Old 04-22-2017, 11:02 AM   #225
-Willis-86touge
Drives: Stock
So did another high speed test this week let's just say it's bad! First off I changed rims and tires, still na. I got a cheap set of rims that weigh a lot but I figured it make it look better and I could test a fitment that I wanted with out spending 2000 and being disappointed. So for tires I went with a meaty tire a 245/40-18 instead of a 225/40-18 yea I know crazy right. So first few days there was rubbing because I hadn't got a alignment. After the alignment no rubbing unless I hit a big bump going to fast or let's say the was a steep inlince like a drive way. So all good there. ... so. The test run I was expecting to hit 160 165 because the bigger tires in effect lower final drive ratio. So yes it's a bit slower driving around town but it's smoother too! Well I end up hitting 137�� Wtf! Any thoughts. It's either the heavy rims or the cars power level doesn't have enough with the new final drive to push faster. I think that their is it not enough power now. Really sucks I guess il have to go back to a normal tire size and see what happens!
-Willis-86touge is offline   Reply With Quote
Old 04-22-2017, 11:09 AM   #226
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
This car has 200hp lol, what are you expecting? You won't get much higher than that.
Yanbags is offline   Reply With Quote
Old 04-22-2017, 11:12 AM   #227
-Willis-86touge
Drives: Stock
Well I hit 155 before.
Old 04-22-2017, 11:30 AM   #228
Somerandom18
Drives: 2017 manual BRZ
Crazy, I've hit 150 only with different tires..
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 04-22-2017, 12:13 PM   #229
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Many times in the range of 140-145 mph.
Old 04-22-2017, 01:49 PM   #230
Yanbags
Yanbags's Avatar
Wow, beats me then.
Old 04-22-2017, 02:56 PM   #231
-Willis-86touge
Drives: Stock
What size cause the 245/40-18 that I put on are almost an in bigger.
Old 04-22-2017, 09:31 PM   #232
Somerandom18
Stock size just sticker compound so probably wouldn't make a difference as far as top speed goes.
Old 04-23-2017, 05:15 AM   #233
paulca
Drives: Toyota GT86 Coupe Red (UK)
When you changed the tyre size did you recalibrate the speedo or are your driving with a broken one?
Don't know about over there but insurance companies here will invalidate your insurance if you change the size of your wheels (rolling circumference) unless you can prove you re-calibrated the speedo. Not to mention the police might be interested.
If you fit larger circumference wheels the speedo under reads. Fit smaller ones and it over reads. By default on stock wheels the speedo under reads by about 10%.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 04-23-2017, 02:28 PM   #234
A fun piece of math and physics for you top speed masters.
According to the attached formula, what would be the theoretical top speed of a stock, 2013 FR-S with a manual transmission..??
Note ..... be sure to use estimated wheel horsepower.
Old 04-23-2017, 04:45 PM   #235
-Willis-86touge
Drives: Stock
Stock at 7500 rpm with stock tires is 175
With 245/40-18 @ 7500 rpm math works out to 184
Sorry to say I didn't use your formula humfrz just used a basic program that figures tire size and gearing.
Old 04-23-2017, 04:47 PM   #236
-Willis-86touge
Drives: Stock
No I didnt recalibrate yet the speedo showed 133 did the math and works out to 137 with the 245/40-18 tires but when I did 155 it was completely stock; speedo read right
Old 04-23-2017, 08:29 PM   #237
Well now, Willis-86touge, that basic "gear limited" program is just fine ...... but it doesn't factor in the air that the car has to push out of the way .....
Down here on earth, pushing air out of the way is a big factor, especially at higher speeds........
Old 04-23-2017, 08:44 PM   #238
brz11b
Drives: United States
Got to about 120mph, took me about 37 minutes. there was more room but I was running out of road and patients waiting.
2013 BRZ limited, FBO stage 2 and more - SOLD
2015 Silverado LTZ Z71 Midnight edition - DAILY
2013 FRS turbo - coming soon!
brz11b is offline   Reply With Quote
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
Need For Speed... Really? Texas BRZ Tracking / Autocross / HPDE / Drifting 61 01-11-2013 11:59 PM
Top Speed L3P47 Scion FR-S / Toyota 86 GT86 General Forum 6 12-18-2012 12:06 AM
top speed JLMtm Scion FR-S / Toyota 86 GT86 General Forum 56 10-30-2012 09:23 AM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 10:59 AM
