| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Overlord
Drives: SWP 13 BRZ, 94 Miata
What about OZ Ultraleggera 17x8.0 +40??
I apologize if someone has already discussed this before, but i can't seem to find any information at all on the +40mm offset version of these wheels. I'm going to be buying a set a new wheels very soon to replace my stock wheels (it's a good time for me since i have to replace my haggard Hankook Ventus v12s anyway) and fell in love with the Ultraleggeras
. I came across these on Tirerack but i haven't been able to find any other discussion here on these. Does anyone have any info or thoughts on them/anyone using this offset at all? Any confirmed pics? Why i should get them or the +35? I've been going back and forth in my head between either these or the +35's. I'm primarilly focused on an OEM+ setup right now that's very flush or a tad under and hate not having good comparison pics between the two. I'm also currently on stock camber/suspension but will be swapping out to STI pink springs in a few weeks. Tirerack link for +40 is below (ignore the 325i/jetta in the links, it's a Tirerack "feature" ). I'd greatly appreciate anything you guys have!+40 https://www.tirerack.com/wheels/Whee...t+Silver+Paint +35 https://www.tirerack.com/wheels/Whee...t+Silver+Paint
"FR-S or BRZ, it doesn't really matter, they're the same to me. It's a matter of choice, like mass effect, but then the thought of boxer engines make my mass erect!" -The Roman
#2 |
Drives: 2013 Subaru Brz
I think I can help a little on this, I just put on a set of OZ Ultraleggera's on my brz, the specs are 17x8 +48 with a 245/45/17 tire. the only issue I have run into is slight rubbing on the front sway bar when i turn the last 5% of full lock. As for the look mine are sunken in a bit and not so much "flush" but its the same offset as oem wheels so it looks similar. I would think if you were to get the 17x8 +40 it would be a good fit.
#3 | |
Drives: 2015 BRZ
http://www.ft86club.com/forums/showthread.php?t=65113 Apparently they have stopped making these wheels in 17x8 +35. But to answer you question the 17x8 +40 will fit but a +35 would be more flush. EDIT: Ah yes, i missed the bolt pattern. OP you need 5x100 bolt pattern wheels Last edited by Vital; 04-05-2017 at 01:11 PM. |
#4 |
Drives: SWP WRX HATCHBACK
+40 Would not fit, wrong bolt pattern.
#5 |
Overlord
Oh shoot, my bad. Thanks for pointing that out guys! Sorry about the bad post.
| Wheel Directory: OZ Ultraleggera 17x8.0 +48 | Mageep | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 104 | 04-11-2021 12:03 AM |
| SoCal FS: OZ Ultraleggera 17x8 Black | Pacific Auto | Wheels and Tires | 16 | 02-14-2019 12:30 PM |
| FS: OZ Ultraleggera | 17x8 +35 | Black | smg1138 | Wheels and Tires | 8 | 12-11-2016 12:08 PM |
| FS Oz Ultraleggera 17x8 ET48 255/40-17 | Mingo | Wheels and Tires | 0 | 02-16-2016 06:06 PM |
| OZ ultraleggera - 17x8 with tires | BRZ-y | Wheels and Tires | 7 | 02-10-2016 06:36 PM |
