Old 04-12-2017, 11:58 AM   #15
misterfly
Drives: Toyota 86 2017
Thanks Tcoat, i will check this when i will go in the parking after the job
misterfly is offline   Reply With Quote
Old 04-12-2017, 12:09 PM   #16
Si vous avez ce probleme vous le saurez sans aucun doute!
Old 04-12-2017, 02:35 PM   #17
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
When i was working at Toyota in 2014 i emailed Toyota many times in regards to this issue. No response from the north american head office. 3 years later they released the TSB when i am no longer with Toyota. Fuck my life.
Muaddib is offline   Reply With Quote
Old 04-12-2017, 06:53 PM   #18
number_Un0
Drives: 2013 FRS 10 series #0001
great! right when my warranty is over.
number_Un0 is offline   Reply With Quote
Old 04-13-2017, 01:49 PM   #19
sato
sato's Avatar
Drives: Dodge Patitas
Shit, I just got my TOB replaced under 5/60 warranty, but they used the 802 part. Well, at least they acknowledged something was wrong and I will have a solution TOB for purchasing when I have to replace it again at 100k miles.
sato is offline   Reply With Quote
Old 04-13-2017, 09:00 PM   #20
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Thanks for the info. I updated the TSB Thread to point to this thread for now. Can't wait until there is a PDF for this TSB. I got this fixed as well, but with an older parts
Old 04-14-2017, 08:06 AM   #21
Ragin Gti
Drives: '15 Subaru BRZ
Clutch squeak, grind, groan TSB released.
Subaru TSB 03-77-17, dated 1/3/17, for a "rotational sound from clutch release bearing". New TOB part # 30502AA150. Covers '13-'17 BRZ. New bearing installed in cars from VIN H*600825 and up.
Ragin Gti is offline   Reply With Quote
Old 04-14-2017, 02:39 PM   #22
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Well, no pdf (yet) but here's the summary description from the techinfo.subaru.com website:
-Qte-
“Rotational” Sound from Clutch Release Bearing
This bulletin announces a change to the internal lubricating grease used during assembly of the clutch release bearing for BRZ models. In cases where drivers have a tendency to rest their foot on the clutch pedal, doing so can cause the bearing to overheat. As a result, the grease inside the bearing can break down and over time, cause a “whirring” or rotational-type sound to develop. The new clutch release bearing contains a grease which is more resistant to heat while maintaining proper lubrication.
-Unqte-
PWBRZ is offline   Reply With Quote
Old 04-14-2017, 03:52 PM   #23
exE36M3
Yikes 3.7 hours... NorCal dealer labor rate is about $250/hour.
If you guys have this issue - get into the shop NOW. Out of warranty looks like an $800+ fix!
exE36M3 is offline   Reply With Quote
Old 04-14-2017, 04:54 PM   #24
Ragin Gti
$250 an hour?!? Holy Cali pricing. 😳
Old 04-15-2017, 01:33 PM   #25
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
Thank you! I was in the shop last week and they wanted to change my pedal assembly. I am going in with this TSB number and get this thing fixed with updated part.
Ethereal05 is offline   Reply With Quote
Old 04-15-2017, 02:28 PM   #26
Ragin Gti
There is also a TSB for a creaking noise from the pedal assembly.
Old 04-15-2017, 07:49 PM   #27
Ethereal05
Ethereal05's Avatar
Interesting. I am certain it is coming from the bell housing but I'll have them replace the pedal assembly first and if it continues move on to this. Thanks. Would you happen to have the TSB number for the pedal assembly creak?
Old 04-15-2017, 10:46 PM   #28
Ragin Gti
Definitely two different noises. The clutch pedal will make noise without the engine running. The throw out bearing only makes noise if the engine is running. I can find the pedal assembly TSB number.
Clutch pedal loud squeak Neekowahhhh Issues | Warranty | Recalls / TSB 617 09-18-2024 01:54 AM
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
