Old 03-30-2017, 08:59 PM   #15
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Originally Posted by WolfpackS2k View Post
If you're talking about beating an S2000 from a standstill, then yeah, that guy didn't know how to drive properly.
Yup, S2k has a lot more wheel torque due to extremley high agressive gearing (4.8 i think?) and you can rev it 2000 RPM over the 86 redline. Powerband for those cars is similar to ours (all the power is above 6k RPM) however because of the extra 2000 RPM when they shift they get right back into the sweet spot. In our cars if you shift too early or too slow you hit that torque dip which slows us down.
But yeah i was only able to beat my friends AP1 AFTER my supercharger.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 03-31-2017, 01:47 PM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
All S2000's had 4.10 diff gearing.
Old 04-01-2017, 07:22 AM   #17
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I have uel header, full exhaust system, w/ e85 stg2 tune. Roughly 230HP.
I did a pull with my friend's s2000 on a straight line.
We had a similar 0-60 until we shift to 3rd gear, he starts slightly pull away by little.
But overall, 0-60 s2000 faster just by few inches different.
FR-Sky is offline   Reply With Quote
Old 04-01-2017, 05:49 PM   #18
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've done a rolling start drag racing against AP1 while I was on E85 and stock headers. By the time I shifted into third I was several car lengths ahead. Maybe the driver was slow, maybe that F20 was tired, who knows?
Intent > Content
Old 04-02-2017, 04:46 PM   #19
Lantana frs
Drives: 13 frs red
Csg Mike claims that his 86 will pull on a stock s2000. Driver can make a large difference. Dont forget the ap2 has a larger, higher revving motor. Who cares anyway?
Lantana frs is offline   Reply With Quote
Old 04-03-2017, 02:07 PM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Stock vs stock? Driver sucked in the S2K then. Stock vs stock the MR2T would be very close.
Since one car for the OP in this case isn't stock, it's kind of pointless to compare against a stock MR2. I'll meet him at a drag strip with my 94 MR2 Turbo, it's barely modified.. and faster then my RS..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-03-2017, 02:23 PM   #21
Lantana frs
Drives: 13 frs red
No, his car has ace header and flex fuel
Old 04-03-2017, 08:12 PM   #22
CSG Mike
CSG Mike's Avatar
My 17 BRZ can pull on a stock s2000, depending on what tires and wheels I have on.
A stock BRZ will pull on a stock s2000 in a narrow window of speeds.
No NA bolt-on BRZ has a chance against a S2000 with a test pipe and tune.
For the record, I own both a S2000 and a BRZ, and have clocked well over 100k miles in both platforms.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
brzaapi (04-04-2017), Cole (04-04-2017), Frost (04-04-2017)
Old 04-04-2017, 01:51 PM   #23
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Not that I need to validate CSGMike, but I also have a 17 BRZ running ACE/DTFF/E85 and I also have an S2000 with a berk test pipe, while running a canned tune off of Hondata.
As good as the BRZ with the ACE is, when the S2000 is surging above 6k rpms....there is no mistaking the difference in power and the acceleration.
So plus 2 for the S2k with tune and TP.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 04-04-2017, 02:17 PM   #24
funwheeldrive
I didn't realize the s2k responded so well to bolt ons.
Old 04-04-2017, 02:37 PM   #25
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I would defer to CSGMike on this, but it is my understanding that in NA form the TP (elimination of the OEM Cat) is by far the best bang for buck. It was worth it to me.
However, items like the header/manifold and cat back systems seem to help more with response and fleshing out the power band, more than giving big peak gains. But, I bet Mike could add more depth to the S2k bolt on mods.
Daily: Audi TT RS
Old 04-04-2017, 04:05 PM   #26
CSG Mike
CSG Mike's Avatar
It only responds to a TP, which is universal to any car. It's simple physics; you're removing the largest restriction in the intake/exhaust piping.
brzaapi (04-05-2017), funwheeldrive (04-04-2017)
Old 04-05-2017, 03:47 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You know that I've had both also, but it wasn't a 2017 BRZ not sure if they are faster not, but the 2013 BRZ didn't stand a chance against my 06 S2K, stock vs stock. Maybe with drag radials
IIRC 0-60 in the 13 BRZ was low-mid 6s range.Again, 2017 might be faster now. The 06 S2K was mid 5s.
Both slow to the current daily driver miss piggy...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-05-2017, 05:52 PM   #28
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Nope, the 2017 isn't really faster. Maybe some magazines were able to quantify something, but as a driver its nada. Now, I will say that it feels like the response is a little better, and the dip is still there. Vaguely different, but still there. Essentially the acceleration is the same, you just shift earlier.
Although my memories could be biased as of now, I have owned a 13, 15 and now 17 BRZ. So I have run the gamut.
Daily: Audi TT RS
e85, mr2, ost, s2000, tune
New Turbo Coupe Honda S2000 Sideways&Smiling Other Vehicles & General Automotive Discussions 95 08-31-2014 12:25 PM
FS: AP1 s2000 SCharged Canada Classifieds 0 03-14-2014 09:52 PM
Toyota 86 Turbo vs S2000 Supercharged (Race Video) hmong337 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 56 01-28-2014 06:56 PM
BRZ vs 86 vs S2000 Brzetto FR-S / BRZ vs.... 0 05-09-2013 01:54 AM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 11:46 PM
