#15 |
Drives: nissan frontier, DGM MT BRZ
Writeup!!
#16 | |
Drives: 2013 WRB BRZ
Any luck finding the ground? I am hoping to do this mod myself when I find the time...
The Beauty of Rear-Wheel Drive
2013 WRB BRZ Semi-automatic 2011 WRB WRX Sedan (sold) |
#17 |
I Love custom Turbo kits
Drives: Limited BRZ
I actually did not have time, (working 72 hours a week) but I tried doing some test, and I think grounding the e-brake will not accomplish what I want, which is full functions of phone while driving. I think this is GPS based, so as soon as the car gets moving, the phone capabilities are limited, it doesn't matter if the e-brake is engaged.
#18 |
Drives: 2013 BRZ Limited
The ground is on 10-pin power/speaker harness...
12--34 5678910 Pin 7 is Ground. I just cut the grey wire on the 16-pin rear camera socket (i.e. where the e-brake lead is), and extended the wire from the stereo side connector to the above pin 7 and electrical taped the far side grey wire so as to not short out anything. |
#19 |
Good info! Does this allow you to play video from USB while moving?
#20 |
#21 |
Subaru BRZ Limited Wiring Diagram / Fujitsu Ten Head Unit
10-pin power/speaker harness 1 2 - - 3 4 5 6 7 8 9 10 (orientation: viewing pins on car's factory plug, wires pointed away from you) Code: 1 RF+ 2 LF+ 3 +12V Accessory 4 +12V Battery/Constant 5 RF- 6 LF- 7 Ground 8 Power Antenna (provides power to Subaru's antenna booster amp) 9 [NC] {amp remote turn-on signal on Toyota HUs, not Subaru} 10 Illumination+ 6-pin power/speaker harness 1 - - 2 3 4 5 6 (orientation: viewing pins on car's factory plug, wires pointed away from you) Code: 1 RR+ 2 LR+ 3 RR- 4 [NC] 5 Dimmer (Illumination-) 6 LR- 28-pin SWC/aux/mic harness 1 .. 14 15 .. 28 (orientation: viewing pins on car's factory plug, wires pointed away from you) Code: 1 [NC] 2 Reverse Gear 3 Illumination Dimmer Cancel (Bright mode) 4 Mic ? (separate, possibly ground) 5 Mic ? (twisted w/ 19) 6 Ground (not connected to mic) 7-14 [NC] 15 [NC] 16 [NC] 17 VSS 18 [NC] 19 Mic ? (twisted w/ 5) 20 [NC] 21 SWC Audio (Seek, Volume) 22 SWC Mode + Phone 23 SWC Common 24 [NC] 25 Aux enable 26 Aux audio Right 27 Aux audio shield/ground 28 Aux audio Left 16-pin rear camera socket 1 ... 8 9 ... 16 (orientation: viewing pins on car's factory plug, wires pointed away from you) Code: 4 ? 5 ? 6 Parking brake 7 Camera +6V supply (HU sends power to OEM Camera) 8 Camera Video In 15 Camera Detect (connect this to chassis ground) 16 Shield/ground |
| The Following 7 Users Say Thank You to xcelir8brz For This Useful Post: | Cornerman (07-01-2012), dangerfield (10-02-2012), Proud of BOXER (07-02-2012), Scooby South (04-13-2013), Thefuzz (07-06-2012), Vlad (10-17-2012), wheelhaus (08-11-2012) |
#23 | |
Radio wiring harness guru
Drives: 1996 SVX L AWD
It's about time I weighed in here...
The Beat-Sonic TVK-54 has 24-pin connectors. It will not work with the Fujitsu Ten nav HUs in 2012-up Impreza and Forester, and 2013 BRZ and FR-S. Quote:
However, I seem to recall a 2012 Impreza owner with the Fujitsu Ten nav (model FW602US) saying that grounding the parking brake input did not unlock everything that is disabled while driving. An easy way to verify is to pull up your brake lever just far enough to light the BRAKE light on the dash. Then have a passenger look for things that are still locked out while you're driving. We theorized that the FW602US was also using the speed signal (VSS) to detect motion for the lock-out. A simple way to test that is to just unplug the 28-pin harness. You'll lose your microphone and aux input, but you should still be able to test everything else. I've seen BRZs with model numbers FA601US (here) and FM601US (here). Does the FR-S have the same models?
#24 |
The pin-out tables that xcelir8brz posted are for the 2012 Impreza Fujitsu Ten nav, model FW602US, from my NASIOC post here. (I'd appreciate credit and a link)
There are several differences in the BRZ and FR-S:
And can anyone post pictures of the back, factory harnesses, and the label on the top?
Last edited by SVXdc; 12-23-2012 at 12:59 AM. Reason: corrected to show differeneces between FR-S and BRZ antenna control |
| The Following User Says Thank You to SVXdc For This Useful Post: | xcelir8brz (06-30-2012) |
#25 | |
Drives: Limited BRZ
#26 |
| The Following User Says Thank You to xcelir8brz For This Useful Post: | Sportsguy83 (06-30-2012) |
#27 | |
#28 |
Drives: 2013 DGM BRZ
I grounded the grey wire as mentioned earlier, the movies still played while the parking brake was down, however the screen turned blued as soon as went passed 3 mph. Did I miss something?
