#7897 |
Drives: None
So.... I'm not sure if this has been asked before or if it's just an all around stupid question but...
Can race fuel be used beneficially with this kit on a stock fuel system? While I do not have e85 readily available near me, I do have race furl extremely available. By pure chance, I accidentally noticed the shop 300ft from my office stocks VP race fuels, I don't know why, but they had pallets of it stored in an adjacent warehouse. Of course I'll talk with mike from moto east about this before I bring my car into him for revisions, but before I sound stupid to him, I'll just throw myself out to sound stupid to you guys. |
| The Following User Says Thank You to Njjawn For This Useful Post: | riboyster (04-14-2017) |
#7898 |
Drives: UK GT86
If by race fuel you mean high octane petrol, then yes it will work. However if you're car is tuned on 91/93 you'll see no benefit unless you're on track where the heat might make the car more knock prone.
.: Stealth 86 :.
#7899 | |
Drives: None
https://vpracingfuels.com/master-fuel-table/ Those are all the fuels available to me... If theres something similar to e85 (I believe c85 info here is) I might entertain the idea of tuning for that. The car is rarely driven, so I'm not overly concerned with having to deal with the hassle of buying fuel from these guys. |
#7900 | |
Drives: Stock
#7901 |
Drives: UK GT86
Octane is octane but E85 requires more fuel injected (around 30%) than petrol. You'd run really rich.
.: Stealth 86 :.
#7902 |
Drives: Stock
Yea but what about race gas what's the rate it's injected? I mean if it has a higher octane it should act similar to e85. This just means it burns slower, right so wouldn't it also need more fuel to be injected too. Please for give me! I know jack shit about different types of race gas.
#7903 | |
Drives: UK GT86
Ethanol has a lower energy content than petrol so requires a much larger volume to generate the same power. If you run E85 tune on petrol race fuel, it'll run ridiculously rich and make no power and run really poorly. In fact I doubt it would actually start. There is no problem running a normal 91/93 tune on petrol race fuel, you just don't reap the benefits of it.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | CarzCarzCarz (04-17-2017) |
#7904 | |
Grip>Slip
![]() In the picture above you can see how the actuator/arm/valve setup works. That being said, I agree with you. He should definitely leave it connected. It's there for a reason. |
| The Following User Says Thank You to xjohnx For This Useful Post: | riboyster (04-16-2017) |
#7905 | |
Drives: 2013 Scion FRS
The fact that you're using something that burns with an entirely different energy output means that you'll be injecting an entirely different volume of it. If you're going to use race gas, you might as well go to your tuner with a full tank of it and get the most out of your ignition timing that you can. Just remember that your car is going to pull as much timing as needed out of your tune when you go back to pump gas on the same tune, and you're going to notice it.
ScreamingElectron - SnakeShit Last edited by riboyster; 04-16-2017 at 06:32 PM. |
| The Following User Says Thank You to riboyster For This Useful Post: | CarzCarzCarz (04-17-2017) |
#7906 | |
Drives: 2013 Scion FRS Limited Edition
Feel free to hit me up if anyone has any questions when it comes to WMI applications. I'd be glad to help!
#7907 |
Drives: None
Having a few interesting problems....
1. Car starts, runs, drives great. I can get a pull or two out of it, and it pulls hard and doesn't seem to have any issues. Then, after a few minutes, ABS and the Traction control lights go on and stay on. The cars power drops off a bit. It will not return to normal until after the car is turned off/back on. This happens regardless of whether I'm driving hard, or I'm going easy on it. 2. I have a Jon Bond catch can mod on my supercharger (installed by JB). After a hard 2-4th gear pull, it seems to shoot a bit of oil out. Is this the catch can? maybe the nipples arent sealed correctly? Notes: I'm throwing a CEL for a Bank 1 O2 sensor. I checked it, its definitely plugged in. Code is P0031. |
#7908 | |
ScreamingElectron - SnakeShit |
| The Following User Says Thank You to riboyster For This Useful Post: | Njjawn (04-21-2017) |
#7909 | |
Drives: UK GT86
That's probably going to be a wiring issue or a new sensor needed. Do you have an EcuTek cable? You can log all the primary O2 sensor info if needed to check and test.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Njjawn (04-21-2017) |
#7910 |
Drives: None
^i don't think it would be a leak because it's not throwing a values code, it's basically saying the sensor is bad... I think
I checked the wiring/plug already and all seemed fine. I ordered a new air fuel sensor hopefully that does the trick. Could that be throwing the car into this "limp" mode? |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
