   #8
CatDaddysBBQ
Drives: '13 FR-S
A much more detailed way to say what I was thinking.
Old 04-28-2017, 05:38 PM   #9
CatDaddysBBQ
Drives: '13 FR-S
The PSS tires were a HUGE upgrade from the oem junk we get. As a road tire, I think they're pretty perfect. It didn't take me too long to find their limits at autoX though. They are GOOD for autoX, but definitely leave something to be desired compared to anything in the 200tw class.
Your mileage may vary. I spent 2 seasons on PSS and then went wider and stickier and it's a huge jump.
Old 04-29-2017, 12:59 AM   #10
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
There is one venue in Tamps where I needed 1st gear the two times I have ran there.(very small venue) Dixie day-one course rquired 1st as well. (That was the only national course I have seen do that)
My wife co-drives with me and we run data. If the tach drops below 2k, I generally consider a downshift to be "needed".
Twinz is offline   Reply With Quote
Old 04-29-2017, 02:54 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The 2k limit is very very low.
Old 04-29-2017, 08:17 AM   #12
Twinz
Twinz's Avatar
That's where I'm sure. At 3k I am looking at what's after the element and considering 1st. At 4k, I'm just out of luck.
Old 04-29-2017, 10:30 PM   #13
strat61caster
http://www.precisionsite.com/auto-x/tools/
@Twinz is just playing it safe, without practice I think I'll be ascribing to his philosophy, 2k rpm is ~16 mph, in my relatively short experience I don't think I've ever seen anything that low, 3k rpm is ~24 mph, not that huge of a speed differential even though a thousand rpm FEELS like it takes forever, it really doesn't.
Data logging can be a huge help here, you can actually know if you're going slow enough to warrant the downshift, whether you decide you need it if you're doing 25, 20 or 15mph is totally up to you.
OP might be able to find local videos or even look back at his own to see if there's any corners <25mph.
ineedyourdiddly
Cole (05-04-2017)
Old 04-30-2017, 03:41 AM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I posted a video that shifting to 1st gear is entirely possible and in fact safe. What do you mean it FEELS like it takes forever, but it really doesn't. A higher gear is just a higher gear. If the car is going too slow and we can change to a lower gear, then we should do it. Maybe he should practice first in a closed road to see how confident he is with this and try to advance his skills as a driver.
The Following User Says Thank You to nikitopo For This Useful Post:
strat61caster (04-30-2017)
First time with OFT (silly question) tzbang Software Tuning 3 06-18-2016 10:34 PM
Another silly salesman story Trashed675 BRZ First-Gen (2012+) — General Topics 70 06-14-2016 07:42 AM
Silly screw ups FX86 Scion FR-S / Toyota 86 GT86 General Forum 78 06-10-2016 03:24 AM
silly newbie e85 question 2much Engine, Exhaust, Transmission 3 01-19-2015 06:34 PM
Top Gear AU - Review (from 4th June launch) Mr Franky AUSTRALIA 16 06-06-2012 07:51 PM
