Old 04-18-2017, 01:28 PM   #421
robotleader
Drives: brzzzz
does this effect 16s? mine was build date of feb 2016
robotleader is offline   Reply With Quote
Old 04-18-2017, 01:41 PM   #422
Da Brz
Drives: 2016 Subaru BRZ
Originally Posted by bass_114 View Post
So I gave it a try today and they said the sound was completly normal and what we hear is the injectors spraying fuel....lol, tried arguing but couldn't deal with the guy's incompetence so no luck for me and i am out 80$ for diagnosis ;(
This has been my experience with my dealership as well. Everything this car does is normal. Chirping? Normal. Hard starts? Normal. Knocking and rough idle? Normal. Knocking while coming to a stop? Normal.
I'm beginning to think Subabru/Toyota have decided that it's all just acceptable at this point. Subaru sold 4,000 BRZs last year and almost 183k Outbacks. I don't think they care.
To me, it might be "normal" but it's not acceptable.
Da Brz is offline   Reply With Quote
Old 04-18-2017, 04:51 PM   #423
stevesnj
stevesnj's Avatar
Possibly, read the TSB in the first post for VIN coverage.
My 2016 Build thread
Old 04-21-2017, 10:43 PM   #424
Kana
Drives: auto 2016 frs
Help! Do I have to print out the copy of the tsb and show service person. they keep telling me the cricket noise is normal. help me please =)
Kana is offline   Reply With Quote
Old 04-21-2017, 10:55 PM   #425
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Find a printer and print that mofo out. At least that way you have actual hard evidence in your hand. If they still won't do it, go to another dealership. The first dealership I went to didn't want to do it, but the second one said it was no problem.
smg1138 is offline   Reply With Quote
The Following 2 Users Say Thank You to smg1138 For This Useful Post:
Kana (04-21-2017), stevesnj (04-22-2017)
Old 04-21-2017, 11:02 PM   #426
Kana
thanks =)
Old 04-27-2017, 11:14 AM   #427
smg1138
smg1138's Avatar
I got the new fuel pump installed last weekend. It's been pretty warm here since then and so far no chirps at all. Hopefully that will continue.
stevesnj (04-27-2017), Tcoat (04-27-2017)
Old 04-27-2017, 11:15 AM   #428
HunterGreene
Hail Magnet
HunterGreene's Avatar
At approximately 500 miles since change and still no crickets, and it was unseasonably warm yesterday.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Tcoat (04-27-2017)
Old 04-27-2017, 11:18 AM   #429
stevesnj
stevesnj's Avatar
Got the pump in October and today is supposed to be near 80 which is when I'd get the crickets. Hopefully this is the end of this issue.
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
smg1138 (04-27-2017), Tcoat (04-27-2017)
Old 04-27-2017, 12:34 PM   #430
Firecruiser
Drives: 2014 brz
Just went to the dealer to get the hpfp replaced. I talked to the tech and he said to set up an appointment to get it replaced. Set up an appointment and drop my car off. Get a call saying that the part isn't covered under powertrain. They wanted 1900$ to replace it.
Turns out that the part in the system is listed as a 3/36 part but the tsb says to replace under powertrain. She called corporate and they were confused as well but said to replace under powertrain. Just a heads up in case anyone else runs into this issue. Make sure they look at the tsb and that it says to replace under powertrain.
Firecruiser is offline   Reply With Quote
The Following 2 Users Say Thank You to Firecruiser For This Useful Post:
Old 04-27-2017, 12:45 PM   #431
stevesnj
stevesnj's Avatar
Have them come to this thread and see everyone else who's dealer replaced it with no issues. Unless you have over 60k miles on it they don't want to do it. I'd go to another dealer that's all. It will eventually work out.
Old 04-27-2017, 02:43 PM   #432
smg1138
smg1138's Avatar
Toyota replaced my HPFP under the powertrain warranty. Make sure to bring a hard copy of the TSB to make it easier. Also, it would be a good idea to make a video recording of the chirping. When I took my FRS in for the repair, it was a cold day and wasn't making the sound. Had to send the recording I took to the service manager so they had proof.
The Following User Says Thank You to smg1138 For This Useful Post:
HunterGreene (04-27-2017)
Old 04-27-2017, 02:55 PM   #433
stevesnj
stevesnj's Avatar
I did the same thing and they accepted that. I think it depends on the mood of the Service Manager too..lol
You can take the audio from my vid and have them listen...
[ame="https://www.youtube.com/watch?v=5uUDRKMAZyg"]2016 FR-S Crickets - YouTube[/ame]
Old 04-28-2017, 07:12 AM   #434
Firecruiser
Drives: 2014 brz
The sorted it out after i told them the tsb says it should be covered under powertrain. Sadly i told them i didn't want to make two trips to take care of the replacement. I showed the tech the issue when i scheduled my appointment. Took my car in they verified the issue again and ordered parts. So now i need to bring my car back when the parts are in. Reasons i hate dealerships...
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 06:39 AM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
