#29 | |
Drives: 15 BRZ LTD, 05 FXT
Only issue I had was the drivers side fender bolt snapping, I ended up having to drill it out, and helicoil it. It wasn't super stable, so I shortened the helicoil on the backside and added a washer and nut to distribute the force since they don't have a larger bracket like the BRZ does. I'd like to see them updated with a longer bracket to a second hole to avoid this, but the other side does seem very rigid, (and even held the hood no problem while doing the helicoil work!) Suffice to say, I love how the BRZ has a long bracket, I'd like to see that implemented on your other kits!
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | whataboutbob (03-19-2025) |
#30 | |
But I'm comfortable with the choice of the fender mount. We have had nearly the same fender mount design (and ball stud) out for the GD chassis for about 3-4 years before we released the SG hood struts. The GD chassis design even requires higher force struts due so of the GD cars having steel hoods heavier hoods, putting more force on the ball studs. Not a single failure to date either. The reason the bolt snapped (very common unfortunately), and some other companies fender mounts snap is that they corrode and weaken/get stuck. Tein's design was very well known for this. That is why we manufacture our own ball studs for that connection, cut from billet stainless. We literally try and think of everything, and test stuff out for months before anyone can get their hands on it. BTW, I'm jelly of that 6speed. Mine is an 04, and the 4.44s on the highway get old fast! Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | whataboutbob (03-19-2025) |
#31 | |
It's obvious how much thought goes into it, and I appreciate the effort. It makes sense that there isn't much room left! Mine is an 05, so it had the same 4.44 FD stock. It made it a total stoplight rocket, but I got a great deal on a blown motor full STi swapped and built RS with the 04 STi trans, R180, etc. Love me some 1-2 shifts
#32 | |
AutoX-10/10ths every run
UPDATE: Well after more than a decade, the hood struts lost their spring. Ordered a new set and received it today. Should be good for another 12-ish years.
#33 | |
Drives: 2017 BRZ PP, 2004 WRX
These might be a wear item in my case ![]() But they've been holding strong after 3-4 years of this use, so I can't complain. I will complain that when I bought them, one of the brackets was already missing powdercoating. Within a year they were starting to rust... and I don't even drive the car in winter.
| The Following User Says Thank You to cmiovino For This Useful Post: | whataboutbob (03-26-2025) |
| GrimmSpeed Review | Khalis | User/Vendor/Sponsor Reviews, Feedback, Comments | 45 | 03-06-2014 11:20 PM |
| Aussie members in the grimmspeed hood strut group buy - Click here!!!!! | RAN94A | AUSTRALIA | 52 | 03-06-2013 02:09 AM |
| B2designs FRS/BRZ Black, Polished and Carbon Fiber Hood Strut Kits | b2autodesigns | Exterior Parts - The Rest | 29 | 02-12-2013 07:45 PM |
| Hood Strut | mr2lor | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-22-2013 07:14 PM |
| Hood strut/prop | peenut1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-25-2012 11:35 PM |
