Old 04-14-2017, 03:33 PM   #225
armstrom
Drives: none
Keep in mind the edelbrock kit ships with a 3.25" pulley which is ~82mm. It uses the same Eaton core as the Harrop kit. Since both kits retain the stock crank pulley they should both produce similar amounts of boost for the same pulley diameter. Of course, the only way to ensure its safe is to put it on and have your tuner datalog a few pulls.
-Matt
Sent from my XT1650 using Tapatalk
armstrom is offline   Reply With Quote
The Following User Says Thank You to armstrom For This Useful Post:
Irace86.2.0 (04-16-2017)
Old 04-14-2017, 03:34 PM   #226
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Will it show gains, right? Thats the real question when you say work. More psi could just result in more knock causing the motor to retard timing which gives it less power, right? Im curious too. Where is the starving point for the injectors and where is the point where knock is an issue on pump gas?
Technically, yes. But if you just want to be able to cruise around on 91 aki before filling up on e85 for track day, you'd want to be able to not worry about detonation at all throughout the entire engine rpm range.
I am running 700 cc injectors to go with e85, but the car is also a daily. No sense in going crazy with a small pulley that doesn't keep things manageable on a lower octane fuel (though this may not be an issue at elevation).
Trefoil is offline   Reply With Quote
Old 04-14-2017, 03:43 PM   #227
Bfranklyn86
Drives: GT86 Harrop S/C
-Matt
Well I did not know that. So the edelbrock kit as it comes from the shop will be hitting around 11psi at the top of the rev range?
That should be all the proof we need that it's safe on stock internals, given I've not heard of any rods going with that kit. And I'm sure quite a few of those people run it on 91.
Trefoil, if you were dropping a pulley size you'd need a retune anyway so I'm sure your tuner could give you a safe tune for 91 at that boost level.
Bfranklyn86 is offline   Reply With Quote
The Following User Says Thank You to Bfranklyn86 For This Useful Post:
Trefoil (04-14-2017)
Old 04-16-2017, 01:04 AM   #228
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Makes you wonder what will come in the CARB kit if they ever get approved. And will they do a high boost CARB approved kit too.
Old 04-16-2017, 12:10 PM   #229
armstrom
Drives: none
Make sure to verify the edelbrock boost levels. While the rotors are the same the rest of the system is not. There could be more pressure drop over the edelbrock intake manifold vs the harrop or something else that prevents this from being a simple apples to apples comparison. Always check with your tuner and examine datalogs.
-Matt
The Following 2 Users Say Thank You to armstrom For This Useful Post:
CxG (05-03-2017), johan (04-17-2017)
Old 04-16-2017, 06:13 PM   #230
Bfranklyn86
-Matt
That's a good point. Depending on where I looked, it seems the edelbrock produces around 10-12psi as standard. The harrop with standard pullley produces 8.7psi, according to the manufacturer.
If VitViper got 11.5psi with the 85mm pulley, then maybe the edelbrock kit does have slightly higher post charge restriction vs the harrop. But I doubt there is much between them.
I'm itching to drop to the 85mm pulley and get a header.
Old 04-30-2017, 04:08 PM   #231
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
You can add one of my shop cars to the list! Installed Thursday, and will get tuning with Delicious Tuning next week. Starting with the standard largest pulley. The car will run primarily on e85, and will see a good mix of Track/Drift and some street driving. We paired the SC with Harrop's oil cooler as well.
Big thanks again to Harrop and Delicious Tuning for making this happen! Very excited to test the car out here in the CA heat.
The Racers Line is offline   Reply With Quote
The Following 6 Users Say Thank You to The Racers Line For This Useful Post:
COO86L (05-01-2017), funwheeldrive (05-01-2017), Irace86.2.0 (04-30-2017), johan (05-01-2017), kuczynskika (05-11-2017), PR138 (05-02-2017)
Old 05-03-2017, 06:24 AM   #232
socal_48
socal_48's Avatar
Drives: '15 FR-S RS 1.0
Any update on the CARB certification?
socal_48 is offline   Reply With Quote
The Following 2 Users Say Thank You to socal_48 For This Useful Post:
Irace86.2.0 (05-05-2017), ohmai18 (05-04-2017)
Old 05-09-2017, 04:44 AM   #233
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
On my side, I've just finished the installation of my harrop kit.
80mm pulley, RON98 fuel (equivalent to AKI93/94), full decat exhaust (ACE anaconda header) and tune by delicious.
I'll go to a dyno to assess the output, but I guess i would be at around 320 HP at the crank. The injectors are now at their limit, so I would need to upgrade them if i want to move to a 75mm pulley or smaller (75mm pulley being already ordered).
vgarcin is offline   Reply With Quote
The Following User Says Thank You to vgarcin For This Useful Post:
Irace86.2.0 (05-09-2017)
Old 05-09-2017, 01:27 PM   #234
Irace86.2.0
Pics or it didn't happen
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
kuczynskika (05-09-2017)
Old 05-09-2017, 02:26 PM   #235
Bfranklyn86
Very nice. Is that the larger or smaller ACE anaconda? Very interested to see your dyno numbers - I think you'll be more than 320 at the crank. Maybe partly dependant on if your exhaust is 2.5 or 3".
Will you worry about throwing a con rod when you are running the 75mm pulley?
Old 05-09-2017, 05:03 PM   #236
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
It is the larger version of the anaconda.
I'm a bit worried for the gearbox and the rods being honest, so i might delay the installation of a smaller pulley to next year (with a sequential gearbox and built motor)
Old 05-11-2017, 02:06 AM   #237
G-Unit86
Count me as another proud owner of this kit. Just got it back for the guys out at Moto-East on Monday. The car feels great on pump gas haven't had a chance to try her out with E85.
Thanks to Phil for all your help.
G-Unit86 is offline   Reply With Quote
Old 05-11-2017, 02:09 AM   #238
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Added!
kuczynskika is offline   Reply With Quote
The Following User Says Thank You to kuczynskika For This Useful Post:
The Racers Line (05-16-2017)
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
