Old 03-21-2017, 10:27 AM   #2717
jwisjw
jwisjw's Avatar
Drives: 2014 Scion FR-S
I know I'm wasting valuable speed by not being patient enough, but I guess I'm curious if it's not just me overdriving, and if it's agreed upon that even on a small 2nd gear ~40s course you can take 'street' tires over their happy space, which would mean I'm making two mistakes and not just one. Just to be clear here, I'm not talking about outright stupidity and drifting burnouts, but rather someone who's going a toe over the line every corner when the trick is to step back from the limit and approach it with caution where necessary. (Or at least that's the mentality, whether or not I'm successful at achieving that approach is... well I have a long way to go).
FWIW, I've had multiple of setups on the same surface that can push, oversteer or be closer to neutral and haven't noticed tires falling off on 40 to 60 second courses in the conditions that you are talking about. Also I've noticed that varying tread depths and heat cycles come into play for tire wear/performance with different venue's.
jwisjw is offline   Reply With Quote
The Following 3 Users Say Thank You to jwisjw For This Useful Post:
justint5387 (03-21-2017), strat61caster (03-21-2017), tigermack (03-22-2017)
Old 03-21-2017, 05:44 PM   #2718
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
@renfield90 I think that's some great advice. I'm well aware that #1 and #2 areas needing improvement are my driving skill and the car setup respectively (I tried something non-standard and it didn't pan out, now heading to a more standard setup that I think will be much easier to drive). But if there's some obvious mental shift or easy change to make (like tire pressure) that can be worth a few tenths sitting further down the list of stuff to fix it doesn't hurt to tackle it sooner rather than later.
I'm thinking that renfield90 may be right and I could be fighting tire pressure. I'm coming off course at ~34-35 psi (I've been as high as ~37, fun, but not fast methinks), I've run lower on other tires but not the RE71R, the pyrometer was showing even temps around the low 30's and so I never went lower. I think that's the next experiment.
But, nice to know that tire management is not a factor in what I've experienced. I presume you also mean to imply that on those hot days you can absolutely overheat the tires, especially on a >60s run in >90 degree heat we'll start to see in the next few weeks (hence the sprayers between runs).
ineedyourdiddly
Old 03-21-2017, 05:56 PM   #2719
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Those are really high pressures, and would explain some of what you're experiencing. Dunno what your camber settings are at, but I run 28/29 F/R, and my pressures generally only increase by 1.5-2 PSI on my run. I'd suggest trying those lower pressures and seeing what that does for you.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 03-21-2017, 06:03 PM   #2720
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Now I have all of your secrets!
MUAH HA HA HA
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 03-21-2017, 06:13 PM   #2721
Stang70Fastback
A.K.A. Starlord
MUAH HA HA HA
Or maybe that was my plan all along! Shark-Bait takes the bait!
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
Racecomp Engineering (05-08-2017), strat61caster (03-21-2017)
Old 03-21-2017, 06:14 PM   #2722
Shark_Bait88
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
Stang70Fastback (03-21-2017), strat61caster (03-21-2017)
Old 03-25-2017, 08:49 PM   #2723
bslate3
Drives: 2015 CWP BRZ
Today's day 1 at the TX Tour was super fun! Great last run Rennfield!
Tomorrow will be another fun battle!
bslate3 is offline   Reply With Quote
Old 03-27-2017, 09:07 PM   #2724
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Great time at the College Station tour! Nice to meet a bunch if you guys and great site/surface!
Just got home from the long drive a couple hours ago, but worth it. See y'all next time.
justinco is offline   Reply With Quote
Old 03-27-2017, 09:17 PM   #2725
Blue Gt
Blue Gt's Avatar
Trophy run!
Congrats Justin on 4th place, nice job with the new car. DP
Blue Gt is offline   Reply With Quote
The Following User Says Thank You to Blue Gt For This Useful Post:
justinco (03-28-2017)
Old 03-27-2017, 09:34 PM   #2726
bslate3
I had a bunch of fun racing against you guys!
Great job Justin on day 2 to snag that last trophy spot. I just totally over drove my last run.
Congrats Manfred on the win.
I need to do some more national events, after a header and tune lol.
The Following User Says Thank You to bslate3 For This Useful Post:
Old 03-28-2017, 01:20 AM   #2727
renfield90
The Stig's German cousin
Thanks Brandon. Good to meet a lot of you and put faces to names.
Thanks to TX for being great hosts despite the weather Friday!
Old 03-28-2017, 12:16 PM   #2728
conedodging
conedodging's Avatar
Drives: '14 BRZ
Quite a few twins using BFGs, I'm assuming the new Rival S 1.5, at the Tx Tour. Are they better than the RE71Rs all around, or just on concrete?
conedodging is offline   Reply With Quote
Old 03-28-2017, 04:52 PM   #2729
renfield90
See the D Street thread for tire discussion. The short answer is many are finding the 1.5 to be a positive improvement, but IMO you still can't go wrong with either tire.
The Following User Says Thank You to renfield90 For This Useful Post:
Shark_Bait88 (03-28-2017)
Old 03-28-2017, 05:01 PM   #2730
Shark_Bait88
This seems to be what it's sounding like from everything I've read.
Based on what I've heard, I think the BFGs would suit my driving style a bit better, but I'm going to stick with the Stones I recently bought for now. I'd very much like to try the S 1.5 though. Perhaps mid-season...
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
cjd (03-28-2017)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
