Old 04-13-2017, 10:33 AM   #29
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Originally Posted by DarkSunrise View Post
Miss the smaller size of your BRZ or s2k?
This, I am curious. I had a '13 1LE. It was great, but I still preferred the feel of my S2000 and BRZs. I love the idea of the new 1LE, and I have driven a new SS spiritedly, but I haven't had the pleasure of driving a new 1LE.
Still, as impressive as the Camaro is in the corners for its size, 2800lbs still feels much better and is more fun (to me) than 3500+lbs.
Maybe in a few years I can get a used 1LE and strip it. But the Camaro still feels damn big, even if it is made lighter. Plus on my local 1.8 mile track, a lot of the HP is not as useable.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following User Says Thank You to brzaapi For This Useful Post:
funwheeldrive (04-13-2017)
Old 04-13-2017, 06:09 PM   #30
Denver1LE
Drives: 2017 Camaro SS 1LE
The new 1LE has specific suspension tune, Electronic limited slip differential, engine oil, differential and trans cooler, much wider tires and 3.73 gears. It is quite a bit different than the standard SS, and handles like it's on rails. Is it heavy, yeah, but its bigger w/ more power and you can't have eaten your cake and still have it in front of you , unless you have a couple 100 grand to spend.
Denver1LE is offline   Reply With Quote
Old 04-13-2017, 06:29 PM   #31
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Nah, the magic cake only costs about $80k.
https://www.flyinmiata.com/V8/ND.php
ineedyourdiddly
Old 04-13-2017, 09:54 PM   #32
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
For 80K I would absolutely be dropping off a base trim C7 Grand Sport at Vengeance for heads/cam/tune.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 2 Users Say Thank You to Deep Six For This Useful Post:
Summerwolf (04-13-2017), Yardjass (04-14-2017)
Old 04-13-2017, 11:40 PM   #33
No magnets, tho.
funwheeldrive (04-14-2017)
Old 04-14-2017, 01:33 AM   #34
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Too twitchy from the short wheelbase, ugly appearance, and definitely way too expensive. Give me an LS swapped twin or 240, or just a regular corvette any day.
Yardjass is offline   Reply With Quote
Old 04-14-2017, 03:06 AM   #35
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I was actually thinking of picking up a 1LE as a daily and occasional track car (and converting the FR-S to dedicated track car), but your comments are making me rethink whether I would even need to keep the FR-S. Not sure if you have other cars, but how would you feel about using your 1LE as both daily driver and weekend track car? Other than the higher cost of consumables, does the weight bother you on track? Miss the smaller size of your BRZ or s2k?
After I built the BRZ, I returned it to stock and traded in for an SUV. I decided go with an S2000. I've noticed that my Supercharged BRZ was only marginally faster than a bolt on S2000 on our local tracks (big straightaway at Ridge). I could barely pass the S2000 on the straightaway with my 268whp Rotrex BRZ and guess what? my friend who had a Rotrex Miata told me the same exact thing. I've found it unacceptable after all the money and effort that I put in on my BRZ. I wanted to try building an S2000 this time since Honda was making a healthier HP vs our FI cars on track environment. On the paper Rotrex BRZ or Miata, should've been a lot faster but they were not.
After I built the S2000, I was planning to keep it with the 1LE then I figured that I won't be driving the S2000 as much after I get the 1LE. I figured that I wouldn't be driving the (I don't want to say "lesser" let's say) slower car that much. I have too many cars in the household (with the SUV and the electric car). 1LE is definitely a lot better road car since both my S2000 and BRZ were loud after the mods, as I was trying to squeeze the last HP out of them reliably. With the 1LE I have no such concern about the power and the grip is insane for something that only costs $45k . I had a couple little issues with the 1LE but other than that it was blast to drive.
I really like lighter cars also Miata, BRZ , S2000s are all special cars but wish they had some more power. If the BRZ had an S2000 engine it would be the best of both worlds but that car doesn't exist :/
They also require good amount of modifications to run safely at track.
My Stock Camaro SS 1LE put 419whp/413 wtq on dynojet and I asked Bob from Drift office to put it against my Rotrex BRZ. You can literally fit a Stage 2 Evo in that gap
glamcem is offline   Reply With Quote
The Following 3 Users Say Thank You to glamcem For This Useful Post:
DarkSunrise (04-14-2017), funwheeldrive (04-14-2017), strat61caster (04-14-2017)
Old 04-14-2017, 03:18 AM   #36
glamcem
glamcem's Avatar
I test drove my friend's '14 1LE but the new 1LE is definitely felt a lot better and smaller than the previous car so it's really apples to avocados. Keep in mind the new 1LE surpasses the previous gen Z28 that comes with carbon ceramics, Multimatic DSSVs, 19" forged wheels and R comp tires. Add those options to the 1LE and the delta would be even bigger.
ORP is also very twisty with a lot of elevation changes where I would expect to see some disadvantage of a heavier car but it didn't feel like it I was definitely in your shoes until very recently but it changed my mind. I believe after a few more events I will get more confidence and the gap will be even higher. The steering feel and the new shifter and the e-diff is simply amazing, it's very easy to rotate and can put the power way easier than my C6 Grandsport. Unlike the GS, it's easier to catch a slide. I hope that helps.
The Following 2 Users Say Thank You to glamcem For This Useful Post:
brzaapi (04-18-2017), DarkSunrise (04-14-2017)
Old 04-14-2017, 03:36 AM   #37
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Only other good handling is miata newest one, rx7 2nd gen and some pricey Porsche for me.
I drove 2016 Cam. Feels bulky and like a school bus with tons of hp. Not my cup of tea.
Old 04-14-2017, 11:03 AM   #38
funwheeldrive
What issues did you have?
Old 04-14-2017, 11:05 AM   #39
strat61caster
No magnets, tho.
Magnets are a fad.
When can we get hyped about inerters?
Might vs. light
Well excuse me then.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Tokay444 (04-14-2017), Ultramaroon (04-14-2017)
Old 04-14-2017, 12:20 PM   #40
Denver1LE
How to make the ultimate Miata, use Camaro parts
The Following User Says Thank You to Denver1LE For This Useful Post:
Old 04-14-2017, 12:41 PM   #41
strat61caster
Well it's a >50 year old recipe.
Stating the obvious, but Chevy learned their lesson when they missed the boat the first time and now lets anybody use their powertrains which are awesome in terms of power density when you want 400+ hp.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Cole (04-17-2017), Ultramaroon (04-14-2017), Yardjass (04-15-2017)
Old 04-14-2017, 01:21 PM   #42
Magnets are a fad.
Right about now. Just googled.
FRS then Camaro SS 1LE? stock Scion FR-S / Toyota 86 GT86 General Forum 25 05-26-2016 04:07 PM
Camaro for FR-S whamslam3 Other Vehicles & General Automotive Discussions 26 06-18-2014 08:53 AM
frs or camaro failingpig FR-S / BRZ vs.... 77 02-22-2014 12:58 PM
FR-S vs 312 hp Camaro? Gill FR-S / BRZ vs.... 32 03-31-2012 07:56 AM
