Old 04-03-2017, 03:09 PM   #15
Originally Posted by pinetree View Post
Exactly, seems even with slight increase in power/torque with bolt on parts and tune, OEM seems to handle the job which is great.
However, does stage 1 have its merits and worthy upgrade or pointless unless you go boosted?
Been reading the forums all night, still can't decide lol
Stick with stock parts. Throwing unneeded "upgrades" at it serves no real purpose and can lead to other issues. The closer you stick to the stock set up the more reliable it should be (although obviously the stock TOB is proving to not be all that reliable).
pinetree (04-04-2017)
Old 04-04-2017, 03:37 PM   #16
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
Sounds like the best option is to stick with OEM.
Appreciate all the input, order has been placed, and I'm doing some shift springs and bushing upgrades while I'm under there. Thinking about that slave cylinder swap as well...
Thanks everyone!
pinetree is offline   Reply With Quote
The Following User Says Thank You to pinetree For This Useful Post:
Tcoat (04-04-2017)
Old 04-07-2017, 10:04 AM   #17
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Dropped my transmission last night, and, as I figured, the throwout bearing was toast. I really hope the TOB that came with the Exedy OEM clutch kit lasts longer than this piece of crap did.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
ajcarson11 (04-07-2017)
Old 04-07-2017, 10:44 AM   #18
Rougenite
Drives: Raven FR-S
Wow...kinda a thread jack but that JUN car made me drool.
Rougenite is offline   Reply With Quote
Old 04-08-2017, 01:01 PM   #19
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I love my ACT clutch, i kept it with the best disc style and streetlight flywheel, prolight can chatter and no true upgrade in noticeable performance. Puck clutches teld to hold more but also can chatter. Ill have to grab a dual clutch or a 6 puck here after my forged build is complete.
345ftlbs is ACTs best disc system
444ftlbs is ACTs best puck style.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-09-2017, 10:21 PM   #20
Turdinator
Señor Member
Turdinator's Avatar
I installed a Exedy heavy duty clutch and a Toda light weight flywheel five months ago. I have a header and OFT tune. I found the clutch has a sharper take up which in my opinion improves feel hugely, I would recommend it to anyone that finds the stock clutch a bit vague.
Disclaimer: It isn't the stg 1 exedy clutch however, part number is TYK-8536HD and may only be available in Aus and NZ.
Also I initially found the light flywheel a bit of a pain but once I adjusted the tip in enrichment as per steve99's suggestion in one of the OFT threads it has been a piece of cake to drive.
TL/DR From my experience a HD clutch and lightweight flywheel are worthwhile on a mostly stock motor.
1974 TA22 Celica
2013 86 GT
Old 04-30-2017, 10:04 AM   #21
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exactly.
Old 05-03-2017, 08:48 AM   #22
Rougenite
Drives: Raven FR-S
I got a 10.5 lb fltwheel. Only other mod is e85.
I think its worth.
DIY Clutch Replacement Supermassive DIY (Do-It-Yourself) Guides 217 08-27-2023 12:35 PM
Exedy OE replacement clutch. APEXIT53 Transmission and Driveline 2 04-08-2017 08:54 AM
clutch helper spring replacement. another way Sandy AUSTRALIA 5 08-02-2015 04:32 PM
Clutch replacement Thatguyjeremy Engine, Exhaust, Transmission 0 02-28-2015 04:22 AM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) — General Topics 1 11-19-2012 12:25 PM
