Old 04-26-2017, 07:15 PM   #2213
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
The tuner should have known that a new 2017 model car bought in the US
would not have a JDM ecu or calibration unless you had modified it as such beforehand. A JDM ecu installed in a USDM car would get Toyota into a heap of trouble with the feds and all the other smog/safety nazis.
How well do you know this tuner/installer and their familiarity with these vehicles?
My tuner worked on FI systems for this car (2014/15 models), but the supplied tune had to be present. When it comes to custom flashing, they don't "roll that way", but they are working with me on properly flashing the ECU at the very least.
I have options though: Wait for EB to recalibrate their CARB tune and send it to me or I buy Delicious Tuning's calibration and roll with that.
I'm doing the former now (as recommended by my installer) until EB gets back to us with a solution.
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 04-26-2017, 07:20 PM   #2214
johan
Drives: '14 981CS, '99 NB1
Originally Posted by ThatAsianBradah View Post
So that also goes for the automatic MY17 twins as well? The only major differences (publicly known) that the MY17s for both 86 and BRZ have are the intake manifold (red) and the intake airbox/tubes.
If anyone can confirm that the autos 17 utilize the same units as previous year models, that'd be INCREDIBLE for R&D building for these new models.
Yes! I have an automatic 17 and I can confirm it has the new alternator design. I put the Harrop SC on my car and that new wire location -just barely- touches the manifold. It almost didn't clear. I wondered wtf Harrop was thinking, now I know I just got lucky. Harrop does fit though!
Attached pic of clearance
johan is offline   Reply With Quote
The Following 4 Users Say Thank You to johan For This Useful Post:
brzaapi (04-27-2017), CSG Mike (04-27-2017), Decay107 (04-26-2017), ThatAsianBradah (04-26-2017)
Old 04-26-2017, 07:34 PM   #2215
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Hmmm...that is waaaay too close for comfort though
Old 04-26-2017, 08:14 PM   #2216
ThatAsianBradah
Wow! It's good to know that with the MY17s going forward that a lot of these FI kits may need some tweaking in order to fit properly. I was able to get the EBSC to work around the new alternator design thankfully. All that's left is the darned ECU! Still waiting for word back from EB on their tune.
Old 04-26-2017, 11:26 PM   #2217
colushi808
Drives: 2017 Toyota 86
Hope EB releases a regular non CARB tune first like how they did in the beginning. If not, might be waiting for a while until they go through the process of getting it approved.
Sent from my SAMSUNG-SM-G920A using Tapatalk
colushi808 is offline   Reply With Quote
Old 04-27-2017, 12:09 AM   #2218
CSG Mike
CSG Mike's Avatar
Confirmed, all 17's have the new alternator. I confirmed it personally.
Old 04-27-2017, 12:10 AM   #2219
CSG Mike
CSG Mike's Avatar
What exactly did you do to get the clearance you need?
Old 04-27-2017, 07:39 AM   #2220
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
THIS!!!! , and if it is your shop that figured it out, please share contact info so I may drive them crazy, I mean.....make my EBSC fit too.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 04-27-2017, 10:11 AM   #2221
Uplink
Uplink's Avatar
Drives: anything you let me
Out of curiosity, does/will the new design alternator supercede the old one? ie, if your '13-'16 has a faulty alternator and you get it replaced, will the dealership install the new version?
If so, this could be something older model owners need to be aware of.
Uplink is offline   Reply With Quote
Old 04-27-2017, 11:17 AM   #2222
driggity
Drives: Silver Coupe with a Boxer
Yeah, I would be very worried about that wire rubbing on the supercharger.
Since the connector on the control cable is different I doubt they would since it would require changing part of the wiring harness as well as the alternator. But weirder things have happened.
driggity is offline   Reply With Quote
The Following User Says Thank You to driggity For This Useful Post:
Uplink (04-27-2017)
Old 04-27-2017, 11:44 AM   #2223
johan
I've been keeping an eye on it, it doesn't seem to be affecting the wire. I've even been to the track a couple times.
That said, if I ever take the blower off for some reason (service? idk)... I'll be filing down the edge of the manifold right there to get some additional clearance. If I had realized it was that close before we'd gotten everything settled, I would have filed it down before finishing the install. Getting the blower in place though was enough of a PITA that by the time that it "fit", it wasn't coming off.
Old 04-27-2017, 02:29 PM   #2224
ThatAsianBradah
My installer said, "The alternator had to be modified a bit by removing the clip for the regulator and bending the pin to clear."
No pictures on that, but you can imagine how it went
Old 04-27-2017, 02:40 PM   #2225
Uplink
Uplink's Avatar
Didn't catch that. Sounds like we'll be safe then, thanks!
Old 04-27-2017, 03:45 PM   #2226
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Well, I suppose I could bend the pin carefully. But do you know if when the clip was removed, did they hardwire the wire to the alternator or use a low profile type connector. Just curious, as I will likely try to modify my own and don't want to mess it up.
Daily: Audi TT RS
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
