Old 03-28-2017, 05:07 PM   #57
frslee
Just drive it
Drives: 13' FR-S
go full throttle all the time.
Full throttle = 6MPG x 13.2 gallon = 79.2 miles per tank
frslee is offline   Reply With Quote
The Following 2 Users Say Thank You to frslee For This Useful Post:
mazeroni (09-05-2018), Tcoat (03-28-2017)
Old 03-28-2017, 07:22 PM   #58
Originally Posted by billwot View Post
...and the rate of heat transfer is directly proportional to the delta T between the 2 entities. So any heat added to the fuel will slow that rate at which the pump can give up its heat to the fuel.
Well, that is true ....... but you didn't solve the problem (answer the question).....
If you had a FR-S fuel pump (pumping fuel out), in the tank, with 12 gallons of gasoline, how long would it take to raise the temperature of the gasoline 1.0 degree C .
Allow me to get you started:
(or you can use @Overdrive 's method "The answer is: Imhotep is invisible, and the train will arrive in Nova Scotia in 27 hours".)
Old 03-28-2017, 08:02 PM   #59
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Well, its really a moot point because the flow of fuel through the pump provides adequate cooling. So the rate of transfer to the liquid in the tank is really not a concern.
But regardless, the unknown value for the calculation is the amount of heat generated by the pump (Btu/h).
BTW, the mass (and specific heat) of gasoline is not the same as it is for water.
BTW, weren't you an OSU Engineering grad?
billwot is offline   Reply With Quote
Old 03-28-2017, 08:08 PM   #60
Back row third from right!
humfrz (03-28-2017)
Old 03-28-2017, 08:50 PM   #61
True.
True, that is the unknown
True (just substitute gasoline for water in the equation)
Well, you got the OSU grad correct ....... but NOT an engineer. My first year I was in the college of engineering, with plans on transferring to the Colorado School of Mines, to become a geophysical engineer.
The problem was ....... I wasn't smart enough, so I shifted gears and went into the college of agriculture.
Old 03-28-2017, 09:07 PM   #62
navanodd
Drives: 2013 BRZ Sport-tech WRB
I just started mathing this out using conservation of energy, and remembered how much I dislike heat transfer.
Anyone want to check to see how much current the fuel pump draws? That's your energy input. I also don't think heat loss to the environment is insignificant.
navanodd is offline   Reply With Quote
Old 03-28-2017, 09:35 PM   #63
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Originally Posted by reeves View Post
Not sure how accurate Torque App is, but it always indicates 2.4 gallons left every time the fuel light comes on. And that light's come at least a dozen times for me.. it's always at 2.4 gallons.
So you can go 60 miles at least on the highway if you drive conservatively (using 93 octane). I've driven 62 miles once after the light came on.. cruising at 65-70mph. And still had 0.5 gallons left (again, according to the Torque app). Wasn't trying to get myself stranded on the side of the road or anything, just wanted to run the tank as empty as possible before filling up with E85.
Not sure how accurate it is either, but probably not super great. Our tank is about 13.2 gallons, so regardless of what the app reads, pay attention to how many gallons you fill up with when the light comes on. Ideally it'd happen right as you park at the pump so you could really know at what point the light comes on. Just subtract whatever the pump reads when it shuts off (no topping off) from 13.2 gallons. If the 2.4 from Torque is accurate, that means your light comes on when you've used 10.8 gallons, and that seems (to me, at least) a little late to be coming on. When mine came on a few days ago I still had a lot of driving to do, and when I got to the pump I ended up putting in 11.133 gallons. I'm pretty sure I used more than a third of a gallon of gas driving a good 20+ miles from light on to gas pump. I'm sure the light comes on aggressively to get people to fuel up sooner rather than push it.
Anyway, the tank is designed to keep a couple of gallons in reserve for those brave souls who want to let the needle go past the "E", and to try to keep the tank from going completely dry since that's where real damage to the pump, fuel system, and engine can occur. So as a rough number, I'd say maybe 11.5 gallons is what you have from full to the empty line. That leaves you a little less than 2 gallons in reserve so that the tank doesn't truly go empty unless someone pushes it to exhaustion.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 03-28-2017, 10:06 PM   #64
billwot
Actually, its the current (amps) X the voltage. (watts)
Old 03-28-2017, 10:44 PM   #65
navanodd
Of course, my bad. Knowing it's a 12V system, I was fixated on finding the current to calculate.
Old 03-28-2017, 11:07 PM   #66
Well, I don't know but, I suggest you could use 20 amps for calculation purposes ...... see how that works out.
GO ....... navanodd !!......
Old 03-31-2017, 04:26 PM   #67
PatSciFRS
Drives: Scion FRS 10 Series
Even if the pump did draw 20A, it would be wrong to assume that 240W of heat was being produced. Most of the power goes to pumping the fuel, only a fraction goes to generating heat.
PatSciFRS is offline   Reply With Quote
The Following User Says Thank You to PatSciFRS For This Useful Post:
humfrz (03-31-2017)
Old 03-31-2017, 07:05 PM   #68
Good point .......
Old 04-01-2017, 10:11 AM   #69
StraightOuttaCanadaEh
Wes
I get about 550 km on 94 octane. According to google that's 340 miles. Goddamn thirsty SOB this car is
Old 04-01-2017, 10:13 AM   #70
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
550KM? That's pretty damn good. I'm less than half tank right now but im at 300KM lol. Im on 91, maybe i should try 94 ..
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
Easy way to empty your catch can...maybe BirdTRD DIY (Do-It-Yourself) Guides 7 04-15-2016 08:18 PM
Does anybody know any empty fields in LA? Tofu-86 Southern California 2 09-13-2015 12:06 AM
OFT Tuner Help, Empty Zip Files? mopar591 Software Tuning 7 03-24-2015 01:57 PM
big empty parking lots andrew5826 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 02-20-2014 11:39 AM
empty parking lots Tt3Sheppard New England 10 09-04-2012 11:36 AM
