Old 04-03-2017, 08:01 PM   #3963
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
Who else is stuck on the C38 charger back order Hoping I get mine for my scheduled dyno day with tuner on the 19th
Canehda is offline   Reply With Quote
Old 04-04-2017, 07:39 AM   #3964
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by SoCalArgento View Post
Anyone have any experience with some of the aftermarket oil pans? Such as Moroso Baffle or the FBM Aluminum Cast Oil Pan?
I have the FBM oil pan on my new motor but the HKS EL header was not compatible so I bought a UEL to replace it.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 2 Users Say Thank You to Deep Six For This Useful Post:
CxG (04-04-2017), SoCalArgento (04-04-2017)
Old 04-04-2017, 03:45 PM   #3965
SoCalArgento
Drives: 2014 Argento FRS
Any thoughts are to it's performance? Or are you still putting together the motor?
I seem to have dented my oil pan pretty badly and debating if to change it to an oem or might as well upgrade if it's worth it.
SoCalArgento is offline   Reply With Quote
Old 04-04-2017, 06:40 PM   #3966
Deep Six
Deep Six's Avatar
It has a baffle designed into it and holds an additional quart of oil. It also has cooling fins built into the bottom of the case. I've had the car back running a couple of months now including two track weekends. The air temperature was cool due to the season. Regardless my oil temps maxed out at 230 degrees. I will be at Sebring the end of this month and it should be a lot warmer so we 'll see how it goes.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post:
CxG (04-10-2017)
Old 04-05-2017, 07:42 PM   #3967
mrg666
pessimistic skeptic
mrg666's Avatar
I am waiting for c30 ...
Old 04-05-2017, 07:45 PM   #3968
SoCalArgento
Thanks for the info, what forming gasket did you use? The Toyota FIPG or some other like permatex?
Old 04-08-2017, 01:46 PM   #3969
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
The belt on my c30 jrsc kit shredded. Does anyone know the part number for a replacement double sided gates serpentine belt? I cant find it anywhere
Thanks
Anomie is offline   Reply With Quote
Old 04-08-2017, 01:54 PM   #3970
dj2020
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
dj2020 is offline   Reply With Quote
The Following User Says Thank You to dj2020 For This Useful Post:
pbirmingham1988 (05-19-2017)
Old 04-10-2017, 09:18 AM   #3971
rns294
Drives: 13 BRZ
http://jacksonracing.com/product/fr-...rcharger-belt/
http://counterspacegarage.com/produc...belt-gt86.html
rns294 is offline   Reply With Quote
Old 04-10-2017, 02:26 PM   #3972
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Thanks
Can ship anytime. Make sure you check the alignment of your belt and pulleys. We've put on years and thousands of miles of tracking without tearing up a belt.
CounterSpace Garage is offline   Reply With Quote
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
CxG (04-20-2017), Jackson Racing (04-18-2017)
Old 04-11-2017, 12:03 PM   #3973
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Hi everyone
I installed the c38 kit a week's ago and I've broke up 2 belts... I don't know why I already change the tensiometer after the first broken belt but know I don't know why this is happening. Does anybody have thus problem before? Maybe something wrong in the instalation ? (It was installed by professionals). Something wrong with the kit or pulleys? Something wrong with the belts? I drive a 2013toyota gt86. I really don't know what to do now.
Toyota GT 86 is offline   Reply With Quote
Old 04-11-2017, 12:05 PM   #3974
Toyota GT 86
The belts didn't broke up totally, in both opportunities it broke up from the sides of the belt, looks like it is moving from its way in some part when I push hard the car...
Old 04-12-2017, 12:58 PM   #3975
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Something was installed incorrectly.
JDMChris is offline   Reply With Quote
Old 04-14-2017, 02:26 PM   #3976
gtengr
Drives: 2017 BRZ
I'm pretty sure I'll be going with this kit, but was wondering about using the high boost pulley on 93 oct and lowering the redline. Does anyone know what redline I'd want to run with the hbp to match the boost output of the standard pulley at stock redline? Any other thoughts? I'm planning to run it with an ACE CS400 header and Delicious tune.
gtengr is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
