Old 06-29-2012, 10:51 PM   #1
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
Post Full Report: Road & Track tests stickier FR-S/BRZ tires
http://www.roadandtrack.com/special-...transformation
As much as we love to drive the wonderfully balanced Toyobaru twins, we were displeased at how the BRZ stacked up against the Mazda Miata and Hyundai Genesis Coupe in a recent test (see “The Great New Hope... or Hype?” July 2012). Yes, the BRZ dominated our subjective ratings with its balanced chassis, but it lacked an edge around the racetrack. We theorized that the tires were holding it back.
[ame="http://www.youtube.com/watch?v=r_IWa_qlt3g"]2013 Scion FR-S - YouTube[/ame]
The Subaru-Scion twins are shod with Michelin Primacy HP 87W GreenX summer touring tires. They have a UTQG treadwear rating of 240 and howl in the corners like a beagle strapped to the roof. Buy a Prius in Europe upgraded with 17-in. wheels, and you’ll get these same sad tires. That’s right, these sporty coupes have hybrid tires, tuned for low rolling resistance, not grip.
But what happens when you slap on some sticky stuff? Will it go quicker? Will it ruin the sublime handling? With those questions in mind, we ordered a set of autocross-winning Dunlop Direzza Sport Z1 Star Specs in the factory size (215/45-17) that retail for $146 each at Tire Rack. For good measure, we arranged another set in a plus-one size of 235/40- 18 at $192. Both are cheaper than the factory Michelins that sell for $214, and the Dunlops have a 200 treadwear rating for only a slight decrease in life.
We needed 18-in. wheels, and worked with Eddie Lee at Mackin Industries to find a set that would fit the FR-S without any modification. He set us up with a set of Advan RG II wheels, measuring 18 x 71⁄2 with a +48 mm offset. Although expensive, the 18-in. diameter Advans actually weigh less than the stock rims (an RG II weighs 17.2 lb.; the factory wheel weighs 20.4 lb.). Plus the Advans fit perfectly with no rubbing or clearance issues.
With our new tires, we headed to Spring Mountain Motorsports Ranch and our favorite test loop. We also brought along a Subaru WRX and Mazdaspeed3 for comparative purposes. All three of these cars can be purchased for around $26,000. On the track, the front-wheel-drive MS3 set the bar with a lap time of 1 minute, 27.6 seconds. The all- wheel-drive WRX was 0.7 sec. behind, and the FR-S on the stock tires was slowest, running another second arrears of the WRX. Interestingly, the MS3 and WRX come with high-performance Dunlops as standard equipment.
Install the Dunlops on the stock wheels, and presto-bingo! We have a new winner. The FR-S dropped 2.3 sec. with a simple tire swap. And not only does the car maintain its wonderful balance, it’s vastly improved. The FR-S’ sharp steering is enhanced by the tires’ grip, providing a dramatic increase in feedback—with the Dunlops’ greater forgiveness at higher slip angles, you can literally turn the steering wheel more. The rear rotates more gently on turn-in and the suspension easily handles the added grip. This is the way the FR-S was meant to run! I’m surprised the engineering team didn’t murder the bean counter who forced the low-rolling-resistance tires on them.
We were salivating at the thought of lapping with the noticeably fatter 235-width Dunlops. If the stock size does this well, this bigger tire should rock, or so we thought. The reality was that we gained a little in grip, but gave up some speed (a total of 1.5 mph on the back straight). Although the wheel/tire weights of the 18-in. Advan and stock setups were similar, weight concentrated farther outward on the larger wheel made it slightly harder for the car to accelerate. Also, the bump in overall diameter hurt a bit too; the smaller tires effectively offer shorter gearing. Handling behavior changed only slightly with a minimal decrease in steering feel and less willingness of the chassis to rotate. That said, the FR-S with the larger Advan RG II wheels still managed to tie the Mazda’s lap time.
If you own a BRZ or FR-S, you owe it to yourself to upgrade the tires and feel the way your car was meant to drive.
