Old 06-29-2012, 02:58 PM   #29
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by lordtakuban View Post
Does anyone know the correct Power Enterprise MAG II oil filter to use? Those come with magnets inside them already and are a really good filter. I use them on my MR-S and would like to continue to use them in my FR-S. I'm just having a difficult time finding out the proper one to buy. So far, based on some other cross-references, it looks like the OFII-04A is the correct one. But I am not certain.
Edit:
It could be either of these:
OFII-04A 65x80 (width x height in mm)
OFII-02A 65x70 (width x height in mm)
Both are: M20×1.5
The O2A allegedly replaces Subaru part number: 15208-A0130. That's not exactly the same as 15208-AA130. But I'm just trying to figure out the proper sizing. I suppose I'll just measure once I have the car and order the one that is the closest height then. The both should fit though.
The tall one should work. But see if you can get an answer as to the bypass valve pressure. If it's real low, you might be better off with the Subaru filters and a filter mag.
Originally Posted by Koji_Online View Post
Hey whatsup, when I look at the Fumoto valve, I'm trying to figure out where the oil comes out; is it on the side of the open valve (90 degree angle to pan) or does it flow out the straight opposite ende of the opening that goes into the pan?
The oil comes straight through the Fumoto valve. If you look at the picture of the F-108N you'll see where the oil comes out. The round part at 90 degrees is the pivot and spring housing for the lever to keep it closed.
The Following User Says Thank You to Draco-REX For This Useful Post:
Koji_Online (06-29-2012)
Old 06-29-2012, 03:01 PM   #30
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Smile
Awesome thanks! I was having negative thoughts already on if it came out that other way; with threads being different and all haha
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 06-29-2012, 03:27 PM   #31
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Good point. I'll be sure to check that out.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 06-30-2012, 07:22 AM   #32
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Thanks a lot Draco. The links are appreciated, it can be hard to find good tools and support parts.
Have you done an oil change on your set of ramps? Did you have any trouble with the front air dam clearing the slope of the ramps?
NRGBalanced is offline   Reply With Quote
Old 06-30-2012, 11:46 AM   #33
Draco-REX
Corner Junkie
Draco-REX's Avatar
At stock ride height the front air dam just grazes the ramp. Any lower, or if you want no contact at all, you can use a couple boards to get the front end up higher before your tires hit the ramp. Just a pair of 3/4" thick boards on top of each other are enough to get my lowered STI onto the ramps.
Old 07-05-2012, 06:23 PM   #34
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I'm gonna buy that oil jug. I've used a sealed drain pan with a spout for a long time but it is awkward and messy.
Does anyone know any good websites on which to order oil/ramps and other maintenance equipment? I went to Autozone today but they only had one type of 0W-20 and it was pricy. Also I never used ramps before because I never needed them so I'll need to buy those.
I did stop at Subaru today to buy an oil filter for kicks. I figured it'd be tough to get the right one at the auto parts stores still and taking the Toyo to the Subie dealership for an oil filter was funny to me. (that and I think it's pricier at Toyota) A couple employees from sales and service were outside looking at my car when I was done muttering to themselves how it's only a little different.
Chewie4299 is offline   Reply With Quote
Old 07-05-2012, 08:22 PM   #35
Draco-REX
Corner Junkie
Draco-REX's Avatar
Advance Autoparts (.com) should have everything you need. I know the stores out here stock everything. 0W-20 is harder to get. Mobil1 (not recommended for Subaru engines) and Castrol Edge Titanium. You can also use 5w-20, especially in the summer, the operating weight will be the same. I put 5w-20 Pennzoil Platinum in mine at my last oil change.
Old 07-06-2012, 07:21 PM   #36
Chewie4299
Spaceman
Chewie4299's Avatar
Hmm..... all I could find was Mobil 1 0w-20. I'll have to return it and get some 5w-20
Sent from my Galaxy Nexus using Tapatalk 2
Old 07-10-2012, 05:44 PM   #37
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Thanks Draco for the very helpful post. So what is the correct filter to use and washer (if we don't go fumoto)? You seemed to mention two different filters when discussing the magnets?
Oh, and do you need a special tool to tighten on the fumoto? I recently tried installing one during an oil change on a friend's car and we couldn't really tighten it because stuff was in the way.
Phaedrus29 is offline   Reply With Quote
Old 07-10-2012, 05:53 PM   #38
Draco-REX
Corner Junkie
Draco-REX's Avatar
There are two filters that fit our engine. The Subaru numbers end in 130 and 160. The 130 is a shorter and wider filter whereas the 160 is a taller and narrower filter. Both fit and both meet Subaru's standards for the engine. If you were to get a Purolator instead of the Subaru filter, you'd be looking at either the PL14459 (same as the 130) or the PL14610 (same as the 160). As far as the washer goes, a 16mm crush washer should be fine. A lot of Subaru parts departments will sell them with the filters.
Old 07-10-2012, 05:53 PM   #39
Draco-REX
Corner Junkie
Draco-REX's Avatar
I just use an open ended wrench. 19mm I think....
Old 07-10-2012, 06:18 PM   #40
Phaedrus29
Phaedrus29's Avatar
Thanks again. So is there any advantage to one filter over the other? I think I saw in another thread that Subaru might be discontinuing one of them?
Old 07-10-2012, 06:46 PM   #41
Draco-REX
Corner Junkie
Draco-REX's Avatar
If you're buying the Subaru filters, there's no difference. If you're getting another brand, I'd recommend the 14610 or equivalent. Aftermarket filters have MUCH lower bypass pressures (8-11psi vs 24psi), so you want as much filter element as possible to keep the pressure at the bypass valve as low as possible.
Old 07-10-2012, 07:52 PM   #42
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Thanks for reminding me about the Fumoto valve. I had one on my Elise and, especially for that car, it makes oil changes soooo much easier. Ordered!
I suggest you setup an Amazon Associates account and link to the Amazon product page. That way you can earn a little cash on an excellent recommendation!
cobrabyte is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
