Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: 2013 BRZ Limited
Clutch replacement
Hi,
Having my clutch replaced later this week after having issues with the throw out bearing, and reading through the forums still can't decide which route to go. Have a BRZ '13, with about 70k miles. Car is N/A, headers, exhaust, intake, tune (OFT). Not sure what power car is pulling, but guessing not much from stock. Option 1: OEM clutch, stock flywheel resurfaced Option 2: Exedy stage 1, stock flywheel resurfaced Option 3: ACT HD street clutch, lighter flywheel Option 4: Something else? Help me decide! Car is daily driver, with maybe a few canyon runs a year. Also, it looks like the consensus is to get the Velox clutch fork as well, even with my application is it worth it? Any advice with this is much appreciated, need all the help I can get. Thanks! |
#2 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
I went option 3 with the Streetlite flywheel. Also went ahead with the Velox clutch fork and pivot while the transmission was opened up.
My impressions after 3k miles: I'm still getting used to the clutch, it grabs pretty hard which combined with the lightened flywheel makes taking off from a stop tricky for me. I have to rev a bit higher to get her going. Also, consider how much stop-and-go traffic you endure. Sometimes I wish I had the stock setup since it was so easy to drive in stop-and-go traffic. |
The Following User Says Thank You to dhuang For This Useful Post: | pinetree (04-03-2017) |
#3 | |
Thanks! |
#4 |
Exedy makes the oem clutch, so they are the same except the markup.
The Following User Says Thank You to swarb For This Useful Post: | pinetree (04-03-2017) |
#5 |
#6 |
I'd suggest you go with option #1.
If the clutch fork looks OK, why replace it (assuming you're putting back a OEM clutch and flywheel). humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | pinetree (04-03-2017) |
#7 |
Drives: 2013 Raven FR-S
My FR-S is just under 60k miles right now and I'm in the exact same situation. My throwout bearing has been making a grinding sound whenever I depress the clutch pedal. Tried to get Toyota to fix it under warranty, but they said clutches aren't covered. I'm torn between the Exedy OEM and Stage 1 clutch kits right now. I often run an E85 Stage 2 tune, so wonder if the extra torque warrants a stronger clutch or not?
#8 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
If you are NA you dont need a stronger clutch... get OEM replacement and call it a day.
The Following 6 Users Say Thank You to Cockatoo For This Useful Post: | ajcarson11 (04-04-2017), fika84 (04-03-2017), humfrz (04-03-2017), pinetree (04-03-2017), smg1138 (04-03-2017), Swisher Seattle (09-26-2022) |
#9 | |
However, does stage 1 have its merits and worthy upgrade or pointless unless you go boosted? Been reading the forums all night, still can't decide lol |
#12 |
Drives: 2005 Toyota Camry
If you're not going to clutch kick all day (i.e. drifting), OEM is plenty fine for your needs.
Clutch fork is only a need if you have upgraded pressure plate. |
#13 |
Anybody know if the throwout bearing is the same between the Exedy OEM and Stage 1 kits? I seem to remember reading somewhere the Stage 1 had a higher quality bearing. Dropping the transmission is going to be a PITA, so I don't want to do this again for a long time.
#14 | |
TALLY FT86
Surprisingly, I'm boosted with almost 240wtq and my low miles OEM clutch is doing fine... wont last forever obviously |
The Following 2 Users Say Thank You to Cockatoo For This Useful Post: | Tcoat (04-03-2017), Ultramaroon (04-03-2017) |
DIY Clutch Replacement | Supermassive | DIY (Do-It-Yourself) Guides | 217 | 08-27-2023 12:35 PM |
Exedy OE replacement clutch. | APEXIT53 | Transmission and Driveline | 2 | 04-08-2017 08:54 AM |
clutch helper spring replacement. another way | Sandy | AUSTRALIA | 5 | 08-02-2015 04:32 PM |
Clutch replacement | Thatguyjeremy | Engine, Exhaust, Transmission | 0 | 02-28-2015 04:22 AM |
Clutch/flywheel replacement? | bucket | BRZ First-Gen (2012+) -- General Topics | 1 | 11-19-2012 12:25 PM |
