#365 |
The TSB was in October 2016 you don't have the new pump if you hear chirps. The look of the pump has changed also. Go back
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#366 | |
Drives: 2019 BMW ///M4
LOL jk.So your VIN falls into the applicability of having the fuel pump swapped, correct? If so, that means you have the old pump, not the new one. But the Tsb is a Toyota one, not a subaru one so I'm not sure how that works out.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#367 | |
Drives: '15 Subaru BRZ
Subaru has a TSB also. They are the same car, just serviced by two different manufacturers. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Ragin Gti For This Useful Post: | DaBoBo21 (04-02-2017) |
#368 |
Hail Magnet
Had the fuel pump for a bit over a week, couple hundred miles, warmer weather, no chirps yet. Stay tuned.
| The Following User Says Thank You to HunterGreene For This Useful Post: | funwheeldrive (04-04-2017) |
#369 |
Drives: Silver 2013 Subaru BRZ
Getting a new pump on Thursday, hoping it fixes the chirps. Seeming like its possible based on the replies in this thread.
#370 |
Drives: 2013 Raven FR-S
I can't get my fuel pump to start chirping again, so I haven't been able to do this yet. Knowing my dealership, they'll refuse to do it unless it's happening right then. It'll probably start chirping again as soon as the warranty expires. lol
#371 | |
Never thought we would be trying to make the damned things noisy.
| The Following User Says Thank You to Tcoat For This Useful Post: | funwheeldrive (04-04-2017) |
#372 | |
Or not.
#373 |
I will never change it unless it fails. I don't fix what ain't broke for the sake of a noise I can control by not buying certain fuels.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#374 |
Senior gif poster
Drives: 2013 Asphalt FRS
Sucks in Ca there is no 93 octane and anything higher than 91 is very hard to come by. Mine does the same thing, if its warm out she chirps at idle. I agree don't fix what isn't broken. Sure the noise isn't ideal but I think it adds character and doesn't seem to impact performance or reliability.
| The Following 3 Users Say Thank You to DandoX For This Useful Post: |
#375 | |
The TSBs do say that it does not impact the performance of the fuel system, just a cosmetic thing. |
| The Following User Says Thank You to Dialkyl For This Useful Post: | DandoX (04-04-2017) |
#376 |
Drives: Subaru BRZ
#377 |
Yep. They may all have the same octane but the levels of ethanol can vary. If you read the stickers on the pumps (at least here) it says "may contain up to 10% ethanol". I have no clue what the trigger level is but have no doubt that someplace in that range is the concentration that causes chirps at just the right temperature. If cool out I can use whatever I want with no noise but when over about 70 degrees then there are a couple of brands that are 100% guaranteed to wake the little guys up.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | JD001 (04-04-2017) |
#378 |
Funny thing is when I run E85 the crickets go away. If I run E10, especially in summer, they usually come right back. My best guess is E85 has extra lubricants that E10 doesn't
| DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump | ZeroTo86 | Engine, Exhaust, Bolt-Ons | 0 | 08-08-2016 06:39 AM |
| FS: Moto-East Flex Fuel Kit - OEM Fuel Pump | FR-Shred | Engine, Exhaust, Bolt-Ons | 1 | 05-16-2016 06:28 PM |
| Fuel system questions. Boost-A-pump/stock fuel lines for engine swap | Toxicmilk45 | Engine, Exhaust, Transmission | 4 | 12-14-2015 03:52 PM |
| Fuel pump | sw20kosh | Engine, Exhaust, Transmission | 1 | 12-10-2013 10:21 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
