Old 12-19-2016, 12:06 PM   #57
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Just installed these over the weekend... Feels Awesome! Definitely one of those, "should have come this way from the factory" things.
Noticeably improved rear end characteristics. Can feel the difference in all aspects (acceleration, braking , cornering). For the price, this is a must do mod (especially if you have done other suspension mods)
Had a little trouble with the rear bolts like most, what worked for me was loosening all 4 corners, so i could wiggle the sub-frame to get the holes aligned.
Cockatoo is offline   Reply With Quote
Old 04-18-2017, 09:24 AM   #58
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Hey guys I installed these over the weekend and everything went fine except I ended up cross-threading the passenger rear bolt... Should've looked for other instructions instead of just following Whiteline's, these are better.
Anyway, I have an issue now where I get this *tink* noise whenever I turn and/or go over like little potholes. It's definitely coming from the rear. It kinda sounds like that tight metal noise you get when tightening lug nuts. I double checked that everything is tightened down and also the lug nuts were tight but the noise remains. Perhaps I didn't put enough grease? Any other ideas? Thanks
ApexEight is offline   Reply With Quote
Old 04-19-2017, 03:24 AM   #59
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
This is very common, and not aligning the bolt PRECISELY, as you've seen, will result in a cross thread. To make it worse its a cross thread you don't realise has happened until you start tightening with tools. Another reason to never use pwr tools doing this job.
You can re tension the bolts to make sure they are still tight, remove the bolt and re tap with a M14x1.5 tap, re thread the bolt with a M14x1.5 die, or, if you're game, remove the offending bolt and pack it with washers before re installing it and tensioning. An idiot I paid to install mine actually cross threaded one bolt as it was nearly home, despite me warning him, and he used washers to pack the bolt out a little. Seems to have worked but I want to go the tap and die route eventually. There is also the possibility that what you're hearing is normal now you've stiffened the bushes. Your NVH is going to be worse. I also installed the diff bushes at the same time and there is now a very mechanical noise from the rear when I reverse or select a gear every now and then. This is a job that's a lot more hazadous than the written instructions and Youtube clips let on. Good luck
Bodalenko is offline   Reply With Quote
The Following 2 Users Say Thank You to Bodalenko For This Useful Post:
Jhood (05-18-2017), Tristor (03-28-2018)
Old 04-19-2017, 09:20 AM   #60
ApexEight
Do you think using this rental tool from AutoZone will work? http://m.autozone.com/loan-a-tools/t..._0_0?location=
Looks like the tap will be no where near long enough to get all the threads but I don't want to drop $25 on a long tap to be shipped to me next week since I'm autocrossing Sunday, I'd like to address it now. I also might try to find a longer one locally. I already had the diff inserts before these, and yes, while NVH has increased, this almost sounds like something is either loose or even overtightened. Like I said, when going over uneven road I get a *tink* noise from either or both sides of the rear. It's strange and unnerving. I'm going to work on the car today and hopefully fix it. Could also be my rear brakes since I just worked on those but I'm not sure. Will report back. Thanks
Old 07-15-2017, 08:14 PM   #61
ApexEight
So I got a long tap and a new bolt and fixed that one corner that I cross threaded. I'm still getting the "tink" noise on some bumps though. Any ideas?
Old 12-01-2017, 12:23 AM   #62
Hadalet
Hadalet's Avatar
Drives: Argento FR-S
I just put these in today and if i didnt know better, I'd think it was a power mod! So much easier to rotate too!
As to the noise (if it's still happening), check the plastic cover that you had to remove from the passenger side to remove the top two bolts in this pic. It's held on with clips. I had to remove two of the clips in order to pull the cover back far enough to get to the bolts. When I put everything back together, I forgot one of the clips. The plastic would tap where the clip was missing and it sounded just like what you describe. It only did it over rough road or potholes. I hope this helps. 😎
Sent from my SAMSUNG-SM-G891A using Tapatalk
Hadalet is offline   Reply With Quote
Old 12-19-2017, 09:25 PM   #63
Pat
Pat's Avatar
Drives: 2023 BRZ
First, thank you for the excellent post.
Second, there seems to be a discrepancy between the torque specs in this thread (see picture in prior post) and what Whiteline says here.
Anyone know which is correct?
The Following User Says Thank You to Pat For This Useful Post:
Old 12-20-2017, 01:49 PM   #64
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
hmm good point, normally i'd go off of the factory manual, which was what i did when i installed mine the other day.
buttt i would say that when I removed the bolts, they definitely didnt feel like 107lbft to me
IG: @OMGFRS
The Following User Says Thank You to Wes For This Useful Post:
Old 12-20-2017, 03:06 PM   #65
Pat
Pat's Avatar
Drives: 2023 BRZ
I thought the same thing. And the smaller ones sure didn't feel like 54.
Old 12-25-2017, 05:32 PM   #66
NRXRaptor
Do you know what's really awesome? Reading all these posts on how easy it is when I can't even get the fucking thread started again. Now my car is undriveable how am I supposed to get to a shop? Just kill me. Never believing a diy again. Wasted so much money on torque wrenches and sockets
edit: I did it, but I'm going to leave my rage for all to see. It did not go smoothly. Use a creeper jack to align the subframe with the holes in the chassis. Use the screw jack to support the subframe that comes with your car to get the subframe pressed up against the chassis. God damn it that was frustrating
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
Chimera (05-15-2018)
Old 12-25-2017, 05:57 PM   #67
Somerandom18
Drives: 2017 manual BRZ
Yeah I had serious issues too... When taking the bolt off it lifted the body of the car off the subframe. Like wtf? You may be able to limp it to a shop if you can get the rest of the bolts in.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 12-26-2017, 04:08 AM   #68
Wes
Wes's Avatar
Yeah it's not mentioned here, but the trick is to level the subframe. If you lower one end, you need to lower the other end the same amount to keep it aligned, since the bushing will fill in the gap plus a little more
IG: @OMGFRS
Old 01-17-2018, 06:29 AM   #69
Hags86
Drives: Toyota GTS 86
I'm removing my diff centre to install an LSD. Is this job easier to do with the diff in or out?
Hags86 is offline   Reply With Quote
Old 01-18-2018, 04:59 PM   #70
Cockatoo
TALLY FT86
Cockatoo's Avatar
No difference I would think
The Following User Says Thank You to Cockatoo For This Useful Post:
Hags86 (01-21-2018)
bushing, crossmember, diy, whiteline
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
Installed the Whiteline crossmember bushing(no pics sorry) gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-26-2013 03:00 PM
++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ genometuning Transmission and Driveline 4 10-12-2012 10:23 PM