Name:  Screen Shot 2012-08-09 at 3.46.53 PM.jpg
poormans_LFA is offline   Reply With Quote
The Following 36 Users Say Thank You to poormans_LFA For This Useful Post:
00NissanNinja (08-09-2012), autobrz (06-27-2013), BAE (08-09-2012), bestwheelbase (07-01-2012), CBR600RR (08-15-2012), CoRi J (06-30-2012), danthedirt (08-10-2012), DSPographer (08-10-2012), fernan2 (08-10-2012), flippy (08-10-2012), Fly Guy (08-10-2012), FRSjeff (08-10-2012), FrX (06-30-2012), GaN-MaN (07-01-2012), Grateful Dave (08-10-2012), Guff (06-30-2012), hyper4mance (08-09-2012), Jayde (08-10-2012), MarkRacerX (06-30-2012), maxdriver (06-30-2012), MVJ1975 (08-10-2012), Nepenthe (08-19-2012), Noble713 (08-13-2012), nzer (08-12-2012), RRnold (06-30-2012), S2kphile (06-30-2012), Sideways? (08-10-2012), Slartibartfast (06-30-2012), Snoopyalien24 (06-29-2012), Style (07-02-2012), Subaruwrxfan (08-09-2012), touge-n00b (08-10-2012), TRD_07 (08-14-2012), Turbowned (08-13-2012), yayforaddison (06-30-2012), YukiHachiRoku (07-01-2012)
Old 06-29-2012, 11:12 PM   #2
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
The key message of this video: no need to swap wider gripper tire. Just stay at the stock size.
Name:  fr-s track tire choice.jpg
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
The Following 6 Users Say Thank You to Want.FR-S For This Useful Post:
autobrz (06-27-2013), bestwheelbase (07-01-2012), Guff (06-30-2012), MarkRacerX (06-30-2012), ShoGun (08-09-2012), TRD_07 (08-14-2012)
Old 06-29-2012, 11:14 PM   #3
Razz
Razz's Avatar
Drives: Fast
I would like to see someone test 16 inch wheels and lowering the car.
Razz is offline   Reply With Quote
The Following User Says Thank You to Razz For This Useful Post:
p911gt3 (08-10-2012)
Old 06-29-2012, 11:19 PM   #4
poormans_LFA
FT86Club.com O.G.
I'd probably do 225/45 all around, either 17" or 18"
Old 06-29-2012, 11:23 PM   #5
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
That's cool. I want to know what kind of times they would see with a 17x9 wheel with dunlops or even hankooks. Keeps the wider tire but not the gearing issue of the 18s.
I also have a set of 225/45/17 dunlops and kooks that I autocross with.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-29-2012, 11:43 PM   #6
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
So that -2.3second gain WOULD have beat the Mustang V6 GT with track package at Willow Springs?
eriktherod is offline   Reply With Quote
The Following User Says Thank You to eriktherod For This Useful Post:
Old 06-29-2012, 11:57 PM   #7
Proud of BOXER
Drives: 74 Toyota Celica ST
This test is somewhat misleading. When they plus sized the tire, they changed the gearing. The new tire is about 20mm taller than the 17" size. If they wanted a more comparable comparison, they should've run 225/40-18s, which would still be 11mm taller. Also, this doesn't take into consideration the weight of the larger Advans.
Proud of BOXER is offline   Reply With Quote
The Following User Says Thank You to Proud of BOXER For This Useful Post:
FreshFRS (01-22-2013)
Old 06-30-2012, 12:08 AM   #8
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
So a TL;DW would be.......
225/+45/17? and for 18's the same?
Snoopyalien24 is offline   Reply With Quote
Old 06-30-2012, 12:25 AM   #9
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
For reference the Mustang V6 track pack comes with:
Pirelli P Zero P255/40ZR-19
220 AA.
A much closer tire match to the Star Specs they put on the BRZ.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 06-30-2012, 12:26 AM   #10
Proud of BOXER
TL;DW
There is improvement found on using stickier tires
Dunlop Direzza Star Specs are better than Michelin Primacy HPs
Video is not a helpful comparison between 215/45-17s and 235/40-18s.
Snoopyalien24 (06-30-2012)
Old 06-30-2012, 01:32 AM   #11
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Im rocking 245/40/17's on 17x8 rpf1's. Fastest lap time around my local track was 1.35.9 with the oem tires im hoping to drop at least two seconds in my next run this sunday. Videos will be posted for sure trying to confirm this.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 06-30-2012, 03:22 AM   #12
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
I am happy w/ my oem size tire w/ grippy RS3's
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 06-30-2012, 03:56 AM   #13
fistpoint
Drives: Supercharged Golf Cart
Lol, I just posted this.
fistpoint is offline   Reply With Quote
Old 06-30-2012, 08:27 PM   #14
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Say it with team: "Rolling Diameter"
Is anyone.. really anyone, surprised that stickier tires turned a faster lap time and "taller" tires affected gearing?
Road & Track: 5 minutes to a faster FRS (/BRZ) via Tires xjohnx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 11-18-2013 05:31 PM
Road and track vid DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-29-2011 09:00 PM
Road & Track: Scion FR-S Preview FutureFT86 Scion FR-S / Toyota 86 GT86 General Forum 3 08-29-2011 09:54 PM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 12:20 AM
Road & Track says 2013 Champion Scion FR-S / Toyota 86 GT86 General Forum 6 09-08-2010 11:33 AM
