Old 02-25-2017, 03:54 PM   #43
Crashdummy
too much is never enough.
Crashdummy's Avatar
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
Since its been in storage for the winter, had time to install the Velox Transmission Tunnel Cover that's been sitting on my shelf since November. >_<
Velox Transmission Tunnel Cover with custom made 3rd panel
Custom 3rd panel made out of aluminum to finish covering the tunnel
Now to fix the front end from hitting a
furry 14lb bowling ball, on my way back from the SEMA show
more in that later
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon
Nanako's Mod Thread
Crashdummy is offline   Reply With Quote
The Following User Says Thank You to Crashdummy For This Useful Post:
DustinS (04-10-2017)
Old 02-26-2017, 02:11 AM   #44
Crashdummy
Crashdummy's Avatar
Racoons suck
In November, on my way back from an Epic 6,249 mile road trip (Sheboygan, WI, to Portland OR, then down the PHC to LA and then over to the SEMA show, then back to shoebottom) I hit a furry 14lb bowling ball.
This will not buff out......
At least I did recover the Decepticon emblem
When the INS adjuster was here, he was saying this would all be easy to replace and not cost that much. lol
A 20 min estimate turn in to him being here 3.5 hours. lol Evidently they have/had no experience with the RS 1.0, cause once he phoned it all in they were all in a tither.
If it was not for the pics of the remnants of the coon, they were trying to insinuate that I hit a curb or a parking block.
Anyhow, new bumper cover and grill and misc other parts are on the way. They are having me send out the front spoiler to have a repair attempted. IDk how that's going to look, anything less then perfect, it will be rejected.
In the mean time, since the font bumper is off, time to install a Mishmoto Oil Cooler and the Greedy Air Intake Snorkle that's sitting on the shelf.
Laterz
Nanako's Mod Thread
Old 03-03-2017, 10:59 AM   #45
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
Laterz
Love the build and sorry to hear your rs1 lip was busted! those things are rare indeed
spicyricecake is offline   Reply With Quote
The Following User Says Thank You to spicyricecake For This Useful Post:
Crashdummy (03-03-2017)
Old 03-04-2017, 11:00 AM   #46
norcalpb
norcalpb's Avatar
Damn nice undercarriage. Did you notice a difference during highway speeds with drag/noise reduction?
Old 03-04-2017, 11:43 AM   #47
Crashdummy
Crashdummy's Avatar
Yes, less noise and gained about 2mpg. The car feels more stable at highway speeds and in cornering too.
Nanako's Mod Thread
Old 03-20-2017, 11:57 PM   #48
Crashdummy
Crashdummy's Avatar
While waiting on the bumper cover and front lip to be painted from the racoon damage, had some time this weekend to install the some parts!!
Mishmoto Oil Cooler
Greddy Air Intake Snorkel
Replaced the damaged Hella Horns
Replaced Condenser bug screen
Mishmoto Oil Cooler
The oil cooler was pretty easy install, fun part was getting the lines in a position they were happy about. Not easy bending braided lines, a lil heat from a heat gun helps.
Chose the thermostat sandwich plate at 185/F
Drilled out the drain holes in the lower radiator box panel. They were totally clogged with bugs and crap.
I
cut about an inch off the snorkel so it doesn't hang down so low, to block the oil cooler. left it just low enough to be in position to catch the air flow.
Took some 3/4 in velcro strip and used it as a gasket. The stuff the came with the snorkel was a joke
Fits nice and tight for no leaks. Also channeled out the styrofoam bumper cover support for the snorkel
New Condenser screen
Wating for its clothes
damn racoons
Nanako's Mod Thread
Old 04-10-2017, 02:49 PM   #49
Crashdummy
Crashdummy's Avatar
Front bumper is finally on, now waiting for the front lip to get redone. Was not even close to factory look.
Cant wait for this hole racoon saga to end!!
Nanako's Mod Thread
Old 06-02-2017, 10:41 AM   #50
jorgerendonjr
Drives: Frs
Finally had some time to get a few more things done!
Rear Arm Rest
Courtesy light in doors
Custom Ghost Lights in doors
Red Floor Lights
All the stuff laid out
Rear Arm Rest
Pretty simple!
remove seat and unbolt the 2 10mm bolts for the console and pull out the arm rest
The factory glue was not holding so I re-glued it
Installed
Courtesy Lights and Ghost lights
B+ and Ground ran through door boot
Courtesy Lights and Ghost Lights mounted and wired in the door panels
Red LED floor lights for front and rear foot wells
Put a few coats of VHT Nightshades to knock down the brightness
Since there was nowhere to mount them, I made custom brackets for them
Front Drivers
From the Fuse box to the OBDII support bracket
Pass Front
JB Welded this one to the 2 flat spots on the blower assembly
Drivers and Pass Rear
Mounted both to the flap that runs down from the backrest to under the seat, zip ties do the trick. Then ran the wire along with the factory harness.
Finished!
The set up:
Each side is wired to the factory door switch at the BCM and diode isolated
Drivers door opens - Ghost lights, Courtesy light come on there side only, all floor lights on
Passenger door opens - Ghost lights, Courtesy light come on there side only, all floor lights on
Park lights - All Floor lights come on
More things in the works....................soon!
laterz
Hi friend sorry for the late reply, but do you have the part number for the center arm rest in the back seats? Or a link to purchasing it
jorgerendonjr is offline   Reply With Quote
Old 06-02-2017, 02:10 PM   #51
Crashdummy
Crashdummy's Avatar
replied to your pm
Nanako's Mod Thread
Old 06-02-2017, 03:10 PM   #52
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
Talking
with that mesh screen behind the grill looks real nice. i like how it makes things darker aha. im a noob and dont understand what it does though? did you just DIY it? my frs is black and i think this would look pretty sleek and stealthy
ImAdopted is offline   Reply With Quote
Old 06-02-2017, 11:42 PM   #53
Crashdummy
Crashdummy's Avatar
It stops any bugs or other road debris (rocks, dirt chunks, etc) from hitting and damaging the Hella Horns, oil cooler and AC condenser.
Nanako's Mod Thread
Old 03-17-2018, 09:02 PM   #54
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
Did you mention anywhere how you got the fogs to come on with the parking lights? I have an 860 Special Edition with the factory LED fogs and I'd like to have them work independently of the headlights.
Aipex8 is offline   Reply With Quote
Old 03-22-2018, 01:05 PM   #55
Crashdummy
Crashdummy's Avatar
Used a relay off the parking lights wire out of the BCM to trigger them, along with the dash light.
Nanako's Mod Thread
Old 04-07-2018, 01:42 AM   #56
Crashdummy
Crashdummy's Avatar
Man its been a year since I did anything to her!!!
Well I am changing that!
Next phase of the interior is starting.
Being a Release Series 1.0, I am going to put my vision as to how the interior should have been made from the factory.
It may have added a lil more cost to it, but I sure ppl would have paid for it.
First up:
Black Suede headliner
And a teaser:
Hand stitching takes time...
Good things are coming.............
Nanako's Mod Thread
new2subaru (04-07-2018)
Fr-s release series 1.0 Q&A Ankit BRZ Photos, Videos, Wallpapers, Gallery Forum 7 12-30-2015 06:15 PM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Exterior Parts (Aero, Lighting, Etc.) 0 05-12-2015 12:15 PM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Audio/Visual, Electronics, Infotainment, NAV 0 05-12-2015 12:14 PM
Release series MemphisR Scion FR-S / Toyota 86 GT86 General Forum 33 07-11-2013 07:58 PM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 02:02 PM
