Old 03-31-2017, 11:06 AM   #365
stevesnj
stevesnj's Avatar
Originally Posted by DaBoBo21 View Post
Took my BRZ (2016) to the dealership to have my fuel pump swapped out and they said it already had the new pump installed (my vin was on the list of vins to have the swap done). Whether it was true or not, I have had crickets since after break-in.
The TSB was in October 2016 you don't have the new pump if you hear chirps. The look of the pump has changed also. Go back
My 2016 Build thread
Old 04-01-2017, 04:08 PM   #366
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
You have a subaru, not a Toyota LOL jk.
So your VIN falls into the applicability of having the fuel pump swapped, correct?
If so, that means you have the old pump, not the new one.
But the Tsb is a Toyota one, not a subaru one so I'm not sure how that works out.
N1rve
Old 04-01-2017, 06:41 PM   #367
Ragin Gti
Drives: '15 Subaru BRZ
Originally Posted by Ragin Gti View Post
Subaru TSB 09-54-12R. '13-'16 BRZ, last updated 9/27/16. Some get just the pump. Some get the drive case and a left side rocker cover.
Subaru has a TSB also. They are the same car, just serviced by two different manufacturers.
Ragin Gti is offline   Reply With Quote
Old 04-04-2017, 09:50 AM   #368
HunterGreene
Hail Magnet
HunterGreene's Avatar
Had the fuel pump for a bit over a week, couple hundred miles, warmer weather, no chirps yet. Stay tuned.
It has priests in it?
Old 04-04-2017, 10:33 AM   #369
Dialkyl
Drives: Silver 2013 Subaru BRZ
Getting a new pump on Thursday, hoping it fixes the chirps. Seeming like its possible based on the replies in this thread.
Dialkyl is offline   Reply With Quote
Old 04-04-2017, 10:39 AM   #370
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I can't get my fuel pump to start chirping again, so I haven't been able to do this yet. Knowing my dealership, they'll refuse to do it unless it's happening right then. It'll probably start chirping again as soon as the warranty expires. lol
smg1138 is offline   Reply With Quote
Old 04-04-2017, 11:43 AM   #371
Mine won't do it unless it is over 70 degrees out and I put certain fuels in. Once it gets hotter you should be able to make it chirp.
Never thought we would be trying to make the damned things noisy.
Old 04-04-2017, 01:50 PM   #372
Meh, if this new pump actually runs quietly I may just grab one off of a salvage engine in a few years.
Or not.
Old 04-04-2017, 02:13 PM   #373
Or not.
I will never change it unless it fails. I don't fix what ain't broke for the sake of a noise I can control by not buying certain fuels.
Old 04-04-2017, 02:41 PM   #374
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I will never change it unless it fails. I don't fix what ain't broke for the sake of a noise I can control buy not buying certain fuels.
Sucks in Ca there is no 93 octane and anything higher than 91 is very hard to come by. Mine does the same thing, if its warm out she chirps at idle. I agree don't fix what isn't broken. Sure the noise isn't ideal but I think it adds character and doesn't seem to impact performance or reliability.
DandoX is offline   Reply With Quote
Old 04-04-2017, 03:08 PM   #375
Dialkyl
Mine was chirping even with 93 in it. It wasn't nearly as loud as some of them out there, but with having the warranty, figured it was worth getting replaced anyways. Worst comes to worst and it still has the crickets, but I got a new HPFP and work done under warranty instead of paying the cost of it. Tech said just the fuel pump was $600 + all the other parts + labor.
The TSBs do say that it does not impact the performance of the fuel system, just a cosmetic thing.
Old 04-04-2017, 03:38 PM   #376
JD001
JD001's Avatar
Drives: Subaru BRZ
I've noticed that fuel from different suppliers (same octane) makes a difference to frequency and intensity of chirping.
Old 04-04-2017, 03:43 PM   #377
Yep. They may all have the same octane but the levels of ethanol can vary. If you read the stickers on the pumps (at least here) it says "may contain up to 10% ethanol". I have no clue what the trigger level is but have no doubt that someplace in that range is the concentration that causes chirps at just the right temperature. If cool out I can use whatever I want with no noise but when over about 70 degrees then there are a couple of brands that are 100% guaranteed to wake the little guys up.
Old 04-04-2017, 04:09 PM   #378
smg1138
smg1138's Avatar
Funny thing is when I run E85 the crickets go away. If I run E10, especially in summer, they usually come right back. My best guess is E85 has extra lubricants that E10 doesn't
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 06:39 AM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
