Old 12-28-2016, 10:52 PM   #1
srt4_night_rider
Delete Delete *please delete*
Delete delete delete delete
srt4_night_rider is offline   Reply With Quote
Old 12-30-2016, 08:33 PM   #2
Bullitt2496
Guest
Posts: n/a
Originally Posted by srt4_night_rider View Post
For those of you that had to go with an aftermarket clutch master cylinder for clearance issues or just because the stock one didn't put out enough pressure, what did you end up going with?
Pressure. Need to have the bore and stroke match whatever is OEM to the clutch slave in the swap.
My car's kit from WGP for LS came with a 3/4 Tilton Master w/ adapter to OEM pedal and a mounting plate for the firewall. They also provided a modified Brake Booster fluid reservoir to supply the fluid to the master.
Old 12-30-2016, 08:44 PM   #3
http://www.ft86club.com/forums/showthread.php?t=77390
Old 04-25-2017, 11:54 AM   #4
srt4_night_rider
I guess my main question is other than WGP who actually makes them for our car. I find all sorts of pictures of people running smaller ones but no info on what brand etc they are. I have a clearance issue with my motor and need something that is right under 3" off the firewall.
Old 04-25-2017, 12:02 PM   #5
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Vorshlag has one designed, they just haven't released it yet. They are busy with other projects and now that good weather is upon us, I imagine they will have even less time for projects (big time racers). So don't hold your breath on it being released any time soon. I just need to get the measurements, but plan on having my friend machine me up an adapter. Once it is designed and machined, super easy to make another one. So I can get more made if need be.
edit: I will get a measurement today of the Tilton Master most of the swaps seem to be using.
The Following User Says Thank You to DustinS For This Useful Post:
srt4_night_rider (04-25-2017)
Old 04-25-2017, 03:43 PM   #6
srt4_night_rider
This is one of the most recent ones I have seen. I messaged the guy twice and he kept saying clutch masters made it. However to my knowledge they didn't fool with masters, but I emailed them anyway just to be sure I wasn't wrong. They confirmed that they did not make them.
Old 04-25-2017, 03:48 PM   #7
DustinS
DustinS's Avatar
That really looks like a S2000 Clutch Master...
Old 04-25-2017, 03:52 PM   #8
srt4_night_rider
I actually thought the same thing!
The Following User Says Thank You to srt4_night_rider For This Useful Post:
DustinS (04-25-2017)
Old 04-25-2017, 03:54 PM   #9
srt4_night_rider
What's interesting as well. If you type in FRS or BRZ clutch master cylinder in google images the S2000 one comes up from JHPUSA.com.
Old 04-25-2017, 04:07 PM   #10
DustinS
DustinS's Avatar
I have a friend with the Tilton/Wilwood Master to Honda Master adapter, Seeing if he can measure the mounting hole distances and angles for me to see if they are the same. This may be the solution on a master cylinder mount without needing custom parts made.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
all4spl (04-25-2017), Sportsguy83 (04-25-2017)
Old 04-25-2017, 04:38 PM   #11
all4spl
Great work guys!!!
all4spl is offline   Reply With Quote
Old 04-25-2017, 04:54 PM   #12
DustinS
DustinS's Avatar
Well he missed the word "Clutch" and thought I meant Brake master. So still not sure there. May eat the price and order one up anyway and see what happens.
Old 05-01-2017, 09:47 AM   #13
DustinS
DustinS's Avatar
Master Adapter comes in today. Will keep you updated on if it fits correctly or not.
all4spl (05-01-2017), Sportsguy83 (05-01-2017)
Old 05-02-2017, 09:36 AM   #14
DustinS
DustinS's Avatar
Bolt spacing/angle is not the same on the honda/S2000. You can slot the bolt holes a bit and get it to fit, though it sits a bit crooked.
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
WTB: Master Cylinder Brace DAEMANO Want-To-Buy Requests 8 09-03-2015 12:12 PM
What happens if I get air in the master cylinder? dstrout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-21-2015 11:42 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
BRZ/FR-S master cylinder brace - $60 Turn in Concepts Brakes, Suspension, Chassis 35 01-26-2013 12:17 PM
