| Member's Car Journals Car journals by our members. |
Drives: '15 BRZ RA
nikitopo's BRZ OEM+ build
I am presenting a journal of my car. It is based on the bares-bones JDM car, with a few changes for the German market. This trim level was offered until the middle of 2015. Now we have only the high spec trim. It is not a daily driven car, but a weekend fun car.
September 2014: Car arrived ... ![]() ![]() January 2015: Rims Enkei Racing RS05 (16 inches), Project mu lug nuts ![]() ![]() April 2015: Spoiler & badge delete, new tires (Advan AD08R) ![]() ![]() ![]() June 2015: A/C delete ![]() November 2015: STi flexible tower bar, STi bolt support rear sub-frame & upper stopper ![]() ![]() ![]() February 2016: Smaller battery based on the bare-bones JDM car ![]() June 2016: STi steering bolts ![]() August 2016: Toda Racing pulley kit ![]() ![]() April 2017: Toda Racing bigger throttle body ![]() September 2017: Sachs Performance Coilover Suspension
| The Following 12 Users Say Thank You to nikitopo For This Useful Post: | BRZgirl (10-16-2016), D5teph (10-01-2017), Iceman (09-30-2017), Mr.Impreza (03-08-2017), mrg666 (10-01-2017), new2subaru (10-23-2016), Racecomp Engineering (10-02-2017), surfwaxsmitty (12-04-2016), Taka (05-24-2017), Tcoat (08-27-2016), Trap63 (04-28-2017), weederr33 (03-11-2018) |
#2 |
Drives: '15 BRZ RA
November 2017: OEM +'17 exhaust manifold with thermal coating and Cosworth tuning kit (stage 1.0)
![]() ![]() ![]() ![]() February 2018: Toda Racing Light Weight flywheel & clutch kit (3 puck metallic disc) ![]() ![]() May 2018: Rear OEM +'17 stabilizer bar ![]() August 2018: STi shift knob Duracon & Yuasa battery (Made in Japan) ![]() ![]() October 2018: STi air filter & STi connector (sound creator) ![]() ![]() May 2019: STi fender garnish ![]() June 2019: STi performance muffler ![]() ![]() August 2019: Bilstein JDM tS suspension ![]()
| The Following User Says Thank You to nikitopo For This Useful Post: | weederr33 (11-16-2017) |
#3 |
Drives: '15 BRZ RA
After a long time, I am ready for the next step. I'll make an order for the Toda big throttle body. I used once the sprint booster (throttle controller) and the results were quite good (*). Only issue was that the car was very nervous during city driving (e.g., traffic lights). Personally, I couldn't used to it and the only solution was to take it off. I expect the throttle body change to be a much better option, without any of the disadvantages. Toda parts are very rare and this one are saying will need a 60-75 days period for delivery. Let's see when it will be delivered.
(*) The engine was more responsive, it could rev quicker and there was a small torque increase in the low-middle area. Probably because more air was getting in, than the tip-in enrichment. Last edited by nikitopo; 03-17-2017 at 02:50 AM. |
| The Following User Says Thank You to nikitopo For This Useful Post: | Mr.Impreza (03-16-2017) |
#4 | |
Proud of BOXER
Drives: Subaru Boxer
Interesting, I didn't even realize those wheels came in 16"
| The Following User Says Thank You to Clipdat For This Useful Post: | nikitopo (03-17-2017) |
#5 |
Drives: '15 BRZ RA
First post updated with the Toda Racing throttle body.
#6 |
Drives: '16 Hyperblue BRZ
Are those RS05 reps? I thought they only came in 18in...
#7 |
Drives: '15 BRZ RA
#8 | |
#9 | |
Drives: '15 BRZ RA
![]() Overall, you don't need bigger wheels. Only if you have bigger brake calipers or for aesthetics. The Advan AD08R tires have very stiff sidewalls, so they can compensate the more rubber. Last edited by nikitopo; 05-01-2017 at 11:28 AM. |
#10 |
Weight Weenie
Drives: 15 FR-S
Can you tell me the sizing on the tires please? I downloaded the pic and zoomed in but I still can't read it.
#11 |
Drives: '15 BRZ RA
| The Following User Says Thank You to nikitopo For This Useful Post: | new2subaru (04-28-2017) |
#12 |
Drives: '24 GR86
You're thinking of RS05RRs. The RRs and the normal RS05s are different and come in different sizes.
Just like their: PF01 vs PF01 EVO GTC01 vs GTC01RR NT03M vs NT03RR
| The Following 3 Users Say Thank You to TylerLieberman For This Useful Post: |
#13 |
Drives: '15 BRZ RA
I had the chance to test the new throttle body. I didn't test it thoroughly, because there was traffic and then it started raining. However, I managed to make a few pulls up to 4-5k RPM with partial throttle and one with full throttle. The car has definitely more torque and the engine runs much smoother. I was a bit puzzled how this can happen with just a small size difference, so when I arrived home I studied the stock part.
It looks that the stock tb has some design issues like that the inside surface is quite rough and overall the tapered shape is not very smooth. It is like they glued two different pieces together, but without fitting them exactly. I am not sure if this was made on purpose or just for keeping the cost low. However, these differences together with the size increase (+2mm) of the new tb, gave an impressive result. Additionally, I didn't see any disadvantages like higher idle RPMs etc. I heard at the beginning there were such kind of issues, but it looks that Toda managed to solve them because this is a revised part (16400-FA2-002 instead of the older 16400-FA2-001). |
| The Following User Says Thank You to nikitopo For This Useful Post: | Mr.Impreza (06-17-2017) |
#14 | |
How did you measure this?
