Old 04-04-2017, 01:21 AM   #687
D5teph
Automotive Enthusiast
D5teph's Avatar
Drives: Zenki 86
Originally Posted by KayC View Post
What's the specs on your setup? Look's clean bro!
D5teph is offline   Reply With Quote
Old 04-07-2017, 12:36 AM   #688
DeshuL
Drives: RS 2.0
2016 FRS RS2.0: Build Thread
DeshuL is offline   Reply With Quote
Old 04-10-2017, 10:23 PM   #689
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I have these wheels with a 255/40 tire on stock suspension. I'm thinking of getting swift spec r springs on bilstien b8 struts and running -2.0 camber up front using camber bolts. Does anyone know if I'll run in to clearance issues with this set up?
rcm47 is offline   Reply With Quote
Old 04-15-2017, 10:41 AM   #690
icybrzzz
Drives: 2015 Scion frz
LRM_EXPORT_20170414_215328 by Daniel Cocar, on Flickr
LRM_EXPORT_20170414_214656 by Daniel Cocar, on Flickr
icybrzzz is offline   Reply With Quote
Old 04-17-2017, 04:37 PM   #691
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
You'll run into clearance issues up front with that setup. Also keep in mind it's quite hard to get more than -1.5 camber with just bolts.
tyler_win_photo is offline   Reply With Quote
Old 04-17-2017, 07:11 PM   #692
churchx
churchx's Avatar
Drives: 2014 GT86
tyler: with camber bolts in both holes at stock height imho one should get around -2.2
Old 04-19-2017, 11:23 AM   #693
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Raven FR-S with Gold RPF1
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 04-21-2017, 09:23 AM   #694
Chronology
Drives: 13' Satin White Pearl BRZ
235/40/17 Federal 595RS-Rs on 17x9 +35 Victory Blue RPF1s.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 04-21-2017, 10:11 AM   #695
Erick KY
Drives: Raven FR-S 6MT
Wheel Directory: Enkei RPF1 17x9.0 +35
lol twins 😭
Erick KY is offline   Reply With Quote
Old 05-09-2017, 07:36 PM   #696
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Anyone tried these with 8mm spacers and 255/40s? Worried about rub in the rear, but also a stupid good deal on a used set in the classifieds.
trippinbillies40 is offline   Reply With Quote
Old 05-09-2017, 07:38 PM   #697
Erick KY
@trippinbillies40 are you on stock suspension?
Old 05-09-2017, 07:59 PM   #698
trippinbillies40
Drives: '22 WRB
Yeah. For now.
Old 05-09-2017, 08:02 PM   #699
Erick KY
Originally Posted by trippinbillies40 View Post
Yeah. For now.
You'd be fine in the rear. Upfront however, you'd rub the fender liner on full lock
Old 05-09-2017, 08:11 PM   #700
trippinbillies40
Drives: '22 WRB
Rub it because of stock suspension??
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
