Drives: 2013 Raven FR-S
Best quality throwout bearing?
So, at only 59,000 miles the throwout bearing on my FR-S is going out. Planning to drop the tranny soon and replace the entire clutch while I'm in there. Just wondering, are there any better quality TOB's available than the OEM one? I don't want to deal with this again for a long time, so I want to use the best one I can find.
| The Following User Says Thank You to smg1138 For This Useful Post: | ajcarson11 (04-04-2017) |
#2 |
Drives: 2013 Subaru BRZ Limited (Black)
^^^ Bump. I'm interested in this as well. I can hear my TOB making a noise when the clutch is engaged (pedal not depressed). It's a light whirring noise which doesn't sound alarming and is barely audible... but I bet its a sign of things to come.
| The Following User Says Thank You to ajcarson11 For This Useful Post: | jonperezinsd (06-14-2019) |
#3 |
Drives: 2013 BRZ Limited
I'm not sure any kit comes with a 'better' throw out bearing as they all look like OEM replacements.
If anyone knows of a better option regarding that part let us know! |
#4 |
Mentat
Drives: 2013 Scion FRS 6MT
You can try SKF N4111.
| The Following 3 Users Say Thank You to Muaddib For This Useful Post: |
#5 |
#6 |
Mentat
I recommended a friend of mine with that when he was replacing his clutch. No issue yet. I used to work in the Marine industry and SKF make good bearings.
#7 |
Drives: '14 BRZ
Might as well add a Velox billet clutch fork to make it last even longer
#8 |
Because compromise ®
Drives: Red Herring
And their pivot.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Tcoat (04-05-2017) |
#9 |
Drives: Late 2014 Subaru BRZ
Billet fork and pivot is a must. Last week I bend my fork and caused gear lockout. Im running an extreme pressure plate from ACT and it was tomuch for the factory fork to handle.
Pauter rods are on order so the engines coming out anyhoot. I wish i didnt have to order from 5 different parts vendors to complete this build.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#10 |
Señor Member
The stock throw out bearing is an NTN which is a quality Japanese brand. SKF is a good Swedish brand. Both are quality brands so you can't say one will be better than the other on brand alone. It may be the bearing is under designed for our cars. What is it that actually fails on the bearing?
I sell bearings for a living. EDIT: With a bit of searching it seems a lot of Subaru throw out bearings have the same ID and running surface diameter. It may be possible to mod a WRX or even STi bearing to suit our set up. It will depend on the fork as those bearings seem to be wider.
1974 TA22 Celica
2013 86 GT Last edited by Turdinator; 04-09-2017 at 11:03 PM. Reason: Further info |
#11 | |
#12 | |
Drives: Crystal Black BRZ(Sophia)
#13 |
TechNINJA
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
I'll be putting in my 3rd TOB in the next week, along with the Velox fork and pivot. My last TOB was squealing after only a few thousand miles with a new clutch. I believe for those of us that have aftermarket clutches (I have an ACT Xtreme), if you don't have a stronger fork, the OEM at minimum, bends - putting uneven pressure on the bearing. Just my thoughts...
#14 |
Drives: 2013 FRS / 2013 427 Vert
Been running an ACT 6 puck the past 2 years with considerable track use. TOB started to squeal last month and I replaced it with an oem unit along with the Velox billet fork and pivot. Ordered a new friction disk once I saw how much wear was showing as well. Got it back on the street today and the difference in pedal feel really surprised me. Overall shifting is so improved I feel like it's a different car.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
| The Following User Says Thank You to Deep Six For This Useful Post: | Bonburner (11-03-2017) |
| Throwout bearing going bad | B-R-Z | Engine, Exhaust, Transmission | 40 | 09-08-2017 09:23 AM |
| Throwout bearing. | bdanisi | Issues | Warranty | Recalls / TSB | 54 | 07-17-2016 06:13 AM |
| 63,000 and throwout bearing ruined everything | riironman | Issues | Warranty | Recalls / TSB | 188 | 05-14-2016 11:02 AM |
| Throwout bearing? | RavioliG | Issues | Warranty | Recalls / TSB | 3 | 10-31-2015 01:17 PM |
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 02:17 AM |
