Old 04-13-2014, 03:15 PM   #15
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by fstlane View Post
I'm interested to hear as well. Shorai uses prismatic LiFePO4 pouches where as Antigravity uses A123 cylindrical LiFePO4 cells so their composition is different. However, neither use a built in battery management system to prevent overcharging/undercharging so both would be subjected to the same operating conditions. I'm pretty disappointed as I was excited to implement this newer battery technology into this platform but it doesn't appear it's a viable option as a drop in replacement.
Shorai is in my to do list and my car will see many track events this year so I will report back
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
fstlane (04-13-2014)
Old 04-28-2017, 05:59 PM   #16
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Any update on this @glamcem?
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 04-29-2017, 12:59 PM   #17
RFB
RFB's Avatar
Drives: FRS
Tracking and D.D'ing my Shorai for several years now, let it go flat a couple of times, the last time it discharged it would not charge up again with the Shorai charger.
However, I charged it with an old crappy tire conventional charger at HIGH for a few minutes, then a conventional charge.
Been working fine and charging with the Shorai charger for the last 2 years.
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
fstlane (04-30-2017)
Old 04-29-2017, 01:15 PM   #18
stevesnj
stevesnj's Avatar
If the battery needs a special charger then I would think the alternator on the car wouldn't maintain the battery the same as a special charger. Do they provide any special regulator or anything between the battery and the alternator feed wire?
Edit* I just saw this new automotive battery with a BMS which is what is needed for cars with an alternator...
My 2016 Build thread
Old 04-30-2017, 03:50 PM   #19
glamcem
glamcem's Avatar
Sorry, I no longer have the car :/ I was planning to get one of these but didn't get a chance to do it
FRS iPhone 5 Case T-SoL Miscellaneous 6 02-13-2013 11:22 PM
In case you can't decide... spomi Southern California 9 11-10-2012 01:15 AM
Just in case you thought you could GT300 your BRZ... Superhatch BRZ First-Gen (2012+) — General Topics 5 09-01-2012 04:48 PM
Just in Case Anyone in SoCal is Still Looking. ZmZMWagon Southern California 17 07-25-2012 01:55 PM
