Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-28-2012, 06:19 PM | #57 |
Scrape Master
Drives: Goal: Oldest FRS State Side
300 whp or 250 wtq what ever comes first. If a turbo/supercharger isent to much I will go for that. Im gussing to get to my goal i will need.
-Exhaust -Intake -Headers -HKS Gasket (low compression) -Pistons -Maybe injectors and fuel pump? |
06-28-2012, 06:19 PM | #58 | |
Drives: First SWP BRZ-L
hmm. We've been watching the AFRs with the headers both on the dyno and on the street- they are pretty much the same as stock. I don't think it's a worry. At least with the nameless. I wouldn't run that junk chinese one we've seen around the forum, it looks terrible and might throw a CEL and/or mess with the motor a bit. I know I probably sound biased, haha. But it's true, I've had headers on the car for a week with zero issues. no limp mode, no CEL, nice and strong- did over 100 WOT pulls on it during the track day with no issues. That was all after several dyno pulls, data log events, and letting the car idle for a while, so I felt safe doing it. You get what you pay for I guess.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
06-28-2012, 08:14 PM | #59 |
I Love custom Turbo kits
Drives: Limited BRZ
If you don't go for turbo and leave the car N/A, lowering compression will only result in loosing power, no gains at all. The gasket would be needed when you want to run higher Lbs. on forced injection.
06-28-2012, 09:29 PM | #60 | |
That Guy
Drives: 2013 asphalt FRS MT
That said,I went out and checked the tag on my alternator and it says 12V 130A umungst other numbers. I wouldn't take that as gospel but it seems to me that it's a 130 amp alternator, no problem there. That only leaves the drivers in the ECU. Well and the wiring, but I'm not worried about that. |
06-28-2012, 10:22 PM | #61 |
Scrape Master
thanks for the info. So if i stay NA i will want the higher compression one?
06-28-2012, 10:25 PM | #62 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
06-28-2012, 10:38 PM | #63 | |
Pedals over Paddles.
Drives: Celica GT-S | 89 Supra | 07' Accent
Also, there are other members saying they want 300+whp and i don't think they've received the same level of scrutiny you've kind of aimed toward me. My Celica is stiff and gutted and i don't have a problem with it.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily |
06-29-2012, 12:15 AM | #64 | |
Drives: Limited BRZ
There are different ways to go about it, but as a general rule, if your car is already 12.5:1 compression ratio and you are building an N/A setup, there is no gain in lowering the compression ratio, the only result is lower HP. The benefit of lowering compression ratio is it allows you to boost to higher psi. Example, both cars with engine built equally, only difference is 9:1 ratio and the other is 12.5:1, is that the 9:1 car will be able to hold higher boost without risking breaking it. This is in very simple terms there are more things into it, but it gives you an idea. |
06-29-2012, 12:57 AM | #65 |
Drives: 2013 Scion FRS/whiteout,MT
mine is 750hp by next year, we will see if we can meet that goal
06-30-2012, 11:03 AM | #66 |
Drives: MX5
200whp. NA setting, 9000+ rpm redline if possible.
250whp. Supercharge if possible. 7500 redline. adding less than 30 lbs of weight. Your goals seem to be insane.... how can a 350whp/1200kg car be a everyday car.. that's a horsepower monster. |
06-30-2012, 11:04 AM | #67 |
Drives: MX5
06-30-2012, 11:10 AM | #68 |
I want around 300bhp, or just over a 10:1 power to weight ratio. That will cure the "it doesn't make enough power" blues. without going overboard. My weapon of choice will be a supercharger. If companies are able to get 350bhp+ from an S2000, I don't think it too lofty to want an extra 80bhp from forced induction and other supporting mods without cracking open the motor. We'll have to wait and see what the aftermarket brews up! If it means changing out internals, I'll wait 'til I'm out of warranty and the car is near being paid off.
I'll have to decide between boosting my MR2 or the BRZ; I think I can only afford one. I'll probably throw cams and standalone in the MR2 and be happy with ~165whp and 2200lbs
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 06-30-2012 at 11:27 AM. |
06-30-2012, 11:14 AM | #69 |
Drives: MX5
06-30-2012, 11:17 AM | #70 | |
Drives: MX5
Similar Threads | ||||
100,000 Units Annual Goal for BRZ/FR-S/86 Announced by President of Fuji Heavy Indust | yajin | BRZ First-Gen (2012+) -- General Topics | 114 | 04-04-2012 04:24 PM |
ft86.com has some serious horsepower! | MrBRZ | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 03-22-2012 07:45 PM |
Pricing announced for Uk version. Question about Horsepower | maxeveland | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 02-24-2012 08:38 AM |
Top 10 Lightest 300 Horsepower Cars | Axel | Other Vehicles & General Automotive Discussions | 2 | 11-22-2009 02:23 AM |
