Old 03-31-2017, 03:40 PM   #1
TheLowlyThird
Drives: '17 Toyota 86
Front End Links Rubbing
Hey guys, just a quick question - yes, I've already searched and Googled it - I just installed Tein Flex Z's on my car a little over a week ago and threw on some Perrin poly end-links thinking (hoping) they'd be shorter than factory, which they weren't. I finally lifted my car again yesterday to see where I was rubbing and it looks like the bolt head connecting the end-link to the coilover is rubbing my inside fender liner whenever I turn. I've already ordered adjustable end-links hoping that'll fix the issue, but has anyone run into this before and/or know of a solution? Thanks.
Running -2.3 camber up front if that helps any.
TheLowlyThird is offline   Reply With Quote
Old 03-31-2017, 03:44 PM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Do you have pictures of the rubbing spot?
I had this exact issue when i installed my Flex Z's but only on one side, How low is your car?
The rubbing only occurred while the car was tilted (not level) and turning the wheel
I was able to alleviate the rubbing by raising the car slightly.
VIP BRZ is offline   Reply With Quote
Old 03-31-2017, 04:24 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Raise your car or shorten your endlinks by the amount of lowering you have done.
Pat (06-30-2020)
Old 03-31-2017, 05:24 PM   #4
TheLowlyThird
I'll try to throw it up on the lift today. Mine rubs mostly when turning the wheel and especially entering parking lots with an incline. Are you on OEM end-links?
Old 03-31-2017, 05:39 PM   #5
VIP BRZ
VIP BRZ's Avatar
Yea OEM links, Sounded almost like a squealing (metal on metal contact).. and i could see the spot on the inside fender where the metal had been rubbed raw shiny by the back of the end link head.
But the Perrin endlinks are probably the most low profile option available..
I increased the ride height only a tiny bit and the oem endlink cleared. -3 camber.
How low is it? Are they maxed out at the lowest?
Old 03-31-2017, 05:49 PM   #6
TheLowlyThird
Mine sounds more like a plastic sound at the moment. I didn't see any rubbing elsewhere, that's the only thing I could find. I can feel it binding when making sharp turns. I'd say I've probably got another inch or so before they're maxed out.
Old 05-12-2017, 09:02 PM   #7
PNW FRS
PNW FRS's Avatar
FWIT... I also have coilovers on my FR-S - lowered about 1.25" and I had checked with Perrin about their solid End Links. If those are the ones you have, they are designed for use with OEM struts; not with aftermarket coilovers and a lowered configuration (this is per Perrin staff I communicated with). If used with non-OEM struts or coilovers, the Perrin guy said there could be "rubbing."
If your coilovers didn't come with adjustable End Links, you'll probably have to go with some aftermarket links like White Line KLCs... adjust them to your needs.'
Link to some info I recently posted...
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 05-12-2017, 11:55 PM   #8
norcalpb
norcalpb's Avatar
Lowering the car and adding camber is what makes them not wanna fit I think.
Here's mine on stock struts (well actually koni inserts) but still.
Old 05-13-2017, 11:21 AM   #9
VIP BRZ
VIP BRZ's Avatar
This is the exact same spot i had rubbing with my stock endlinks, lowered on Flex Z coils. Maxed. -3 camber
Once i raised the car slightly the problem was alleviated.
Old 05-18-2017, 02:47 AM   #10
Mackizzle86
Mackizzle86's Avatar
Camber plates will solve this problem while keeping your lowered height.
Mackizzle86 is offline   Reply With Quote
Old 05-18-2017, 11:05 AM   #11
wparsons
wparsons's Avatar
How will camber plates help? If anything, they'll make it worse (unless you're removing camber with them).
flickr
strat61caster (05-18-2017)
Old 05-18-2017, 01:24 PM   #12
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
hmmm i make slight squeaky sound if i turn right/elft with car not moving at all.
i also have flex z with perrin end links as well. i dropped 1.2 around though...i gotta check if mine touches that fender liner. i thought perrin endlinks just have that sound
Old 05-19-2017, 02:30 PM   #13
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Only way to 'clearance' the upper end link portion is to 1. raise the car enough or reduce negative camber to clear the end link, 2. relocate the position of the end link mount on the shock and reweld, 3. hit the portion of the frame rail with a ball peen hammer and repaint.
Intent > Content
Old 05-20-2017, 04:30 PM   #14
norcalpb
norcalpb's Avatar
I kinda just wanna take a regular hammer and smash the inner fender in like 20mm. Would you advice against this?
WTB: Front End Links sebastiansim NY / NJ / CT / PA 0 08-19-2016 01:48 AM
Drift alignment. rear toe problem and front sway bar rubbing trdric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-03-2015 01:21 AM
WTB front tie rod end links Devil 86 Want-To-Buy Requests 0 07-25-2015 12:21 PM
How to tell if front wheel is rubbing against strut? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-08-2013 09:54 AM
Fitted 9.5inch wide rims, on the FRONT.. No rubbing, no guard rolling :) WTF AUSTRALIA 32 03-27-2013 01:42 AM
