Old 04-20-2017, 02:10 AM   #435
retrofit
Drives: Toyota 86
Have any fellow Ace Laguna 90 catback owners considered the Intec Japan Tail Lights with integrated reverse lights (to replace the stock reverse lights)?
https://translate.google.com.au/tran...ml&prev=search
The best price I've come across is around $500 USD so they're a bit on the pricey end of town. Unfortunately there do not appear to be other brands making tail lights with integrated reverse lights for the 86/brz.
I'm not really a fan of the Diode Dynamics 'Tail and Turn' tail light mods as the turning indicators are no longer amber. Where I'm from the Australian design rules require the turn indicators to be amber. Interestingly the rules allow reverse lights to be either white or amber, so I could as an alternative, have my stock indicator lights double as reverse lights (I wonder if the Diode Dynamics kit will allow me to do this?).
retrofit is offline   Reply With Quote
Old 04-20-2017, 03:32 AM   #436
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Only problem is, the reverse is shaped like a flower....
Sent from my SAMSUNG-SM-G935A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 04-20-2017, 12:24 PM   #437
johan
Drives: '14 981CS, '99 NB1
You got something against flowers?
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Ultramaroon (04-20-2017)
Old 04-20-2017, 01:02 PM   #438
I'm holding out for the Hello Kitty reverse.
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
endless_pain (05-03-2017), Jmonty (04-21-2017), johan (04-20-2017), strat61caster (05-03-2017), Tcoat (04-20-2017), why? (04-22-2017)
Old 04-20-2017, 01:06 PM   #439
Is that similar to reverse cowgirl?
Jmonty (04-21-2017), Pointmutation (04-20-2017), RJasonKlein (04-30-2017)
Old 04-20-2017, 01:14 PM   #440
johan (04-20-2017), Overdrive (04-20-2017)
Old 04-29-2017, 01:22 AM   #441
retrofit
Drives: Toyota 86
Going back to the topic of reverse lights...
Is it in the realm of possibility to cut the center fog light out of the reverse light module to provide enough room for the exhaust tip to pass through while still retaining it's function?
Assuming the above is possible, would some heat shield between the exhaust tip, and the reverse light, be enough to stop it from melting/failing from the heat?
If the above is a no go then a simple standalone aftermarket or subaru reverse lights with compatible wiring/connector might be the easiest fix. I'm thinking of placing the standalone reverse light in the empty space next to the exhaust tip (assuming heat isn't an issue) or maybe to the right of the bumper close to the stock exhaust tip.
Right now I'm having trouble finding standalone aftermarket/OEM reverse lights as a google search of 'subaru reverse light' is giving me results for replacement bulbs or reverse lights integrated with tail lights
Old 04-29-2017, 02:20 AM   #442
Reamer
Drives: 2015 FRS
I would suspect heat would be an issue, but I have nothing to back that up with. I say try it and if it fails then deal with it later (since reverse lights aren't a legal requirement and the stock ones do very little anyways).
I am not affiliated with Diode Dynamics in any way but their solution is the cleanest on the market IMO and it isn't expensive either. It is also a super easy install for anyone to do (I'm in a wheelchair and I did it at night with inadequate lighting within 30 minutes). This is by no means showing off my wrenching prowess (which is minimal, at best), I only mention it for the ease of installation.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
The Following User Says Thank You to Reamer For This Useful Post:
Jmonty (04-29-2017)
Old 04-30-2017, 01:10 AM   #443
retrofit
Drives: Toyota 86
Unfortunately where I'm from reverse lights are a legal requirement.
I might just try running them right next to the exhaust and see how it goes.
Old 04-30-2017, 01:17 AM   #444
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I've thought about getting a slim bar to put in the back window but haven't researched much into it.
Highly unlikely it would pass a legal inspection though.
Or a smaller bar where the license plate lights are. Wouldn't look very good though.
Old 04-30-2017, 11:28 AM   #445
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
The Diode Dynamics solution has worked out awesome for me, I couldn't be happier.
Jmonty is offline   Reply With Quote
The Following User Says Thank You to Jmonty For This Useful Post:
Silverfox (05-01-2017)
Old 04-30-2017, 08:19 PM   #446
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
but what are the requirements exactly? Could you just get a led strip and run it above the diffuser across the rear of the car? That seems like it would be the easiest solution.
why? is offline   Reply With Quote
Old 05-01-2017, 09:52 AM   #447
retrofit
Drives: Toyota 86
If the led strip is not overly bright or too dim then it should suit my requirements.
I believe the stock reverse lights may have reflectors built in which potentially is another requirement. Although this could be dealt with separately.
Do you have any suggestions for led strips?
Sent from my SM-G930F using Tapatalk
Old 05-03-2017, 10:48 AM   #448
nunonuna
nunonuna's Avatar
Can anyone tell me how this exhaust sound differ from Q300?
nunonuna is offline   Reply With Quote
FNA rear fog light Kit 1 w/high power LED HATED1 Exterior Parts (Aero, Lighting, Etc.) 5 02-09-2015 04:31 AM
HKS High Power Spec-L Ti-Tip Tien Engine, Exhaust, Transmission 0 10-23-2013 11:54 PM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 07:41 AM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 06:30 PM
