Old 04-07-2017, 09:40 PM   #1
jarrensandoval
Drives: Scion Fr-S
Code P013A! Please help
Recently this code came up and it reads "oxygen sensor slow response rich to lean bank 1 sensor 2."
Has anyone experienced this before? I got my car tuned recently at Church automotive and it was explained to me that it could be a bad o2 sensor or maybe an exhaust leak.
Any ideas on how to fix this ?
jarrensandoval is offline   Reply With Quote
Old 04-08-2017, 12:12 AM   #2
steve99
Drives: FT86
You would need to do further diagnostics via logging and look at the afr readings of the front and rear 02 sensors and compare, with commanded AFR. also look for high LTFT.
If you have no devices to log ecu parameters then take it to a shop
Or just take a punt on the rear 02 being faulty
Code P013A indicates problem with rear 02 sensor, but it could be exhaust leak or cracked header, or a multitude of other issues
Old 04-11-2017, 12:56 PM   #3
jarrensandoval
Drives: Scion Fr-S
Appreciate the response. I had it checked out and discovered that my ethanol sensor is actually plugged into the port where the original o2 sensor would be plugged into. I had the delicious FNG tune before and never encountered this problem until I recently had my car dyno tuned . I'm assuming that the code just has to be deleted since I'm not using an o2 sensor there .
Old 04-11-2017, 03:32 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, delete the DTC.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-11-2017, 05:17 PM   #5
steve99
Drives: FT86
Hmmm,
Assumed the tuner would have know that if it was rear 02 connected flex kit :-)
If they fitted a flex kit using the rear 02 sensor as input then the tuner needs to disable the rear 02 associated DTC in tune and also disable the rear 02 afr corrections.
I can understand the tuner overlooking a DTC disable but once you queried them on the CEL code/DTC they should have immediately tweaked to the problem if they fitted flex kit and/or tuned car with kit fitted
Simply clearing the code with a code scanner wont fix problem, needs to be done in tune.
jarrensandoval (04-13-2017)
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
u0115 code? ThisGuy919 Issues | Warranty | Recalls / TSB 1 11-11-2013 12:09 PM
