Northern California NorCal
Old 03-28-2017, 01:03 PM   #9227
funwheeldrive
Originally Posted by thecarfilmer View Post
Could it be true that im failing my emissions tests because my tpms and airbag lights are on?
I don't think so. What does your smog report look like?
Why are you smogging?
Old 03-28-2017, 01:08 PM   #9228
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
State ref. Oxygen sensors "not ready". everything was put back to stock.
thecarfilmer is offline   Reply With Quote
Old 03-28-2017, 01:32 PM   #9229
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
http://repairpal.com/Drive-Cycle-Issues
Also, what tune are you running?
Originally Posted by humfrz
I'm old and lazy
Old 03-28-2017, 01:35 PM   #9230
thecarfilmer
IG: @nickwiththefrs
stock tune
Old 03-28-2017, 01:49 PM   #9231
Clipdat
Proud of BOXER
Clipdat's Avatar
In that case, make sure you flash back to OTS Stage 2 when you put your header back on
stock tune
I'm old and lazy
Old 03-28-2017, 01:50 PM   #9232
Lawrezzy
Drives: 16 Scion Frs
How does one start a new thread?! Im trying to start a build thread.
Lawrezzy is offline   Reply With Quote
Old 03-28-2017, 01:52 PM   #9233
thecarfilmer
IG: @nickwiththefrs
Haha i sold my oft and header
The Following User Says Thank You to thecarfilmer For This Useful Post:
My Key (03-29-2017)
Old 03-28-2017, 01:53 PM   #9234
thecarfilmer
IG: @nickwiththefrs
go to members car journals on the main forum homepage, click on it and click new thread on the top.
Old 03-28-2017, 01:55 PM   #9235
Clipdat
Proud of BOXER
Clipdat's Avatar
Screenshot
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
funwheeldrive (03-28-2017), spike021 (03-28-2017)
Old 03-28-2017, 08:45 PM   #9236
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
I've tried to give her the Lexus but like I said she likes how practical the tC is with the hatchback... she's hauled everything from Costco runs to Home Depot to IKEA... it's basically a minivan without the accompanying stigma LOL. Plus it's a "beater" we are not afraid to leave parked out in the supermarkets and malls parking lots, whereas with the Lexus she'd be more conscientious about protecting it from door dings and whatnot.
LOL the MR2 is tempting... but I feel like I would be more inclined to get another SW20 than the Spyder again.
we should do a group photo with the other local TC105N guys ... @MisterSheep
Edison (ahhh can't remember your forum name)
Eric @ Elite Performance
@Pish
@tigermack
who else am I forgetting...
Let's do it!
Pish is offline   Reply With Quote
Old 03-28-2017, 10:28 PM   #9237
spike021
spike021's Avatar
Argh. Only stalling very occasionally now. Sometimes when I'll downshift to 2nd for a red light and then right when I'm crawling at like 6mph or so and coming to a complete stop, the light changes to green. But what I do is I go to pretty much a complete stop, put the clutch down, and then shift to 1st from 2nd, basically, but then since 2nd is higher ratio I end up stalling. Not all the time but once in a while.
Should I just stay at 2nd gear if the light is about to change and I'm coming to a stop?
spike021 is offline   Reply With Quote
Old 03-28-2017, 11:07 PM   #9238
driggity
Drives: Silver Coupe with a Boxer
I'm don't know what your previous setup was but based on my experience with ODB2 cars the "oxygen sensors not ready" result is a symptom of not driving enough after resetting your ECU.
driggity is offline   Reply With Quote
The Following User Says Thank You to driggity For This Useful Post:
Clipdat (03-29-2017)
Old 03-29-2017, 01:08 AM   #9239
Kaotic Lazagna
Drives: GR Corolla
I don't think I've ever stalled 2nd before, even from a stop. But why do you shift into 2nd so soon?
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
spike021 (03-29-2017)
Old 03-29-2017, 01:09 AM   #9240
Clipdat
Proud of BOXER
Clipdat's Avatar
Well what you've just described here is basically a "no win situation" in terms of stick shift driving. There's no "correct action" that you can take as a response to this happening.
The way I figure it, you have three choices.
1.) Clutch in, shift into first gear, and start to bring your revs up ~200-300rpm higher than usual as you clutch out and engage first gear. First gear isn't really meant to be downshifted into like this, so it's very difficult to do so without it lurching a lot. The key is more gas/revs than usual since first gear will probably be at a higher RPM that you are expecting.
2.) Clutch in, leave the shifter in second, and then start revving it up with a fair amount of gas. SLOWLY release the clutch and engage second at what is almost certainly a lower RPM than you normally would, so as you do, continue to give more gas than a normal second gear engagement.
Hopefully the extra gas will allow you to slightly accelerate as you engage the gear, and get some extra speed/inertia/momentum going, so that as you fully engage it's not lugging the engine or as hard to engage at the lower speed/rpm.
3.) Clutch in, shift into neutral, and apply the brake to come to a complete stop. Shift into first as normal and start out briskly since you just held up the person behind you a bit and didn't "react" to the traffic light as quickly as you should have, in their mind.
This third option is what I typically do because in a way it's the easiest for me if I'm being lazy and don't feel like trying to rev match first, or ride out second without lagging/riding the clutch. I really don't care if the person behind me is delayed and has to wait an extra amount of time to get going off the light. Haven't been honked at yet!
I'm old and lazy
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
